Stand light stopped working
Good day all.
I have a SON 28 dyno driving a Supernova E3 Pro 2 up front and TL-2 in back.
I noticed recently my stand light stopped working. I believe the capacitor that drives that feature is in the E3 up front. There doesn't appear to be a way to open that light up to service anything - at least to my non-expert eyes. Does anyone have any expertise here? It's a pretty minor annoyance, but if I can solve it, I'd like to.
Is this light serviceable in any way?
Thanks for any info.
Quoted: 6195 Post(s)
Liked 4,810 Times
Usually if the manufacturer considers things user serviceable then they will be in the user manual which many manufacturer's expect you to download from their website to save on printing costs for things most people will throw away. Otherwise it's up to your DIY skills and adversity to the risk of making it totally and irreparably useless.
Likes For Iride01:
Quoted: 3461 Post(s)
Liked 1,466 Times
Is it still under warranty? If so, contact Peter White. And if not, contact them anyway to see if they do repairs.
His website says you can't mix Supernova with other brands, but can with a Schmidt. If it was me, I would ask Peter White if I could use a B&M taillight with it since B&M taillights have their own standlight and are not that expensive.
Good luck.
Good luck.
Likes For Tourist in MSN:
Quoted: 1829 Post(s)
Liked 3,376 Times
I'm not familiar with the various versions of the Supernova E3, but a few years ago, I did fix a fellow's E3 Triple that had been connected to a battery and blew up just about everything. The front and rear portions unscrewed from the center of the body.... which is not really a surprise.
The supercap that powers the standlight was on one of the two circuit boards that were accessible by removing the rear portion of the housing.
Steve in Peoria
Steve in Peoria
Good luck.
Good luck.
Liked 1,466 Times
His website says you can't use any taillight that is not a Schmidt or Supernova on a Supernova headlight, But it says that is because the Supernova is DC (direct current) and lights that use AC (alternating current) won't work. But I have tested a B&M taillight with a DC power source (a Li Ion battery from my phone), so I know that lower voltage DC is not a problem for B&M taillights. I have also used the phone battery to test a Spaninga Pixeo taillight, so that will work on DC too.
If you try a B&M or Spaninga light and if the stand light on the tail light does not work, reverse the wires to the tail light, as it is possible that polarity might matter for the standlight on a B&M or Spaninga.
Good luck.
Liked 3,376 Times
However, the tricky detail is that the voltage across the taillight is also used to regulate the charging of the super capacitor (a.k.a. "supercap") that powers the standlight function. While I can't think of a way that some generic dynamo taillight might interfere with the supercap charging, I'm not sure that it might not be possible. The supercap in the Supernova that I fixed was rated for 5.5V, and appears to rely on the voltage drop across a diode to limit the charging of the supercap to 5.5V. I'm not sure that it really did a good job of that, since once the current through the diode decreased, the voltage drop across it would decrease too, resulting in charging the supercap to a higher voltage.
Anyway... it's hard to recommend that anyone ignore Supernova's advice to only use their taillight, despite not seeing a real problem with it. In fact, since most dynamo taillights have to include a full wave bridge rectifier and some sort of current limiting, there's less voltage available for powering LEDs. As such, the Supernova taillight should be able to produce more light.
Steve in Peoria
