Totally Tubular
#851
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
Anybody ever use these ?
New Continental Giro Road Track Train Tubular Tire 22mm Sew Up Tyre 700c 27' 28" | eBay
#852
Quoted: 378 Post(s)
Liked 1,409 Times
5.83 each at REI's yard sale today. 700x21
"standard" Practice is 700x22.5 (note the play on words)
Classic look, 270 TPI. All the tags were in Japanese.
Perfect for an 80's build.
#853
Great find! I haven't seen any of these in Sendai, but I think I'll ask my LBS about them
Vitus 979, Simplon 4 Star, Gazelle Champion Mondial, Woodrup Giro, Dawes Atlantis
#858
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
BTW, what do you guys use to glue the base tape back on after a patch? My tape always puckers up and is unsat. All the hints I see call for "latex glue" which I've never seen in an appropriate size package.
Show me an actual product.
#859
Quoted: 628 Post(s)
Liked 316 Times
I have glued the tape on with this : https://www.amazon.com/00107-3-Ounce-...tact+cementAnd I use this to glue the tire back on :3M 08031 Fast Tack Trim Adhesive Tube 5 Oz | eBay
#860
Quoted: 556 Post(s)
Liked 132 Times
I use contact cement too, D-Scott. Never understood what "Latex glue" might be.
But Pliobond is rubber-based and would probably work well too.
https://www.amazon.com/Pliobond-P141-.../dp/B00176HL9Y
#861
Bikes: '72 Peugeot PX-10; '74 Raleigh International; '87 Specialized RockHopper; '88 Specialized StumpJumper; '02 Cannondale Scalpel
Quoted: 46 Post(s)
Liked 9 Times
1000 miles on a Servizio Corsa tubular
After about 1000 miles, my rear tubular tire developed two significant bubbles.
Just out of the blue.
The bubbles caused the outer skin to tear away from the inner casing.
The tread was worn smooth, so the service life of the tire was almost gone.
The good part is that it got me home safely.
Good, because I was really tearing down that last hill, unaware of the damage.
Check your tires regularly.
#862
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
For the few tires I've patched I've used the same stuff for holding the tire on the rim. My base tape always puckers too, but I don't think it's the glue. I think it's my sewing technique.
Real cyclists use toe clips.
jimmuller
jimmuller
#863
Quoted: 628 Post(s)
Liked 316 Times
One thing I found out the hard way is you can't rob the Ms. sewing box for the thread . I use the new type braided fishing line (only because I have it) that stuff is super strong . Jim I agree , why use two different types of glue ?
#864
Quoted: 86 Post(s)
the sorriest looking set of tires, that hold air, i've ever seen on a bike. had to laugh...
#865
Really? In my house only I have a sewing box. Princess Lenton pays to have her buttons sewed back on
#867
The only latex I know of is just plain old latex, which might be useful for coating sidewalls, but I could never imagine it bonding tape to tire. I have used contact cement like the others.
One time I tried to re-glue an entire base tape, but didn't have the sense to do it on the rim. I think the tire ended up about an inch shorter than it needed to be. Of course I found that out on the road when I flatted and went to use it for a spare. Oops. Wound up just tearing the tape to get the tire mounted.
#868
Quoted: 628 Post(s)
Liked 316 Times
I knew there was a reason I was told to use contact cement on the tape . Thanks due route .
#869
Bikes: 1938 Raleigh Record Ace (2), 1938 Schwinn Paramount, 1961 Torpado, 1964? Frejus, 1980 Raleigh 753 Team Pro, Moulton, other stuff...
Quoted: 26 Post(s)
Liked 11 Times
#870
It's MY mountain
Liked 2,980 Times
Sew-ups are on for Saturday's charity ride.
#871
It's MY mountain
Liked 2,980 Times
Screw it - I got a couple more this week after I flatted on Saturday. I think they might be discontinuing this model and I really like it and it comes in 27mm width. The flat was a Yellow Jersey cheapo anyway, so now I'll match both tires.
#872
You could also use it to replenish the worn off latex of your sidewalls...
Anyhow, you brushed some on the base tape, and some over the sewn up repair, let it flash dry, and pressed them together. So yeah, it was actually contact cement. Offhand I'd say it was more or less identical to the water based contact cement you can buy today.
I'd suppose any good strong contact cement could do the job. Testing first would be a good idea.
#873
Quoted: 1607 Post(s)
Liked 2,216 Times
I keep finding old sew ups with the base tape starting to separate from the casing. I am tempted to use them because they still hold air. One pair are Clement Futur CX. Decent tread but the casing on the sidewall is showing and the base tape has thread hanging all around.
I was looking for Latex glue but now that y'all have agreed on Contact cement. Thanks for the validation and a solution.
#875
Quoted: 834 Post(s)
Liked 2,126 Times
Another option for base tape adhesive might be 3M Fast Tack. It was a pretty common emergency glue commonly used when I raced back in the 80s. It dries within 30 minutes or maybe an hour, so one could use it on race day if you got a flat during warm-up. Some people used it as a every-day glue. The main complaint was that it was too strong, such that when you needed to change a tire, it often pulled the base tape away from the casing and left it on the rim. I've been using Barge Cement for re-applying base tape, but I think the 3M Fast Tack would be a good option. It's used for car upholstery, and still readily available at most auto parts stores. Anyone tried it on base tape?
