Dented chain stay help
Bikes: 1988 Specialized Rockhopper Comp, 2012 Goodrich Randoneuse, 2016 A-Train, 2022 Wilde Dream Engine, 2022 Salsa Mukluk
Quoted: 61 Post(s)
Liked 88 Times
https://sfbay.craigslist.org/nby/bik...431280694.html
hello folks,
Does the dented chain stay look bad to you? Could this be repaired and covered with a chain stay protector? Just left as is? Or avoided all together?
hello folks,
Quoted: 3814 Post(s)
Liked 3,345 Times
link generates "expired" message
Quoted: 18378 Post(s)
Liked 4,512 Times
The listing says "This posting has expired"
There are a few types of chainstay "dents". Some are normal.
Near the chainrings, there may be chainstay indents from the factory for chainring clearance. Or, perhaps put in on steel frames by the owners, These likely are inconsequential.
Likewise, they indents can be put on the tire side for tire clearance.
Also there can be some indents around the rear freewheel/cassette.
More concerning might be dents midway along the chainstays that is not mirrored on both sides. This could indicate a rear triangle alignment issue.
Also, look for deep scratches in some frame materials due to the chain getting stuck.
Quoted: 61 Post(s)
Liked 88 Times
Ok, looks like in a matter of minutes seller stopped responding and maybe sold the bike or had a change of heart.
Thanks though
Thanks though
Quoted: 61 Post(s)
Liked 88 Times
Never mind, still for sale. How does this look?
Quoted: 61 Post(s)
Liked 88 Times
Not sure if this helps see it more
Quoted: 3811 Post(s)
Liked 6,713 Times
Looks pretty minor to me from that angle.
Quoted: 964 Post(s)
Liked 1,451 Times
Agreed, would have no qualms about riding it.
Looks like a weight-weenie build, with matching red anodized aluminum aftermarket bolts and spoke nipples, and American Classic cranks. Syncros stem and White front hub, King rear. Really cool, right up my alley, probably worth the price for just the components. Probably has some Ti stuff hidden in there (BB? pedals?), that would be true to form. I never did trust those alloy crank bolts, though. Would swap out for Ti so if a crank comes loose on a ride you can just tighten it.
Seller spells Syncros wrong even though it's written on the stem. Pedals is spelled as "petals" also. Seat is not in any pics. Thief? Probably not, too earnest and sincere an ad. But reads as somewhat ignorant, or at least a person having trouble posting from a cell phone, and not taking the trouble to proofread. Kind of a lazy or half-hearted ad, if I'm being honest. That may explain the price, which seems low for something so nice. Go get it!! BUT, don't be surprised if the seller flakes on you, or if you have to conform to their schedule in order to set up a test ride!
Quoted: 61 Post(s)
Liked 88 Times
Likes For twolve:
Quoted: 3464 Post(s)
Liked 2,831 Times
While this is an oval chainstay there, I have removed similar dents from round section stays.
while the word of advice in The Graduate was plastics, my word is coupling nuts, in this case probably 5mm or 10-24? Maybe8-32
you build up a rod with them and set screws, extend it down the one nearest I used a 1/2 round slotted head fastener, tap it back and get it worked out. I used a 1/4 x1" bar to insert through the bottom bracket.be patient
Likes For repechage:
Quoted: 61 Post(s)
Liked 88 Times
Quick update before I make a proper thread someday: I bought the bike today, the dent does not look too bad and it had lots of cool extras, including a matching white industries rear wheel. The seller was a nice fellow, the original owner. He worked for bicycling
magazine when they profiled Evans and then ordered the Hedgehog Roadhog (love the name) custom from him.
Likes For twolve:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Just needs a Campy decal.
Quoted: 394 Post(s)
Liked 346 Times
Quoted: 1106 Post(s)
Liked 1,328 Times
It'd be a lot of fiddly work and sizing the rod-end to the chainstay ID could be tricky. That size dent I probably wouldn't bother with anything more than paint.
Quoted: 394 Post(s)
Liked 346 Times
Ahh, I get it. Actually, given the pieces involved, that's kind of what I was thinking, but it seemed kind of impossible. I was wondering if something like that would work on chainstay crush from a kickstand. Seems like it would take a lot of pressure to push those dents out.
Liked 2,831 Times
they are removed one at a time.
