Good Quality Lights
Good Quality Lights
I am in market for some new bike lights. That I will be using for trail riding, in the winter as well. The lights I have right now were good buy around 30 dollars and do last a while but the batteries do short out now and then it seems and do have to buy new batteries every year.
Looking for something that will work well in all types of conditions as well have a long battery power. Meaning I can go riding in the bush for 4+ hours with confidence. As well the battery will last a long time. Of course easy to recharge as well.
Both good handle bar mount and helmet too.
suggestions too. thanks
What lights do you all of you use at the moment?
Quoted: 5224 Post(s)
Liked 3,581 Times
for off road I prefer a light with a wide beam pattern. I bought a new light last year, which is much brighter than what I had & it has a better beam pattern, but it's kinda narrow for off road. I have it mounted n a helmet & I like that. looking forward to using with my 1st light mounted on the bars. I guess having a narrow beam mounted on a helmet is OK, because one can turn their head & the light follows the direction of the eyes. maybe a wide beam is more important for a stationary light?
Quoted: 590 Post(s)
Liked 445 Times
I like the Cygolite Metro 800 for bar-mount, and the Cygolite Dash Pro 600 for helmet-mount.
Likes For Riveting:
I like the Fenix BC30 V2.0. It uses a pair of 18650 batteries that are easily removed from the light for charging. It's also possible to quickly swap in a fresh pair of batteries.
The beam pattern works well for me. For riding on the road in full dark, I usually use the 600 lumen mode. It includes a wireless remote switch that can be mounted on the handlebar, and that allows one to cycle through the different brightness levels. It also allows one to assert "burst mode" at maximum brightness for up to 30 seconds.
When I don't need the headlight to see, I use the high/low blinking mode to "be seen".
Fenix has a helmet mount available, but I have no personal experience using this light in that way; just on the handlebars.
Quoted: 18883 Post(s)
Liked 10,646 Times
I have a Fenix light, that thing is magic when I need it.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
https://www.outboundlighting.com/
As far as the 4 hour run time the OP is looking for....if he wants to run it on high the whole time, that will require getting a decent sized powerbank with Qualcom Quick Charge 3.0 in order to deliver the charge fast enough. Also requires that you hook the powerbank up from the start. I am looking into that, though realistically, the runtime without an external battery is fine for what I use it for.
I use a Cygolite Metro 850 on my helmet. My helmet comes with a go-pro mount attachment, and I have a Cygolite adapter for that. I like that I the light clips in and out of the mount so easily, so I can leave the light in my pack until I need it, and then it clicks in in seconds. Also works well as a bar light on my commuter bike and road bike.
Likes For Kapusta:
