"Look" brand clip-in pedal falling off
Old 06-24-06, 01:27 PM
wsmith
WSmith
Bikes: Trek Hybrid and Centurion LeMansRS
Please help. I'm sure this is a simple problem with a simple fix; I'm just not very mechanically-minded.
I have an old-school Centurion LeMansRS road bike I put my "Look" clip-in pedals on last night. I felt like I did a decent job torquing them tight (with pedal wrench) when I screwed them in.
However... here's my problem: This morning, my right pedal, still clipped to my shoe, slipped off the rod of the pedal every couple miles while riding. The pedal rod stayed, still screwed on to pedal. Without tools, I'd hand tighten it, go on, and it again it occurred a few more times.
Excuse my lack of knowledge but what causes this? Did I NOT torque down tight enough when screwing on the pedals? Or is it a problem in the internal part of the pedal? Any advise is appreciated.
To work around it, I would pedal backwards a dozen rotations or so every couple miles just in case.
Thanks for the help.
wsmith is offline
Old 06-24-06, 01:30 PM
mechBgon
mechBgon's Avatar
Liked 6 Times in 5 Posts
Your pedal is busted. The body of the pedal isn't supposed to come off the axle (the rod) like that, and it's almost certainly not your fault. Sounds like it might be time for some new pedals.
mechBgon is offline
Old 06-24-06, 01:45 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
I think he means the pedal with the axle detached from the crank arm. Or not. I'm confused.
operator is offline
Old 06-24-06, 01:53 PM
mechBgon
mechBgon's Avatar
Yeah, the description is a bit ambiguous. WSmith, if your pedals are like most, then they do also have a 6mm hex fitting on the threaded end of the axle, which you can use to tighten it somewhat if it's coming loose during a ride (assuming you have a 6mm hex key in your toolkit).
mechBgon is offline
Old 06-25-06, 04:17 PM
wsmith
WSmith
Thanks. I will attempt to tighten the hex and ride it a few more times as such. If it comes off in spite of that, I'll replace. Thanks for the tip(s).
wsmith is offline
