Carbon seatpost in aluminium frame?
I am thinking about replacing my current 400mm alloy seatpost (who the hell would need it that long?!) to make my bike a bit lighter. Current stick is about 310 grams. I was checking for the options and found some alumunium seatposts around 220g with a reasonable price. If i can save 90 grams that would be good. However i wonder if a carbon seatpost would be a wiser choice considering it might help for a more comfortable ride. Though, i am not sure it is a good idea to clamp this gentle material within an aluminium frame. I think it will be broken or be crushed under the pressure. What would you recommend?
Thomson Elite, ~$100 (or Masterpiece, ~$140).
Alloy and lighter than most carbon seat posts. They look awesome, too.
/thread
edit: also, ffs people, carbon is not a 'gentle material'...
/thread
I have the S-works SL Pavé seatpost. Weight is about 200 grams, has a zertz insert and the cool one bolt fastening system.
First: My first S-works, Wohoo!
second: It's light. Okay the thomson elite masterpiece is even lighter, but also, looks
third: I can understand how someone might not like the one bolt system (I didn't) but now that I'm used to it, it makes adjusting so much easier and faster.
fourth: Not sure if the zetrz insert does anything, but it's a cool little gizmo. I suppose it helps with a little bit of vibration
You have to be skilled to break carbon, but overtightening will do it. I use pretty minimal force and toothpaste to keep the seatpost in place.
Would not go back to alloy
Lightest alu post i found is this Ritchey. I will invest my money on this:
https://www.evanscycles.com/products/...29872#features
Bikes: something
It may seem like a sham but really your best bet is carbon friction paste, reduces the amount of clamping force needed aswell.
Super Moderator
Liked 1,013 Times
While I have never heard of this and have never seen this done I CANNOT recommend this as a mechanic. I have seen carbon seatposts seize inside of aluminum frames before and toothpaste strikes me as being a perfect glue since it's primary solvent/ carrier is water and it normally contains many other types of minerals and electrolytes that will just act as bonding agents once the carrier fluid dries out.
So far the toothpaste has worked really well for the past two years. No seizing, adjustment is always easy, no hassle. At some point I'm thinking of turning the frame upside down, washing the old stuff away with a bottle brush and applying new paste. Then again so far the old stuff has kept elastic and easy to handle so maybe not.
Trick is to use the cheap foamy white stuff, NOT the gel. I can really understand how a gel might jam the post, but the white stuff works wondrously well.
don't try this at home.
My original carbon seat post was pitted and had white aluminum corrosion dust after a few years. I just cleaned it off an kept using it (until the saddle clamp quit working) It would be good to pull a carbon post on an aluminum bike once a year for inspection.
The consensus on BF is that carbon posts don't make enough difference on soaking up vibrations to notice.
Liked 58 Times
When aluminum/carbon interfaces on bikes were "new", there was some thought about electrolytic reactions causing sacrificial failure of the aluminum especially in the presence of electrolyte rich perspiration. What ever happened to that concern? It doesn't seem to be considered much at present.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
I've successfully used tubing cutters to remove excess material from an overly long seat post. You can too. Or you could waste your money on a replacement.
pan y agua
Liked 894 Times
Lightest alu post i found is this Ritchey. I will spend my money on this:
Definitely not an investment. It's an expenditure, and a rather questionable one at that.
Once you cut your current seatpost to length, you might be saving 25 grams.
You could get lost and die.
You could hit a tree and die.
Bikes: Helix, HonkyTonk, NailTrail
Turn the seatclamp so that the stress relief in the frame (some have it front, some rear, some side), doesn't line up with the same seam where the tightning bolt is. Some small change to create a stress riser.
It's hard to beat the Ritchey WCS parts. One bolt is nice and easy also. Get a torque wrench if you go carbon. The 0 set back ones are super stiff, none stiffer out there, al or carbon.
Super Moderator
Liked 1,013 Times
As long as it doesn't sieze up like mine
Bikes: something
Carbon friction paste didn't work. Or it might have, but that would have meant using a lot more torque than I was ready to apply.
In finland it's sold as pepsodent xylitol. Green tube
