3D Printed Accessories / Mounts
#726
Ride it like you stole it
Update 2:
Got the adapter back from Shapeways and there is an issue with the angle. I believe I know why Garmin designed it this way, even if I think it is excessive. I also know that the two screw posts that hold it together are parallel to the face but I don't want to design a hunk of plastic that just makes it a simple adapter. More plastic, more cost, more weight. It has to be good looking too! (relatively speaking)
I have another sub-section being printed by Shapeways, will see how that works.
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
#727
Anyone looking for a mount for the MY22 Specialized Allez Sprint, the SL7 varia mount fits and here is a picture to prove it.
#728
Update: I have modeled an adapter to the disassembled RCT715 mount. I think in its current state I will likely only do mounts for the Shimano Pro Saddles and Specialized SWAT equipped saddles as well as the Trek under saddle integrated mount and the Bontrager Blendr mounting system. It is just big and bulky and the mounting holes are in an awkward spot to make it a clean model for all the different seat posts out there (unless I go back to the two bolt clamp design).
#729
My first test piece did not fit correctly. The second just shipped today to me from Shapeways. I will try my best to have solid mounting options by July 8th.
#730
Garmin RCT715 Mount Adapters
I now have a few mounts for the new Garmin Varia Camera, the RCT715. Because of the awkward size and angles of the mount for this new Garmin device, I am only offering a few mounts at the moment (all integrated saddle mounts). Please do not expect any seat post mounts at this particular time.
The three offerings are:
Specialized SWAT Garmin RCT715 Mount Adapter
Bontrager Blender RCT715 Mount Adapter
Trek Integrated Saddle Mount Varia RCT715 Adapter
Here are some guidelines on how to use the mount adapters:
I will try to add pictures in the future unless one of you guys do it before I do.
- Remove the two Torx (Star) screws from the back side of Garmin's supplied mount using a T9 Torx (Star) bit or T9 Torx (Star) driver. Save these screws as they will be reused. Do not lose them, they are small.
- Separate the back from the front of the Garmin mount and set aside the rear portion, we no longer need this section of the mount.
- Attach the new compatible adapter module onto the back side of the remaining section of the RCT715 mount and secure with the two screws you set aside earlier.
- Attach the newly completed mount onto your saddle with two M-5 (5 mm) x 10 mm pan head socket screws or slide into place in the case of the Trek Integrated Seat Post Mount.
- You can use this arrangement exactly like the original Garmin RCT715 mount.
#732
Quoted: 1277 Post(s)
Liked 1,392 Times
WheresWaldo .. have you ever considered a combined seatpost clamp / garmin mount? it would obviously need a little arm reaching up a bit for a device like the varia, and perhaps it would sit a tiny bit low, but it would be so clean! imagine that allez clamp flipped around, with the garmin mount projecting up from the closed/smooth side?
obviously it would have to be printed in aluminum or another metal, which is obviously expensive.
#733
Just to give some example cost comparisons, if a nylon part costs $ X, a polished nylon part is usually $ 2X, an aluminum print of the same part is usually $ 5X - $ 8X, other metals costing more. I designed a computer case badge that was offered in 14K Gold, it turned out to be about 120X the cost of the same part in nylon plastic.
#734
Liked 1,392 Times
Too expensive, Almost anything 3D Printed in metal of any kind is cost prohibitive and should only be used in prototyping designs. There are much cheaper ways to accomplish the same thing. The issue with someone like myself doing this, is that the production is of insufficient quantities to have any savings that come with scale. Then on top of that you have bike manufacturers that believe their aero design profiles are better than everyone else's, so you have a different seat post clamp for almost every bike on the market. Longing for the days of old where all posts were round only helps a little as their are so many different sized round posts. Volumes need to be in orders of magnitude larger than anything I do, to make it a worthwhile venture. Even as a design exercise it is time spent that can never be recouped.
#735
definitely not cost-effective. but a fun project for sure, assuming 3d printed aluminum would actually be strong enough for the task around the fastener and post. obviously it would be best to print it with the layers horizontal in "plan" around the post. do you think a 3d printed aluminum part that was thin enough to flex enough to clamp the post would also be strong enough?
