Campagnolo chain tool. is it needed ????
Quoted: 211 Post(s)
Liked 199 Times
Hi,
I have a 9 speed Campy Chorus chain to be installed.
The bike shop owner said you need a special tool, a regular chain breaker tool will take it apart.......but you need to " peen" the rivet.
He has a Park tool one that does that.
Is this true **********???? Does anyone have experience doing this with a Campy 9 speed chain ???
I took the old chain off with a regular chain breaker.
Maybe I should try to put the pin back on the old chain and see what happens ???
He has the tool in his other bike shop, and will bring it to the shop I go to Thursday.
Again....appreciate any and all help
Quoted: 839 Post(s)
Liked 1,061 Times
True. Better is to just get a quick link (re-usable link) and skip the tool. KMC Missing Link 9R | For Shimano, SRAM, Campy (kmcchain.us) Sold in bike shops or on the net. Shop around for best price if that matters. Make sure the Campy nutters (most don't fit into the nutters category BTW) don't see you're using a Taiwanese chain link or you will be shunned.
Quoted: 211 Post(s)
Liked 199 Times
Will any of these fit a Campy Chorus chain **********
Then chain width is 6.8mm
Quoted: 839 Post(s)
Liked 1,061 Times
What the heck? When I looked at the link I provided I thought it said for Campy too. Not positive about that but I think it fits the Campy 9 speed. Shoot them an email to be sure or maybe another poster will chime in with an answer.
Quoted: 211 Post(s)
Liked 199 Times
ok..
It does say Campy !!!
Thanks CC !!!
I'll call them tomorrow. I sent an email just now to confirm if it will fit Campy 9 speed 6.8mm width
Thanks CC !!!
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
You'd think the shop owner would have suggested a quick link
Quoted: 2338 Post(s)
Liked 2,827 Times
IIRC it is at the 12 speed campy level that there is huge discussion on need for the tool and peening or will an unauthorized quick link work.
Quoted: 211 Post(s)
Liked 199 Times
Not sure sqirtdad
i like the idea of a quick link....kmc calls it "missing link"
I'll let all know as soon as I hear from kmc.
Thanks again for all the replies
Really appreciate it
Quoted: 569 Post(s)
Liked 584 Times
While I and others have never had an issue with Missing Link this is what KNC says:
IS KMC MISSING LINK COMPATIBLE WITH SHIMANO CHAIN, SRAM CHAIN, OR CAMPY CHAIN?
Yes, KMC constructs Missing Link I, II, 9, and 10 for 7.3mm, 7.1mm, 6.6mm, and 5.9mm respectively; all Missing Links are compatible with Sram, Shimano, and Campy equivalent chains.
Quoted: 2026 Post(s)
Liked 1,096 Times
Likes For HillRider:
Quoted: 839 Post(s)
Liked 1,061 Times
Liked 1,096 Times
On Ebay they're practically giving them away. Campagnolo 11 and 12 Speed Chain Tool Install HD-Links UT-CN300 8033148858952 | eBay
Quoted: 569 Post(s)
Liked 584 Times
Full disclosure on my last order from Chain Reaction I bought a few Wippermann to try and like them, no tools needed to install or remove, re-usable and $4.50.
There's really no reason to use only a Campy chain. There should be plenty of others with quick links available. A properly fit quick link will have .1-.2mm of clearance between the inner links and the outer links. Less is too tight and more is a sloppy fit.
Quoted: 4236 Post(s)
Liked 2,949 Times
I know chains are hard to come by at the moment, but just get a KMC X9 chain (or heck, an X10 will work if that's easier to find) with its reusable link and put that on by hand. Sell the Campagnolo chain to someone else who must have a full on match. I mean I've been known to remove a perfectly working Shimano DA or 600 (well both on different bikes actually) headset to replace it with a record headset on a bike that was all Campagnolo (and once replaced a no name seatpost binder bolt with a Campagnolo one - regret that as the Campagnolo ones break so much more easily), but I'm not about to be bothered with making sure my chains match the groupset.
As other have said, it is required, IF you put it back together with a pin (Although I have put mine back together with my park CT-5 and it hasn't come apart yet).
Most of us get a connex link or some other master link (I have 3 KMC's in package) and as long as you don't short the chain when new, you never need to peen that rivet so you never need that tool.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Quoted: 211 Post(s)
Liked 199 Times
Thank you for all the great knowledge!!!
Really appreciate your help and time
I did speak with KMC
They assured there 9 speed "missing link" will fit my campy chorus 9 speed 6.8 mm chain
Ordered 2 today.
Be here next week sometime
Hope it works 🚲🙂🙂🚲🚲🚲🚲🚲🚲🚲🚲
Ordered 2 today.
