question about loose bearing square taper bottom brackets
If I'm replacing the whole assembly, cups, cones, axle, bearings, lock rings, etc., does it matter if it's 3s, 3h, or whatever?
It seems like as long as I match the shell width and the threading and the spindle type (jis vs iso?) I'll be fine, right? I realize different spindle lengths will give me different chain lines, but that's what I'm trying to do. I'm doing a fixed gear conversion and I don't want to have to mess with re-dishing the wheel.
Thanks for any help!
Quoted: 6196 Post(s)
Liked 4,810 Times
The codes probably matter depending on what you want. Sheldon has a table that shows some of the differences between some spindles.
https://www.sheldonbrown.com/bbsize.html
As for re-dishing the wheel, I wouldn't think that your spindle will affect that. Your dishing is determined by the centerline of your bike and what ever you put on the drive side of the rear hub and the dropout spacing.
So the rear wheel choices drive the choices you need to make on the BB, not the other way. Of course the spindle length will determine in you have the correct chainline with whatever crankset you use.
Likes For cyrano138:
Liked 4,810 Times
You don't change the rear to match the front.
Did you see in Sheldon's table how the spindle number and letter affect how far the spindle sticks out from the drive side and non-drive side? That's what you have to worry about. Along with the fact that square tapers in my experience required too much trial and error to get things where you wanted. However some might look at them allowing you to more easily be able to get to where you wanted. But they must have lots of spares laying around to try for free.
Yep, that is what you need to do. If you get the wrong bb and crankset combo, then you have to change either the bb or crankset to get the chainline required to your rear cogs.
I just wanted to make sure in my original post that purchasing a different letter bb wouldn't somehow cause issues with the shell itself. I know that sounds like a dumb question but I just didn't want to screw it up.
Liked 4,810 Times
You have the right idea about it. Just don't willy nilly buy one without knowing how much sticks out to the left and right side of the bike.
The letters and numbers make a difference. So find the specs if they don't readily have them for you. While you might can live with too much sticking out the left side, it'll look funny to some of us. And too short will be and issue if the crank rubs the shell.
I got frustrated with my square tapers trying to find the perfect crank that sat at the proper chainline. I switched to a 2 piece crank and bb for my BSA threaded shell and never looked back or regretted the change. But if you are trying to keep a somewhat vintage bike somewhat period looking, then you'll have to play with it some and might have to make several swaps to get everything correct.
Surprised none have come out yet to give you a better answer than I possibly can. I admit I'm a little biased against square tapers.
All good advice though, thank you
That part is a lot easier than changing out a complete crankset.
Do you have a spoke wrench, a stack of CD Jewel cases, a table, and a metric ruler? There's your dishing tool. Sheldon can tell you how. You simply turn all the nipples on one side and then all the nipples on the other side the same amount in the opposite direction. Not hard.
In all seriousness, I do want to do more with wheels, maybe eventually even build a set, but I've played around with truing them enough now to know that, even if something is straightforward in theory, in practice it can be very difficulty to do even small jobs.
If I didn't already have to replace the cranks i'd give it a shot, but I'd rather ruin a wheel I don't need for a build.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Yes, you'll be fine. I've replaced a couple of BBs to achieve the chainline dictated by the hub and cog. Not being a stickler for vintage spec, I went with a cartridge-style, but the same measurement and clearance principles apply. All told, it's maybe a 15-minute job; re-dishing and truing a wheel would take me a lot longer.
Guest
Liked 3,270 Times
Agreed, but honestly, the only service I've ever performed on a sealed BB was to replace it every three or four years, whether it needed it or not.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Yes, one of the nice attributes of square taper bottom brackets is you can customize a drivetrain exactly like you're doing. I may have overlooked it, and I apologize if I have, but do you have an existing bottom bracket spindle in the bike now? If so, you what the current chain line is and you can adjust from there to get your desired chain line. Remember that, assuming a symmetrical spindle, your chain ring will move outboard by half of the length increase. That is, if you get a spindle that's 6mm longer than your current one, half of that will be on that non-drive side and half of that will be on the drive side. So if you need to move your chain ring over 8mm, then you need a 16mm longer spindle (again, assuming a symmetrical layout).
As others have noted, wheel dish is (almost certainly) not a factor here. Unless you're working on a bike with very fat tires and your chain line is going to be small and you need to move the tire and rim to the left for chain clearance...dish won't be an issue. You can re-dish the rim to the left or to the right, but that's not going to change the spacing of your rear sprocket in relation to the frame. In other words, dish won't affect your desired chain line at all. This is not at all to discourage you from learning more about how to do that stuff, but it shouldn't be the long pole with this particular project.
Liked 762 Times
Thanks, I had a pretty good idea what to do but now I have a clearer idea. My understanding is that re-dishing comes into play when the front of the drive train is a given, and axle spacers are used to align the rear cog with the front chainring. Following that, the re-dishing re-centers the wheel relative to the frame.
Quoted: 1858 Post(s)
Liked 664 Times
If you're already buying a crankset. it's probably simplest to just buy the BB that is recommended for the crankset. Is that not possible? If you can just get a Shimano cartridge of the current common grade with the recommended spindle length, why would that not be satisfactory? What complicates it?
Liked 664 Times
Guest
Liked 3,270 Times
That work could take longer, but maybe not. It's mainly more exacting - you have to do enough of the correct adustment to every spoke, and it might not be the same adjustment for all the spokes. And you have to have the technique not to round off the spoke nipples with the spoke wrench.