#736
BMC Teammachine
Hi Guys,
I have the BMC Teammachine, but unfortunately I am from Europe.. so ordering such a part in times like these is about hard and shipping expensive…
Does anybody have a file, he could share for a Garmin Varia Mount?
Doesn‘t need to be the latest and best. At least having the digital seatpost profile would help a lot and I could play around…
Thanks a lot
Paul
Thanks a lot
Paul
#737
Going to play around a bit with a redesigned clamp to accommodate the new Varia RCT715. Don't actually know if it is going to work, but I have a few ideas. May have a lead on a cut off from a Pinarello Dogma F (non-number series).
#738
Finally! https://shpws.me/TcWA
This is the Garmin Varia seat post mount for the Pinarello Dogma F (without the number). It took a while but it is finally available.
And, here is my first RCT715 Seat Post Mount Adapter, https://shpws.me/TcYx
It is specifically for the Pinarello Dogma F and provides a secure mount that is not the bulky rubber spacers and O-rings that Garmin provides in the box.
#739
Here is an image of the RCT715 mounted on the Trek Integrated Saddle Light Mount
#740
RCT715 Specialized Seat Post Mount Adapter
Specialized SL7 Seat Post Mount Adapter for the Garmin Varia RCT715 is now available. It is the first of it's kind and currently the only aftermarket solid mounting option for the RCT715, https://shpws.me/TdNN
#741
Two more RCT715 mount adapters
https://shpws.me/Te9T - Specialized Venge MY12-17 RCT715 Mount Adapter
https://shpws.me/Te2C - Specialized SL6 Varia RCT715 Mount Adapter
#742
A very nice LOOK 795 owner sent me a small cut off from the bottom of their seat post I now have a Garmin RCT715 Adapter and Garmin Varia mount for this bicycle series. Based on MY22 and may fit others.
https://shpws.me/TevT - Look 795 RS MY22 Garmin RCT715 Mount Adapter
https://shpws.me/TevS - Look 795 RS MY22 Garmin Varia Mount
You guys and gals heard it here first.
https://www.shapeways.com/product/ER...in-varia-mount
https://www.shapeways.com/product/5N...-mount-adapter
#743
Just because someone asked me nice, here is a saddle rail version of the RCT715 mount adapter, https://shpws.me/Texf
https://www.shapeways.com/product/G26BAFRN6/garmin-rct715-saddle-rail-mount-adapter
#744
Threw this together for someone wanting to use a manufacturer supplied reflector mounting strap. It replaces the reflector with a Garmin Varia mount, https://shpws.me/TeIX
https://www.shapeways.com/product/SA7EWNEW3/varia-reflector-mount-adapter
#745
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Links aren't working for me.
Keep the chain tight!
#746
Stuff to do around the house but, had some time to get this one done. Varia (not the RCT715) mount for the Factor OSTRO VAM MY22
https://shpws.me/Tf6x
https://www.shapeways.com/product/CFBATX7W7/factor-ostro-vam-my22-varia-mount
#747
Hmm...
I will send an email to Shapeways support and report it. Their site is code is pretty crappy like something from the WEB 1.0 days. I added the direct URL to the last few posts.
#748
The shortened links appear to work in Microsoft Edge. I tried clearing the cookies on my system and it changed nothing in Chrome.
#749
Hi Guys,
Thanks a lot
Paul
Thanks a lot
Paul
any news ? Thanks so much.
Paul
#750
Holiday promotion
Sent out by Shapeways today; Customers who spend $125 at my shop, will receive free shipping (including international), throughout the promotional period. You can enter MADBIKEFREESHIP at checkout for free shipping from now until December 31st. Terms and conditions apply*.
We are also featured in the Holiday Shopping Guide
We are one of the storefronts featured in the guide.
*This free standard shipping promotion is valid through midnight ET on December 31, 2022. This offer includes a coupon code for unlimited uses within the promotional period. The coupon code cannot be combined with any other offer. The coupon code is void if altered, copied, transferred, auctioned, or sold. This offer is valid for items within your specific shop and not valid on prior purchases. This promotion is subject to change without notice.
FYI: None of us in the Shapeways Marketplace are Shapeways employees, we have no prior knowledge of any promotions Shapeways chooses to run. I did not know about this until a few minutes ago.
