Tire Width Clincher vs Tubeless
Bikes: Dave Kirk Custom, Clockwork Bikes Custom, Batavus Course Specialized HardRock x2 Trek 700 MultiTrack 1991 Trek 950 SingleTrack. Miyata Three Ten
Hi,
I have a set of 21mm internal width rims, have ridden them for about a year with Conti 5000 25mm clinchers. I measured the tire width with calipers at 29mm installed. I replaced those tires with Conti 5000 28 TR tubeless ready tires, but with tubes. I measured those at 29mm installed. Would that make sense that both tires are measuring at the same width?
Thanks!
Jon
Thanks!
Jon
Expired Member
If you know how to use a caliper (joke- some here don't) and you measure both tires at appropriate PSI, then it is what it is.
![Thumbs Up](images/smilies/thumb.gif)
Likes For shelbyfv:
I trust the caliper, just trying to understand why no increase in width, if it's something between clinchers and tubeless. In other words, how did I gain anything if the tires have the same width and height? Maybe the rubber is just thicker.
Expired Member
Your pre-tubeless 5000 measured larger than nominal. That was my experience as well. The TLR is a different tire and apparently measures closer to nominal. Maybe others can report their experience but I think you are correct to attribute it to different construction.
Likes For shelbyfv:
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Liked 261 Times
If you’re not going tubeless, you gained weight, since the 5000 tubeless weigh around 50 grams more than the tubed version. I’ve read the tubeless versions have thicker stronger sidewalls, which makes sense to me, give there’s no tube to help provide sidewall support.
Liked 4,996 Times
How much tire pressure did you have each filled to when you measured? You also might ride the current ones for a year and measure again.
Probably a bunch of little things all adding up to make the results you see.
Hi,
Thanks!
Jon
Thanks!
Jon
Likes For PeteHski:
Liked 2,203 Times
Likes For Steve B.:
When Conti introduced the 5000S TR they also shrunk them to measure close to their nominal size when mounted on modern wider rims. The older 5000 was sized for narrower rims, so they would measure over-size on wider rims like yours. The older 25 mm tyres would measure true to size on narrow rims.
Liked 2,203 Times
Liked 4,996 Times
Abrasion on the sidewalls might be you run them with insufficient tire pressure.
However for a 21mm internal width rim, a 25mm tire is about as narrow a tire you should put on that rim. A tire that is too narrow for the rim it's on is probably more of a issue than a tire that is too wide for a rim.
It's certainly been a journey with these new wider rims. The rims are hooked and they state max pressure 75psi for my weight. At that pressure, with 25mm tires, I immediately got pinch flats, like 6 in three months. So I started upping the pressure eventually landing on 85 front, 90 rear, which seemed to stop the pinch flats, but now I'm going more than what the rim says I should, and closer to what I was running on narrow rims.
So moving up to 28 should also in theory have alleviated the problem, larger tire and lower pressure. However now that I install the tire, it's the same width and height as what the 25 was, so either I need to run these at the same pressure, or maybe hopefully they are just more durable since they are not expanding beyond their intended width. At any rate, the silca calculator says I should be able to run them in the 60s, but I just can't see that happening, even tubeless. If tubeless will let me get that low, then I'll switch!
Liked 3,014 Times
byrd48 What's the difference between "clincher" and "tubeless"? Aren't they both clincher - one being used with a tube, one without? It's not like one is a clincher and the other a tubular aka sewup. Or am I missing something?
tires designed for tubeless have stiffer sidewalls in general and the tires designed for tubes are generally lighter
If you plan on only using tubes there is no need to go to the tubeless ready (but you can use those with tubes)
https://www.continental-tires.com/pr...tem-ccb0832fbc
https://www.continental-tires.com/pr...pingDTacs=Road
Life is too short not to ride the best bike you have, as much as you can.
Liked 3,014 Times
Liked 4,996 Times
So I've quit making that assertion. Even though to me the tire is physically pretty much the same. And many bicycle tire brands seem to use clincher to only refer to tires with tubes.
Liked 4,996 Times
What rims do you have?
The rims say they have a max pressure of 75psi? Or are you getting this from some calculator that is only recommending what your PSI should be?
EDIT.... Not really necessary for me to know. I later found this other post that shows me some rims now put a max PSI on them for various tires. I hadn't ever seen that myself till now.
https://www.bikeforums.net/23237853-post5.html
A tubeless tire should let you go lower since the sidewall and carcass is more robust while not having issues with pinch flats or other things. You could also do the opposite of "supple" tires and get gatorskins/marathons or whatever thick casing/durable tire+tube you can find and run it at lower psi.
All I can say is either the hoop stress is too high with bigger tires at certain PSI, or companies are protecting themselves excessively and thus recommending low pressures. BITD my parents knew people running 150+psi on 21's. Or our rims magically turned into ****** aluminum, but I doubt that.
