What are the steps to removing a quill stem?
Location: "Gosh honey, you pass more like Tony Rominger..."
Bikes: 2005 Scott CR1 Pro - 1992 Panasonix Fixed Conversion 60tx20t
Help! How do you remove and old-style quill stem (1978 Peugeot)?
"How did all those 'Keep Off the Grass' signs get there?"
Shimano Certified
Loosen your stem bolt so that about a half inch is exposed above the face of the stem. Next take a wooden block and a hammer, whack the bolt. It should pop down and be free. If it is still tight, repeat. The stem should be free to move when this is complete.
In some rare incidents, the stem will become corroded in place, requiring more force. As long as the fixing bolt has been loosened/rattling free, you can hold the wheel in place and turn the stem with the bars. the steps beyond that are more complex and typically not needed, so I will forgo the rest unless needed.
NB if you loosen the bolt too much, the retained wedge at the end will drop off and you will have to spend an afternoon trying to fish it out with some bent wire. Try loosening the bolt 2 or 3 rotations.
You may have to yank the bars from side to side to get the stem moving.
Note the length of your front brake cable and undo the retaining bolt if it prevents stem removal.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Make sure you're NOT twisting the fork with a frozen stem. If the wedge does end up in the steerer, rethread the bolt back into it then try to pull it out.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Liked 11 Times
Today, I believe my jurisdiction ends here...
Originally Posted by sydney
^^^^ ....Too tough a concept for carpet smokers.
Liked 11 Times
Yo, Vegas; if the wedge falls into the steering tube you turn the bike over and the wedge falls out.
Is this not clear?
Speaking of smoking carpet, the OP says plainly that the bike is a Peugeot and I suggest it's a Schwinn. Time for another cup of coffee...
Is this not clear?
![Wink](images/smilies/wink.gif)
![Smilie](images/smilies/smile.gif)
ot.net slave
Bikes: Salsa mtb * 3, Intense mtb * 1, Abeni SS rd * 1, Salsa road/touring * 2, Trek Damn one * 1, Vintage/projects * many
9 years is that a record? I think you're preaching to the departed, my friend.
- joel
- joel
Any advice would be appreciated. Thanks.
