Hood replacement question
Old 09-14-21, 12:27 AM
Richard8655
Bikes: 2007 & 2008 Specialized Tricross Comp
Quoted: 35 Post(s)
2007 Specialized Tricross Comp here needing new hoods. Is there any way to replace the hoods without removing the shift cables at the lever? The shift cables are outside connecting to the levers at the sides, rather than routed under the bar tape. Doesn't seem possible but thought I'd ask.
Richard8655 is offline
Old 09-14-21, 07:04 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
You could push out the lever's pivot pin and pull the brake lever and shifter assembly off of the base, then remove the hood and replace it. Reinstall the lever/shift assembly. Note that Shimano STIs have a set screw under the lever that retains the pivot pin so it has to be removed first.
Alternatively, loosen the entire lever assembly' clamp screw and pull the entire lever away from the bar's clamp band. Then peel the hood off toward the back of the assembly and replace with the new one.
HillRider is offline
Likes For HillRider:
Old 09-14-21, 07:13 AM
Richard8655
Quoted: 35 Post(s)
Thanks much! Will take a look at those options.
