Totally Tubular
#2076
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
I have a question that I'm sure some here could answer. I have a set of tubulars that I plan to mount with Jantex Competition 76 tape. Many years ago I rode tubulars for a while that I mounted with glue. I had a spare that was pre-glued. Now, if I flat with tape, and I take off my tire, and the tape stays on the tire, can I reasonably safely ride home on a un-glued & un-taped spare if I take it easy? No fast downhills or fast cornering on the way home. I'm thinking that I'd rather not try to do a tape job on the side of the road and I'd like to take off the spare and replace it with either the repaired flat or a new tire when I get home. Am I crazy? Lets assume I don't have sealant with me or it doesn't seal the puncture. Thanks for any advice.
Likes For CV-6:
#2077
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
If you take it REAL easy, and you pump the tire up to a high PSI... you could ride home safely on a naked rim and an unglued tire.
Likes For DiabloScott:
#2079
Quoted: 591 Post(s)
Liked 663 Times
If you are swapping a spare in, then you will have glue on the rim.
#2080
Quoted: 394 Post(s)
Liked 346 Times
Not if I'm using tape. I was just asking if a spare with dried glue would stay on the rim any better then without glue at all. Would the glue remain tacky over time? It's pretty clear how to handle a flat when gluing your tires on. But with tape I'm not sure. I guess I'll mount my spares without glue and see if they seem like they'll stay on just riding easy around the neighborhood (as a test). I'll do this before taping my new tires on. If they don't seem like they'll stay on I'll pack some tape with the spare like you suggested above. Thanks.
#2081
It's MY mountain
Liked 2,981 Times
My spare is always used, so it has some glue on it - I'm pretty sure there's no disadvantage to putting a pre-glued tire on a pre-taped rim.
The other thing you have to be careful with, when riding a less-than perfectly glued/taped tire, is braking... the tire can creep around the rim and then the valve will get crooked and then there can be problems.
Rolling sew-ups off the rim is the kind of horror everybody's heard about; I have literally NEVER seen it... except for the famous Beloki crash in the TdF... and that was HOT, at race speed, and a steep winding downhill. A lot of the stories (especially criteriums) are crashes for OTHER reasons and then the tire comes off IN the crash rather than CAUSING the crash. So yeah be careful, but quit worrying.
#2082
Quoted: 394 Post(s)
Liked 346 Times
I've seen it happen once. This was around 1985. I was riding in a small group and we were nearing the end of a ride where we would often crank it up if we had any gas left. We were going pretty fast but not really sprinting, maybe 28 or 30 mph. We were drafting each other when the guy in front's front tire came off the rim! We were on a straight stretch of road and he managed to keep it upright as he rolled to a stop on the rim. The tire was still inflated and it just stayed right between the rim and the fork crown and off to the side of the rim at the bottom. I remember that the glue was not tacky at all. No telling how long he rode it like that before it finally came off. The glue must have just completely dried up or not been adequately glued to begin with. That's kind of stuck with me all these years.
#2083
It's MY mountain
Liked 2,981 Times
Checking your glue condition is a standard PM. Once a year is probably fine - twice a year if you're a worrier. Do it without air in the tire so you can really peel up the edges and look for the boogers.
#2084
Question about Velox Jantex Competition 76 Tape
Has Velox Jantex Competition 76 tubular gluing tape been changed/upgraded in recent years?
On vendor sites, I often see Velox Jantex Competition 76 tape referred to as "Belgian tape" that "Must be used in conjunction with tubular glue". These sites usually have a picture of a yellow-tan roll of tape. However, the Velox.fr website shows it as looking more like Effetto Mariposa Carogna tape, but with a pink color, and says nothing about it being Belgian tape. Nashbar.com mentions "New formula for 2015" but contradicts itself about the need to use glue with it.
I know about Belgian tape, used for 'cross tubulars (https://cyclocrossworld.com/how-to-g...-belgium-tape/), but Velox Jantex Competition 76 ain't Belgian tape. I'm just curious about all the confusion in the product descriptions, and wonder if I should try to order some from a website that shows the newer pink stuff. Maybe the distributor (QBP?) is giving all the vendors inaccurate product information. Any advice is appreciated.
