Cabon Fiber Folk
Quoted: 364 Post(s)
Liked 137 Times
Cabon Fiber Folk
I just bought a new/used bike with a Carbon Fiber Fork. Given all the bad news about CF. then passed few years, should I replace the fork with a steel one or not?
Quoted: 364 Post(s)
Liked 137 Times
Carbon Fiber Folk
I know that many commuters have replaced their C.F. bikes with Steel or Alum. I have a new/used bike with just the folk that is Carbon Fiber. Should I replace folk with steel or Alum.?
Quoted: 2625 Post(s)
Liked 3,173 Times
If you're determined to replace it, either steel or aluminum would probably be fine. Some people believe that steel forks give a pleasanter ride, but I've never been able to tell any difference, and I've owned maybe 15 high-end steel racing bikes (including one with an aluminum fork) and several aluminum racing bikes, two with aluminum forks. For what it's worth, my favorite race bike has an aluminum frame and fork.
It would probably be a good idea to determine the rake of your present fork, as well as the length of the steerer tube, before buying a replacement. And the fork should be compatible with the bike's front brake and wheel, obviously.
Liked 3,173 Times
Just replied in your other thread, which has a slightly differently worded version of the same question.
Answer to the question posed here: I wouldn't bother. The percentage of failed forks must be tiny, or the manufacturers would have been motivated to stop using carbon by costly lawsuits claiming that all those failed carbon forks failed because they're inherently unsafe.
Quoted: 3335 Post(s)
Liked 2,182 Times
There’s no such thing as all the bad news about carbon forks. They are used on a million bikes with no issues. Touring bikes with steel frames are likely to see steel forks because they are easy to install eyelets and rack mounts. If you have no eyelets and need them to mount a rack, by all means get a steel fork. I would get steel before I would use aluminum. No point in changing because of poor understanding of carbon forks,
Likes For Steve B.:
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
Really?
Genesis 49:16-17
Genesis 49:16-17
Liked 3,173 Times
Likes For Trakhak:
So, why is the news all bad on carbon? So far I havent seen any issues with any of my carbon bikes and its pretty rough around here in Colorado.
I did just visit a friend in Tennessee and he was saying he wouldnt want to ride a carbon MTB because he was afraid it would fail so maybe this is just misunderstood?
Disco Infiltrator
Liked 2,116 Times
Likes For Darth Lefty:
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3130 Post(s)
Liked 6,797 Times
Merged duplicate threads.
Clark W. Griswold
Quoted: 4505 Post(s)
Liked 4,190 Times
Unfortunately poorly made components of any material can fail. However carbon is generally not an issue. As someone who has 4 carbon fiber forks and has commuted on them I would not replace them. Two of the fork are from Whisky Parts Co. One is ENVE and the other is Specialized and the Specialized fork is the oldest followed by the ENVE and have had a lot of miles on them under a heavier rider with no issue.
The carbon I would worry about is really old carbon and really cheap stuff from unknown sources but if properly laid up from a known source nothing to worry about.
Quoted: 7397 Post(s)
Liked 2,572 Times
Carbon fiber is prone to abrasion. Watch for that, though it's a danger mostly in crashes, not everyday use.
Mad bike riding scientist
Quoted: 6278 Post(s)
Liked 4,322 Times
I had qualms about carbon forks when I got my first on a Salsa Las Cruces in 2006. I put that bike into retirement in 2021 but over the intervening 16 years and 22,000 miles, the fork is still as good as the day it went on the bike. Don't worry about it.
Stuart Black
Stuart Black
yes, I was just watching a youtube that talked about the "ring of death" dealing with the headset where you need to keep it at the right tension otherwise a worn spot can happen to the carbon fork.
now with that said, I do have a bike with a carbon fork and have not had any problems.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 678 Post(s)
Liked 431 Times
What bad news is that? It's too light, too responsive, too strong, too repairable, too common in virtually every type of cycling? Is it because F1 race cars, aircraft, and space vehicles use CF as a common material? Could it be that a few decades of testing, improvement, and use isn't adequate?
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Quoted: 2531 Post(s)
Liked 766 Times
It really should be stressed in more follow-up posts than just this one, how important it is to get the right fork as a replacement. I personally don't think it is even possible in a lot of applications. For MTB there are all kinds of shock forks and suspension 'corrected' rigid forks available on the aftermarket and something can be found that can work. For touring and racing bikes, the fork design is more integral, and often the only practical replacement is no replacement at all. TL;DR: live with the bike as is or get another that does not have components that cause worry.
