Do french-threaded single speed freewheels exist? (bmx?) if so, where...
I'm working on converting my peugeot UO8 to single speed. Unfortunately, I pulled the freewheel and it is apparently french-threaded (the guy at my LBS said there would be markings on the hub if the threads were different from the country of origin, which there weren't).
So, now I'm in search of a single speed, french-threaded freewheel (16T is fine). Does anyone know if they exist? And if they do, where I can get one?
tarck bike.com exile
Bikes: bfssfg iro--black.
yeah for real. just get a wheel that isn't french threaded and your life will be so much easier.
i don't know the answer to your question if you decide to tough it out. i would just get a new wheel.
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
check to see if it is french threaded or metric freewheel thread they do make metric freewheels for bmx in small tooth counts acs makes a few as well as dicta
nope it's definitely not metric, that I can tell with a ruler. Unfortunately, french and english are so damn close I don't know how to tell without just threading on an english freewheel (which hopefully I can do tomorrow).
*****es love tarck
Bikes: so many
I didn't know french hubs had different threads. I wouldn't bother with the stock UO8 wheels anway. Unless they've been upgraded they're steel and not worth the trouble, IMO.
some new kind of kick
hands up for giving france in its entirety to germany so the germans
can make sure the stuff is standardized and works. . .
Paste Taster
good point, i'm going to try and thread on an english freewheel tomorrow.
And, if I'm going to do the wheels I may as well do the whole thing right. I have cottered cranks, so I think replacing the cranks will mean also replacing the BB (also french threaded... they're available, just expensive). Then I can do a new chainring, new cranks, new wheels. Replace the brakes and it'll be like a whole new bike. I'm estimating $300-400 for this project, which is a lot to throw into this bike - but it means a lot to me so I might go for it.
$90 for a set? I'll have to check these out... and make sure they'll fit in my forks.
Don't bother with steel. There are tons of leftover aluminum rimmed wheels around from all these conversions. Ask around and maybe you could score a set for free.
https://blicksbags.com/
my bike Owns me+my wallet
Bikes: Px-10 singeld, 2007 KHS filte 100
I'm quite sure that That bike does NOT have a french threaded freewheel, The U08 is a canadian made peugeot many of the parts are not french and as far as i know the diffrence between french and english freewheel threading is not that diffrent so even if it is, french maybe locktight,
But even then Just get new bloody wheels, you will likely not regret it
The steel rims are reason enough to ditch the wheels, let alone any oddball French sizing issues. I have two sets of a aluminum rimmed 27" wheels in the garage I would give away. It seems like the OP should be able to find a better set easy enough.
I found some options on an online moped store that sells french thread single speed freewheels that should be cross compatible.
Check out treatland.tv and search freewheels
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Last post by the OP was on 6-11-09. Gotta love these newbies with their resurrected zombie threads.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Likes For TejanoTrackie:
Honestly, though, I think a lot of people use these forms as a sort of archived encyclopedia of bike knowledge and advice, so it never bothers me when somebody resurrects an old thread with new information. Yeah, the op won't get anything out of it but who knows how many other people might know to check with moped shops now if they're looking for a French threaded freewheel.
Veteran Racer
Liked 764 Times
Quoted: 2482 Post(s)
Liked 2,955 Times
The old bike mechanic in the shop where I bought the bike simply unscrewed the BSA sprocket, wrapped the hub in aluminum foil, and reinstalled the sprocket. Held with no problem for as long as I owned the bike.
Likes For Trakhak:
Veteran Racer
Liked 764 Times
Liked 2,955 Times
Veteran Racer
Liked 764 Times
