Is there a wrench for this?
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
As I mentioned in my original post, I've tried a chainring wrench. It didn't work at all. I imagine with some filing it could be made too work. I'll have to see what I have in the parts bin.
Bikes: many
Liked 1,392 Times
I'm still out of town (coffeeneuring at Tosi's in St Joe, MI this morning). I will disassemble things when I'm back home (on the weekend) and take pix. My guess is this was how Miyata did their seatpost binders, so it was probably a stick part of some framebuilding supply place inn the early 80s. My understanding is the Univega Super Speciale frame was in reality a Miyata something-or-other. This thought is reinforced by the comment by SurferRosa about using JB Weld to solve the same issue on a Miyata 812.
Likes For smontanaro:
I have a SR Maxima that has the same binder bolt, it can be tightened with using only a allen wrench. Mine was mounted with the slotted side of the nut facing inside the seat lug. The slotted side is slightly beveled on the edge, I'm thinking that's what holds it in place while it's being tightened. Try flipping the nut, maybe it'll tighten up.
Likes For brian3069:
Quoted: 887 Post(s)
Liked 335 Times
I have a Miyata 1000 with that same seat post bolt. There is no slot in the frame or tab on the bolt/nut. The nut will not take an allen wrench either; so I put mine in a little plastic bag marked 'original Miyata seat post bolt" and used a quick release clamp that I had in the bin o'parts.
Likes For dweenk:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times
... reinforced by the comment by SurferRosa about using JB Weld to solve the same issue on a Miyata 812.
Likes For SurferRosa:
señor miembro
Liked 6,484 Times
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Well nevermind then, if you're gonna use that newfangled math, like algebra or trigonometry or whatever ya got there. 🤔 I got my mind fried on that math stuff, just switching to "new math", in the '60s. 🙄😉 You couldn't even get help from your parents, cause they were confused too. Maybe even more than us kids. 😟
señor miembro
Liked 6,484 Times
Quoted: 2363 Post(s)
Liked 1,749 Times
Likes For madpogue:
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
Thank you. ✌️ I dunno, I can spell and punctuate properly just fine, but my math circuitry is definitely faulty. 😟
And it doesn't help anything, when I reply to threads, as if it were a competition, sometimes. 🙄 I know I should use some restraint, but apparently I don't have enough sense to actually do so.
I'm gonna work on that. 🤐
Bikes: '85 Le tour Luxe, Puch Mixtie, Raleigh Gran Sport, Mystery Machine
Quoted: 34 Post(s)
Liked 12 Times
Just make your own tool from some flat stock steel. But first clean that nut-slot up with a file. Put a handle on it, or hold it with pliers. Never use a tapered blade screwdriver on a straight walled screw slot. Use a hollow ground blade. Good Luck.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Everyone is guessing about all of this c**p and how to make a bad idea work....
My first question is what does the other side look like? Please post a picture of the NDS and the rear of the lug.
A photo is worth more than a thousand guesses!!!
verktyg retro grouch!!! ;50;
Sorry for being so nasty...
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 887 Post(s)
Liked 335 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
These kind of binder arrangements are actually the best imo, mainly because the ordinary kind of 8.8- or 12.9-grade "socket head cap screw" tends to be a lot stronger than the typical, shouldered and headed "Cr-MO" binder bolt. I've never broken one!
The nut should be on the left side. And the nut (if it doesn't press-fit into the lug socket on the left side) should be fixed in place with Loctite or other adhesive.
Lastly, the seatpost slippage may be remedied by simply lubricating the bolt/nut threads, which will better convert bolt torque into clamping force, while lessening the unwanted turning force on the nut in the lug socket (so the bolt can draw up tight instead of the nut just spinning in it's bore).
Bikes: many
Liked 1,392 Times
I'm back from Michigan and starting to catch up on email. I spent a bit of time with the Univega this afternoon. As far as I can tell, the "ports" on the left and right side of the binder assembly are identical. Switching left-to-right won't improve things by itself. The 26.8 seatpost is a perfect fit (nice parallel slot). It doesn't slip when I can get the bolt & nut snugged up. I searched through my box of odd small wrenches and found one to modify. Aside from too much underbiking which wrecked a nice tubular, I've solved the problems with the Univega
Seatpost slot detail
Nut detail
Modified "wrench"
Nut detail
Modified "wrench"
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
You went all the ways to Michigan just for coffee, but refused to buy a new binder bolt? 🤔😁😉
The same type of nut was used on handsaws in the 19th century and various other old machinery. Generally known as "Split nuts" Thinking about it, most binder bolts also resemble the type of saw nut that replaced split nuts starting around 1870ish. The usual answer for old tool retrogrouch equivlents is to get a wide blade screwdriver and fie or hack saw a slot for the bolt. Alternatively, spend years digging through old tool boxes at flea markers and tag sales until you find a century old one. I've done both, but the former is much quicker.
Split nut saw nuts: https://www.amazon.com/Taytools-1157.../dp/B07CJ8SGJV
saw nuts: https://www.amazon.com/Chicago-Screw...79480386&psc=1
Quoted: 887 Post(s)
Liked 335 Times
I've got one like that too. I don't have a tool for it, I hold a small screwdriver in one of the notches while I tighten the screw.
Quoted: 3464 Post(s)
Liked 2,829 Times
I would flip the bolt just for grins
originally the bolt faced the drive side
lube the bolt not the slotted nut.
with the bolt away from the bike thread the bolt and nut together and check for fair threading and bolt straightness.
I am not fond of this design.
I would consider a longer bolt, bushing and a nylock nut that you can get some purchase on.
Bikes: many
Liked 1,392 Times
Ah, we did not. Thanks for the reminder.
I don't have a decent picture of the setup. I meant to take one before we left the beach house, but forgot until we were home after dark. So, imagine the bike on the rack with a bungie cord through the wheels to keep the front end from flopping around. The two ends of the cord connect right over the front derailleur. My theory is the road vibration over the 2+ hour drive coupled with the slight pressure from the bungie cord served to push the not-quite-tightly-enough secured derailleur down just a skosh, enough that it scraped the large ring on each rotation (demonstrating that the Ofmega-manufactured crank or chainring wasn't perfectly round).
The fix was trivial. Push the shift lever to its limit to slacken the cables a bit, then raise the derailleur slightly, less than a millimeter.
