1971 Bianchi build
#76
Quoted: 1608 Post(s)
Liked 2,216 Times
Decided to tackle the issue of a standard binder bolt not fitting in the holes of the seat lug ears.
It occurred to me that maybe the edges of the holes were deformed from using other fastening approaches. A small screwdriver sliding along the bor towards the out side of the hold confirmed the deformation. A tapered reamer was used to lightly dress the outside edges of the hole.
The bolt slipped right in.
This is what was used to clamp the post upon arrival
71BianchiSeatLug Bolt on Flickr
Using a standard 6mm socket binder bolt, likely not the original configuration as there is a key notch on one side, Patina and all. I have come to appreciate the history the chips and overall condition of the paint.
71BianchiDone15 on Flickr
71BianchiDone16 on Flickr
Given the overall appearance will not change significantly from this point on. Additiions are few an far between.
Thanks for all that subscribed, added comments, information, and advice!
Likes For SJX426:
#77
Quoted: 4512 Post(s)
Liked 6,386 Times
#78
Quoted: 874 Post(s)
Liked 2,290 Times
I sure like the look of this bike! It has just the right amount of "history" witness that says it has been enjoyed....and lives on. Good job and enjoy the journey. Joe
#79
Liked 2,216 Times
You guys may be too nice to me but I think I placed the DT decals too close to the BB. I don't like where the fork decals are located either. They should have been about 1/8th to 1/4" higher.
The DT shifters are too low too. Good used cable worked but doesn't allow for moving it up.
After looking at a number of frames, it appears that the end of the ST decal and the DT decal should be about level. I was looking at the spacing between the chain rings and the seat cluster for the ST and the shifters for the DT. My bad.
#80
Quoted: 637 Post(s)
Liked 1,287 Times
Aging process is also up for consideration. Any suggestions? Intense UV light? Weathering – Aging Decals – Trains4Africa
#81
Liked 2,216 Times
@Murray Missile - I decided not to age the decals. The bike looks pretty good at 10 ft without aging them as shown in the first pic of #75.
I am now looking for a way to mount a water bottle cage. The old style clamps, that capture the top and the bottom tang of the cage, are not easily found anymore.
Likes For SJX426:
#82
Quoted: 637 Post(s)
Liked 1,287 Times
#83
Liked 2,216 Times
@Murray Missile - Those are the type of clamps I am looking for. Good you have that assembly!
I may have one clamp but need to check the stash for the second.
#84
Quoted: 3464 Post(s)
Liked 2,831 Times
@SJX426
You're welcome. anytime.
If that hole is threaded it may be for a zerk or oldschool fliptop port.
I did a lot of hand wringing when Randy put this up, and a lot more as it stayed up, had it been any bigger.....
This is a fantastic get IMO, when do we ever see an old one like this for any sane $$$?
It may or may not be one of the most desirable ones by the book, who cares, again its fantastic no matter what and you would have to spend much more time and $$$$$ to do any better if at all.
We all know how "stupid" these can be.
I bought a way too small bottom of the line older one similar to this just because and it has some ok parts on it, maybe it will bring me a better bigger one.
that added dimple to the chainstay is a dent.
who knows how it got there, by force somehow.
Steerer is probably Falck tubing.
even Bianchi could not keep Celeste color matched. There was a blog somewhere that made mention of the basic formula-
yellow, blue, white and black!
the black helps knock back the intensity.
there were basic ratios but one really has to go by eye.
Likes For repechage:
#85
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
Several of the big bicycle aftermarket parts places sell strap style band type clamps. these are cheap and allow use of more modern bottle cages. They don’t look too bad.
#86
Liked 6,386 Times
the threaded hole in the headtube is for a slotted pan head screw- it is for adding oil to the grease.
Really glad this frame found a good home, it was saved from what would likely have been a much lesser fate.
@SJX426 did a fantastic job on it IMO.
Likes For merziac:
#87
Liked 2,216 Times
@merziac - thanks for the kind words!
I found what I needed for mounting a bottle cage. If I could find another pair....
I could mount a bottle cage on the Bottecchia.
Likes For SJX426:
#89
Liked 2,216 Times
@Positron400 - Thanks! I like it too! I think they are products of VeloCals. They were purchased with the bike frame.
Fortunately, the decals ended up on paint that did not have any dings.
#90
Liked 2,216 Times
Finally finished and ready to ride.
Purchased the TS-2 from @obrentharris, thank you, it was well used and working fine for a limited range so disassembled and cleaned it up. Pulled a front wheel with uniform dish on both sides and calibrated the stand forks. Then did the final truing on the Bianchi wheels, which needed it.
Glued the tires on and polished the rims. Or polished the rear rim then mounted the tire. Front rim was polished after gluing the tire on, mistake. Now have to clean the side walls.
Closing shot for this thread.
Likes For SJX426:
#91
Likes For aceves:
#92
Bikes: '93 Cannondale R500; '88 Centurion Ironman Expert, '97 Cannondale R900, '95 Serotta CSI, '83 Trek 700, '97 Lemond Zurich, '89 Bianchi Giro, '87 Schwinn Prologue, '83 Fuji TSIV + one perturbed wife
Quoted: 71 Post(s)
Liked 154 Times
Nice Work....the Bianchi is gorgeous!
Likes For Triplecrank92:
Likes For Positron400:
#95
Liked 2,216 Times
Thank you all for your positive comments! I am a bit smitten by it myself.
Took it out for a trial run of about 8-10 blocks just to see how it feels. NICE! Not twitch like the new bikes in the stable.
First impression was the gearing, really high. Funny I never checked it out. Rings are 54/46!. I selected a close block in the back to make it more period correct with 14-22 in 2 tooth increments. No wonder I couldn't find a slightly used chain long enough!
The other issue is the HS. it was loose prior to the ride. Then I remembered that I really don't have a tool to lock it in place. Any suggestions?
71BianchiTopHS on Flickr
Likes For SJX426:
#96
Liked 6,386 Times
https://www.amazon.com/Adjustable-Spanner-Chromium-Vanadium-Bearings/dp/B08THHCW7N/ref=sr_1_19?keywords=adjustable+hook+spanner+wrench&qid=1675890385&sr=8-19
I also use leather to insulate the fitting from Channel Locks.
#97
Liked 2,216 Times
@merziac - I looked at those but the diameter of the pin, 3/16, is more than twice the diameter of the hole, ~2mm. Couldn't find one with that small a pin. My suspicion is it would require a pin made of much stronger material.
I may have to make on by modifying a tool.
A 3/32 drift punch fits really well.
#98
Bikes: A few
Quoted: 289 Post(s)
Liked 197 Times
I have a Unimat lathe, which uses “Tommy bars” to tighten the chuck. I thought they were smaller in diameter than these listed, you could modify, or just pick up some drill rod of the proper diameter.
https://www.ebay.com/itm/18573532307...IAAOSwEx5ffNpB
#99
Liked 6,386 Times
Or maybe cut off a couple of the punches short to use as levers in opposing holes, for temporary if nothing else.
#100
Liked 2,216 Times
@merziacI have an extra adjustable wrench that opens to 30mm, fits around the HS lock nut. 3/32 dirft and 8 drill bits ordered. Going to drill a hole in the fixed part of the wrench at the rright locations.
Likes For SJX426:
