Threadless Conversion Headset
#251
While this isn't necessarily something I want to get into myself, I'm happy to consult and provide spare parts for modification as necessary to whoever decides to take this project on.
#253
I'm trying to install the Innicyle on my 2000 LeMond Zurich. When I thread on the threadless adapter to the fork, it seems to bottom out before I can properly set the preload so there is still a little play in the fork. It's close, but needs maybe a couple more millimeters to tighten. suggestions?
#254
Solved. Found the specs for the length and mine was about 2mm too long. I took my fork to the bike shop and they quickly trimmed a little bit off. It now fits nicely!
Likes For Mr_Stop:
#255
Another very pleased Innicycle owner! It is a very well thought out design and the perfect component for my Neo Retro Velo build.
Everything worked out fine but there is one thing i'm struggling with. Is it normal that I can move the steerer if I turn the handlebars with the wheel between my legs with a good amount of force?
Likes For BenoitB:
#256
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
Instead of 15nm, I torqued it to 15ft-lb & that solved the issue. I really think the newton meter comment was a typo or a simple mis-speak. A newton meter is about 75% of a foot pound so it's not like it's being eggrigiously over torqued considering it's barely being torqued enough to do the job at all to begin with.
I still like the idea of a steel wedge nut discussed of the prototypes instead of the aluminum one supplied in the final product. There may be something there with regards to the proper torque & internal friction in the design process. But, who am I to say? I have a steel wedge nut of the proper dimensions...maybe I should actually test & see if there is a difference instead of floating questions & theories.
BTW: Your bike looks pretty awesome.
Car dependency is a tax.
Likes For base2:
#257
For anyone having an issue getting the quill tight enough to not turn inside of the steerer, I'd suggest one or all of the following (in addition to greasing the threads and wedge):
1. more torque, as noted already. 15 ft*lbs (20 N*m) is fine given the size of the hardware.
2. grease under the top cap where it meets the steerer tube. This interface can generate a lot of friction especially if the steerer tube has been cut and the anodizing is removed.
3. friction paste on the quill portion. The ID of some steerer tubes may be a little more than others requiring more deflection of the quill to get a good 'bite'. The grit in the friction paste will reduce the amount of deflection required while giving more potential grip and helping prevent corrosion.
I do appreciate the feedback and will see if there's something that can be done on future units to improve this function.
Likes For joejack951:
#258
Is there a possibility that there will be a 1 1/8 inch version in the future? Would be very nice upgrade for retro mountain bikes with rigid forks.
#259
I actually have an old GT MTB with a 1 1/8” threaded headset sitting in the garage for just this reason. Perhaps if groupsets weren’t so hard to get these days I’d have already turned it into a restomod-gravel bike.
#260
Threaded headset to hidden conversion
Hi There,
I was wondering if there was such a conversion kit available to convert a traditional 1 inch threaded headset to a " hidden style" headset
Would love to make the head tube much neater if possible!
any thoughts or suggestions would be greatly appreciated
90's vintage 1 inch threaded headset - conversion needed to hidden style headset
#261
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Hi There,
#262
Long time with no updates! I mentioned it in my last post and like many things, it took a lot longer to come about than anticipated but it is finally ready for 'mass' consumption. Of course, there's a special French-threaded upper race to go along with the French-sized crown race and quill, complete with M25x1mm threads. Available in limited quantities of both black and silver. There's also an early Schwinn (21.15mm quill) and BMX (32.6mm cups and 21.15mm quill) version available now as well. Time to get to work on that 1 1/8" innicycle next!
#263
Quoted: 359 Post(s)
Liked 582 Times
Hi There,
The way the headset uses the head tube may be hard to overcome in a "hidden" style.
I can see a lip replacing the cups top and bottom, but then there may be issues with bearing size, bearing races, and differing bikes.
The Innicycle is pretty much for 1" threaded forks. No doubt it can be done, but the machine setup, etc may not be economically feasible.
Still, would be cool to build a bike with one like that, with the stem or spacers appearing to sit right on top of the head tube. Funky.
#265
Hi There,
The cycling industry has done some funny things along those lines with bottom brackets in particular. If anyone remembers the ISIS 'standard' it is a great example of pushing things too far with regards to minimum bearing sizes in an attempt to increase the crank spindle diameter. There are other more recent examples with attempts to convert from some poorly chosen integrated bottom brackets back to a threaded setup but (Trek BB92 I believe). Anyway, it's not a path I'm interested in pursuing for those and other reasons.
#267
Have you tried https://www.innicycle.com/?
#268
Likes For Mr_Stop:
#269
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
These look interesting but there is no vertical adjustment. What about the millions of classic bike lovers that don't want to be hunched over like Moser going for an hour record?
Sugar "Kane" Kowalczyk
#271
Here’s another before and after but with an untrimmed headset (50mm of spacers under the stem): https://www.bikeforums.net/21078123-post65.html
Note that you can also use any one of the number of high rise stems in the market, including the VO Cigne if higher handlebars are a priority.
