Rad Rover Brakes rub when turning
Hi Guys! I have a new Rad Rover that I just put on 115 miles on. The bike seemed nicely tuned and set up when I received it. Recently overt he past 15 miles I get a loud squeaking/rubbing sound on the right tire when turning to the right. If I p[ump the front disc brakes several times the noise seems to cease until I turn right in a fairly loose turn. I adjusted the brakes several times but that doesn't seem to help - It doesn't squeak or rub when riding straight or turning left. All the spokes seem similarly tight although I haven't tested the numbers with a tension meter. I haven't gone off road or deformed the rim at all so not sure what's up.
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Bikes: 2022 Priority Coast, 2022 Priority Current
Quoted: 175 Post(s)
Liked 137 Times
Any chance that you didn't remount the tire and tighten it at 90 Degree angle, tire running perpendicular to the ground?
Quoted: 883 Post(s)
Liked 823 Times
Can't imagine it happening with that beefy frame, but on some flimsy bikes the fork could distort enough to allow rubbing; doubt it but was the brake cable moved so it pulls when you turn?
