Would You Ride Tires You Can't Remove on the Road?
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
If you are satisfied you've given it a good try, move on to a different tire. I wouldn't ride a combo I couldn't fix on the road. IMO, nobody should but here on BF we've had bizarre discussions about even that.
Likes For shelbyfv:
Quoted: 20810 Post(s)
Liked 9,456 Times
Stand the wheel in front of you, use your upper body weight and grip/twist the tire carcass away from you, one hand at a time, like you're rolling up a newspaper. The bead closest to you will pull away, in to the middle of the rim bed. If it doesn't break within a 5-10 seconds, try breaking it at a different spot.
Likes For WhyFi:
Quoted: 5224 Post(s)
Liked 3,584 Times
omg this gets worse. so vice grips & bench vice? what, no flat head screw drivers? but seriously, no I wouldn't ride on tires I couldn't remove roasdside. but now the question is, what tires to get
No.
Liked 9,456 Times
Likes For WhyFi:
Bikes: 2023 S-Works Tarmac SL7 Dura-Ace Di2, 2022 Cervelo Caledonia-5 SRAM Rival etap AXS, 2019 Specialized Sirrus Elite Alloy, 1977 Schwinn Super LeTour 12.2, 85 Bianchi Limited Shimano New 600EX
Quoted: 25 Post(s)
Liked 50 Times
I picked up a 2022 Caledonia-5 in August with the same tires and DT Swiss 1800 wheels. After 3 flats from in the first few hundred miles, I converted to tubeless. I didn't have any problems breaking the bead while replacing tubes.
I had no problems breaking the bead when I removed the tube and installed the (included with bike) tubeless valves. It was fun watching sealant spew out of the holes as I inflated the tires after conversion. All holes sealed within seconds.
In the past three weeks and 500-600 miles, I would have had four more flats. All but one sealed almost immediately. I picked up a nail that took about a minute to seal as it spewed sealant all over my bike. I aired up and continued on. I carry a tube just in case, but I just added a bacon strip repair kit for some more insurance.
I'm now a big fan of tubeless tires.
Not sure what it is about these Vittoria Rubinos. I put over 4000 miles riding my Specialized Sirrus hybrid the same routes I ride now and only had swap tubes a couple times.
Likes For Bici Veloce:
Likes For argulator:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I guessed this before I opened the thread.
I have a pair of graphenes on a bike that were the hardest tires to (un)mount of any I have ever encountered (with the exception of the time I blew one off the rim). My hands ached for days after. I live in fear of getting a flat, so my rides on this have all been within six miles of home (which will be bad enough) and out of cell phone range. The tires are almost new as a consequence.
If yours have 1500 miles on them, declare victory, saw them off, and replace with Rene Herse (widest you can cram into your frame and fork). They are tight but not insanely so.
For tubeless, if they go on too easily, they come off too easily.
Quoted: 383 Post(s)
Liked 690 Times
Keep practicing taking the tires off and reinstalling them in the comfort of your living room until it is second-nature. Then they won't phase you when you flat in the rain.
I don't ride any tires on the road that I couldn't dismount by hand. A lot of people wouldn't believe theirs could be, until I show them. I guess that's my party trick.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2584 Post(s)
Liked 5,642 Times
Had a new bike several years ago which came with Vittoria 23C tires. Rode many miles with zero flats so took it on a century and 25 miles from the finish a rear flat. Took 10 minutes of prying to get that tough sucker off. Put in a new tube and the tire was so tight, it was impossible to do it without tire levers. Inflated it and pinched the tube with the levers. Another struggle to get the tire off and patched the tube. Still couldn’t get the tire back on with out the levers and you guessed it, pinched it again - another hole. Off the tire came and 45 minutes later with more cursing and struggling, back on the road with zero patches left.
When I got home the tires came off and into the garbage. The new tires were never a problem. My recommendation is get rid of your problematic tires so you never have to suffer like I did.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Picked up a Cervelo Caledonia-5, which has almost new tubeless-ready Reserve wheels and Vittoria Rubino pro tires, which currently have tubes in them. Problem is the tires are nearly impossible to get off the rim. Nearly impossible unless you have a bench vise handy, then it's just really difficult. Roadside, not a chance.
I could set them up tubeless, but am still leery of not being able to get a tube in them roadside, if needed. Should I just toss them, or would you ride with them tubeless?
Quoted: 18378 Post(s)
Liked 4,512 Times
I tend to avoid the "tubeless" rims. But, even with those that were tubeless, I don't think I've ever had troubles breaking the bead.
I've broken car beads with a hand operated bead breaker (as well as pneumatic).
Perhaps one could design a bead tool.
I'm envisioning something like a large spoon, but built tough that would have a contour along the rim, and a handle you could push with a long of weight down and into the rim.
The trick with the bead breaker is to not push straight down, but to try to dig in a bit behind the rim.
