GRX RD-RX812 compatibility with 2x
Bikes: 2021 Kona Rove AL 650; 2021 Felt Breed 30; 2018 Cannondale CAAD 12
According to Shimano, my GRX RD, (RX812) is only compatible with a 1x setup - max 11-42T / min 11/40T.
Has anyone had any experience or knowledge of use this RD with a 2x setup? I'm seriously considering it or trying a larger chainring to avoid spinning out on tarmac using my gravel bike.
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 223 Post(s)
Liked 372 Times
I’m pretty sure we have a Look gravel bike with a GRX 800 of some type in the shop with a 2 by crankset I’ll check tomorrow.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1301 Post(s)
Liked 744 Times
Shimano also states that it''s specifically engineered for a 1x with a 11/40-42 Cassette.... chances are that you would run into the Max Wrap not being sufficient.... 31 teeth difference specified.... the location of the upper roller in relation to the pivot point plays into that spec.
Resident PIA
Quoted: 223 Post(s)
Liked 372 Times
Just checked the spec, it’s a GRX 810.
Shad
67'er
Shad
67'er
Quoted: 553 Post(s)
Liked 485 Times
The other and possibly more correct solutions for this:
Increase your cadence.
Drag the back brake.
Quoted: 2375 Post(s)
Liked 2,904 Times
You could retain the current chainring size for the inner ring, and add a 10 tooth larger one for overdrive - just be sure not to use the two largest sprockets with the large chainring, otherwise crunch.
bottom line grx812 is not for 2x...... anything you do will be a hack and not shift well
Quoted: 553 Post(s)
Liked 485 Times
I don't see that there would be a problem with shifting as long as you avoided the evil sprockets of doom. Am I missing something?
Liked 2,904 Times
It could just refuse to shift and break nothing (including rider). It could break the frame, destroy the wheel and put the rider under a bus. Rider awareness would be a major factor in the outcome.
never setup where you can't do big/big
as to shifting in general, no hands on but plenty of other discussion about 1x rear being opimized for 1x and big sprockets.... pulleys etc. and in general experience of trying to make things work..... nothing work as well when used in a non designed for situation