#2085
#GCVintageBicycles for pics of C&V bikes and parts.
#2086
Quoted: 566 Post(s)
Liked 1,052 Times
I used the Velox tape and it didnt say anything about using glue. I didnt use glue and so far all seems well.
#2087
Quoted: 1163 Post(s)
Liked 442 Times
Can you share which tires you were proposing to use with the Major Toms for road? What is their width?
#2088
Quoted: 1951 Post(s)
Liked 2,012 Times
25mm Sprinter Gatorskins. I mounted them and with glue and 90 psi, the radius of the tire was significantly less than the rims. There was a gap on both sides when the tire was centered. While the tires were secure, the gap would have filled up with sand/dirt/etc. I didnt try 28s because my road bikes dont have the clearance.
#2089
Liked 442 Times
Classtime - sorry the Sprinter Gatorskins did not work out and sorry your frame cannot accept 28s.
Any chance that a bonded (not a sew-up) tubular like a TUFO or a Conti GP4000 tubular with more of a flat base tape might work better in the 25 mm width?
#2090
Liked 2,012 Times
Somebody else is racing CX on those Major Toms. My go to road tire is a regular 22mm Sprinter. And the 25mm Gatorskin is for Eroica, The BWR, and one day, Cino. (Those 22mm Sprinters on 7900/Nemesis felt pretty awesome today.)
#2091
Liked 442 Times
I have Major Toms (polished) built up with Chris King road hubs into a custom road wheelset. I have not ridden them yet but hope they work for me for road.
#2092
Need to get new tubs like my Strada
Lo
Love the way these ride... gifted to me by a friend. But it seems the new Strada has a synthetic sidewall, spun poly or something. These look like Egyptian cotton judging from the outrageous psi rating but I don't know. As a recreational rider 150 lbs they run great at 90/100psi. I vaguely remember how a great tubular like the clement seta rides from the 70s so I'll be disappointed if the new ones don't have a good feel and sound. And I'll be damned if they don't have a tan sidewall! Should I go for it?
#2093
Quoted: 1324 Post(s)
Liked 927 Times
I just put a pair of Servizio Corse tubular tire onto the rims. Unfortunately the rear tire isn't sitting quite right at the valve stem and thus there's a bit of a bump every revolution. What's t he easiest way to get the tire to sit on t he rim perfectly round. I haven't applied the tape yet because 1. I was wanting to stretch the tire prior to doing that and 2. I wanted to be sure the tire was perfectly round on the rim.
Thanks and cheers
Thanks and cheers
#2094
Bikes: many
Quoted: 1444 Post(s)
Liked 1,394 Times
#2095
Liked 2,012 Times
I've never mounted Servizio Corse tires but Is is very important that you mount the tire with a great deal of stretching force from the beginning -- at the valve -- or you end up with more tire at the valve. And if the base tape is doubled at the valve? Well?
#2096
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
#2097
Quoted: 2338 Post(s)
Liked 2,827 Times
Thanks and cheers
Thanks and cheers
Tubular Tire Mounting Cement Gluing Adhesion by Yellow Jersey; Thoughts on a Front Wheel
#2098
Quoted: 2432 Post(s)
Liked 638 Times
I only pre-stretch my tires if they're super tight and then I only stretch them overnight. I've never had problems with lumps if they aren't stretched.
#2099
Liked 927 Times
Yesterday I manage to g et rid of the hop near the valve stem. Unfortunately te tire now has a hop in a different location. I didn't feel like messing with it today.
Funny thing is that the front tubular tire went on the wheel with no hop at all.
I shall persevere and get this rear wheel t ire hop out... eventually. I'll let you all know when that happens.
Cheers
Cheers
#2100
Liked 638 Times
I've mounted tubs so many times now that I'm good at getting the tension even all the way around the first time. If I do an up getting a lumpy spot I'll just pull over to the side of the road, remove wheel, deflate and readjust the tension to stretch out the lump then air it back up and continue the ride. Not a big deal.