Quoted: 2432 Post(s)
Liked 638 Times
One reason why I've never considered tubeless compatible road tires is because of all the horror stories about how tight they are and that would suck trying to install a tube on the road if I had to. But then I thought about the fact that the open tubular clinchers I ride are very tight brand new but they do stretch out over a few rides like regular tubulars. So now I'm actually considering a tubeless compatible open tubular like the 350 tpi Veloflex Corsa Race TLR. Running those with no tubes would be a super smooth ride.
Last year I bought a new MTB and when I converted them to tubeless is was a freaking nightmare because they were so tight. But because I had to remove/reinstall them so many times due to other problems (getting a good seal) I noticed they stretched out and became easier to mount. If I have to put in a tube on the trail it wouldn't be a problem. I assume road tires are the same.
Just noticed how many times I typed tube and tubular and tubeless, sorry
Walking home is not!
calling someone to pickup is not practical if where you ride has spotty cell coverage.
No, I personally would not ride one like that. But on the other hand, I frequently see riders walking on their cleats miles from town, or sitting at the dirt waiting for their ride.... So needless to say others are willing to accept that risk.
Likes For atnyc:
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
If no, just get a set of non TL clincher tires of some sort. That should solve your tire removal problems.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
Last Friday after a buddy replaced his tube, he couldn't get his tire back on, even using that tire jack contraption.
He ended up making the call of shame. Personally I wouldn't ride a tire like that.
Quoted: 581 Post(s)
Liked 921 Times
I had a SS conversion built for my wife that had Ritchey WCS tires on WTB rims. The tires were an impossibly tight fit, I think they may have been 'factory seconds'. I broke multiple tire levers trying to get them on (I normally do not use tire levers to install but these were a special case).
THis bike was regularly used, but one day was left in the front yard unlocked, and was stolen.
A few years later (~10) a friend was driving down a country road and spotted the bike left out for the garbage truck and he picked it up and returned it to me The only problem with the bike as far as I could tell was that it had a puncture in the rear tube. I suspect the then 'owner' (thief?) wasn't able to get the tire off to fix the flat so decided to junk it.
Likes For ClydeClydeson:
Learn how to do the job.
Rubinos and Marathon Plus are for masochists. If you aren’t, don’t use those tires.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If the tire isn't completely flat to start with, I will give the wheel a "bear hug" while holding the valve open, to squeeze out as much air as possible -- I don't want to fight any residual air when trying to move the beads around. Then I pick a place on the wheel and grab onto the tire with my fingertips, and pull the sidewall that's facing away from me backward toward the center well of the rim. Since I'm not trying to pry anything up, just slide the bead laterally, I should be able to move it at least a little bit. Maybe if it's really tight you might have to work your way around the wheel more than once, scootching it a little bit at a time before you can get it all into the center. Once both beads are loose, I will stand up the wheel on my foot, pinch the tire between two fingers of each hand at the top and slide my hands down to the other end of the wheel. This forces the beads into the center well all the way around the wheel, and since I'm continuing to hold tension on the tire, they can't pop back out. Once my hands are at the bottom of the wheel, I can use one hand to maintain that tension while I flip the bottom of the wheel up. With the free hand holding the wheel near the rim for support, I'll take the slack bit of tire in my hand and push sideways to shove it over the sidewall of the rim. I'm pushing on the tire, so that it will pull the bead over the rim. (Those "bead jack" tools do a similar thing, pushing the bead laterally rather than prying it into or out of the rim.) It might be hard to get that first bit of the bead over the rim, but once it is, I use my helping hand to hold it there while I push the bit of tire right next to it over the rim, and so on.
I don't think any of this is original, and in retrospect it's easier to just do than to describe. It's certainly important with folding tires on my tubeless-compatible Pacenti SL23 wheelset, but I also have a pair of really tight Nokian snow tires that require good technique even with single-walled rims. Ditto for the cheap Sunlite tires on the Sun CR18 rims on my English 3-speed, the tall sidewalls on those rims require all the tire slack I can find!
Caveat: I haven't played with hookless rims yet. That hump in the rim bead might make it harder to break the bead (as it should!), but if no laws of physics were broken to mount the tires, we shouldn't have to break any to unmount the tires.
Likes For ThermionicScott:
Liked 3,584 Times
I can do that only with my loose summer MTB tires
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
But the most recent GP5000 was extremely hard to get that initial bead out of the rim groove. Shoving with both thumbs, or pulling from the opposite side with all four fingers. It just wouldn't get started. I couldn't fit my Pedro levers in between the sidewall and the rim either. It finally came loose in a short region, then the rest was easy. Ow, sore fingers.
Is there a tool to help pry out the first bit of the bead? I'm thinking something wide and thin, like a putty knife. With a slight hook across the end of the blade to help lever out the bead.
True. If you're unable to get the bead unseated, no tool is going to help. I will say that in years of riding tubeless, the only beads I've had trouble unseating are on fat bikes (which have extraordinarily tight beads on my rims). I've had to put the wheel on the ground and step on the sidewalls of the tires to get the bead unseated on my fatbike...
