Anyone Ever Use Toe Clips With BearTrap Style Pedals?
Extraordinary Magnitude
Quoted: 2609 Post(s)
Liked 1,704 Times
Has anyone used toe clips and straps with the Bear Trap style pedals?
I was sort of gifted a set of Union pedals, I didn't think I would ever use them- more "BMX-y" or "mountain bikey" than I would go for. I got an idea to just throw them on my Voyageur- and I pretty much like them. I've also decided that I really don't like not being connected to the pedals- so I thought it might be nice to try clips on them.
Commence to jigglin’ huh?!?!
Quoted: 795 Post(s)
Liked 1,811 Times
I have used open half clips with bear claws on a couple of bikes the setup seems to work fine and is a nice compromise for a street communter bike.
Bikes: 1969, 1972 and 1973 Crescent Pepita Specials
Everyone who mountain biked in the early 80's used toe clips and straps on bear paw type pedals.
Pip
Pip
Liked 1,704 Times
Power Grips are the straps that run diagonal, right?
yep, that's them ... https://www.rei.com/product/609173/po...grips-original
Bikes: Trek 600 ,1980Raleigh Competition G.S., 1986 Schwinn Passage, Facet Biotour 2000, Falcon San Remo 531,Schwinn Sierra, Sun Seeker tricycle recumbent,1985 Bianchi Squadra
Quoted: 33 Post(s)
Liked 12 Times
I've got a Schwinn Passage, and use bear traps and toeclips, it's the only thing that felt comfortable and stable on a big bike frame and size 13 shoes. I also have an older 1981 Voyageur with a similar set-up.
Other Worldly Member
Quoted: 194 Post(s)
Liked 136 Times
Well, you mean rat trap pedals aka serrated aluminum or chrome steel teeth? Rode thousands of miles (5000-7000-10,000+ ?) with Christophe toe clips and leather straps. Never had a wreck where I couldn't shed the pedal. Never heard them called "bear trap". Circa 1973-1980 on my Grand Jubilee.
Make ******* Grate Cheese Again
Bikes: 2019 KonaLibre- 2003 Litespeed Vortex -2016 Intense Spider Factory Build -2008 Wilier Mortorolio- Specialized Stumpjumper Hardtail converted to bafang 750 mid drive -1986 Paramount 2014 - --- Pivot Mach 429c
Quoted: 43 Post(s)
Liked 15 Times
Liked 1,704 Times
Quoted: 194 Post(s)
Liked 136 Times
Ah...I wondered. Same principle, different design. Having grown up with clips & straps, very comfortable to use with one exception. My right foot was susceptible to nerve issues if I got the strap a tad to tight on that side. Don't see why the clip wouldn't bolt up, might have to bend the clip to the curve or shim it. The inside to outside strap position will require some fiddling as it looks to have four possible positions, two of which are diagonal.
Quoted: 5232 Post(s)
Liked 3,600 Times
I'm a 1/2 clipper, no straps
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 677 Post(s)
Liked 427 Times
I had those same pedals on my 1984 Univega Alpina Ultima and used them with Specialized MTB toe clips (cutting edge tech in 1984) and Campagnolo straps (so I could go extra fast). When I restored the bike last year after collecting dust and rust for 25 years, the clips and straps were brittle, but I found a pair of strapless toe clips (Delta, I think) that worked fine.
That said, as I rode it more, I ended up swapping the pedals and clips for an SPD setup.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Liked 3,600 Times
those are nice!
Liked 1,704 Times
I replaced pedals on a bike- tried the old clips on the pedals, and I needed a washer- so I was just going without until I get a new set of clips. I did a ride the other night on that bike- and I realized how much I depend on having my foot affixed to the pedal. Especially at stops- getting the pedal in position to start up.
Someday I may go to clipless, but for now I'm happy with clips and straps (and not having to have special shoes and such)
As far as the porpoise for the thread- I wasn't sure the rounded edge would work well with the clips. I've found that I really like ATB type pedals with clips, and don't like the quill style pedals with or without clips. I feel as if the larger area of the bear trap style pedal may distribute the weight/force over a larger area of the sole of my shoe.
Bikes: 1982 Torker BMX, 1990 Cannondale Black Lightning, 1996 Cannondale F400
Originally made by Titron (in titanimum), Hutch made these pedals the 'must have' accessory of the era.
Liked 1,704 Times
I just got my cages in the mail- so I just bend the bottom part of the cage to match the arc of the pedal cage?
Liked 3,600 Times
Liked 1,704 Times
What I was talking about- the surface of the pedal that the clip attaches to is rounded instead of flat. I had to bend the mounting surface of the clip to match the arc of the pedal cage.
I had to take them off last night. WICKED toe overlap. Because the pedal is already larger (from front to back) than an ordinary pedal- the forward extension of the clip REALLY limited the range the wheel could turn. I seriously could not turn out of the driveway while pedaling.
This is on a a 1986 Voyageur.
Liked 10 Times
Back then they made small cage attachments that took up the space so you cage mounted properly on the Suntour XC Pro pedals. The XC Pro pedals were all I ran, I'm sure I still have some of those attachments, I'll look and post a photo later.
What??? Only 2 wheels?
Quoted: 1223 Post(s)
Liked 645 Times
The stoker's crank on our tandem has Avenir mtb-type pedals, black , plastic, and very purposeful-looking. They have standard Christophe-type clips w/straps. They seem to work just fine.
Real cyclists use toe clips.
jimmuller
jimmuller
Liked 1,704 Times
I'm now leaning towards Power Grips on these pedals on this bike. I really like the pedals, I just would like to have my feet secured.
