Stripped Threads Brake Post Mount
Quoted: 2976 Post(s)
Liked 1,182 Times
So after a wheelset swap was readjusting my rear brake caliper and one of the bolts wouldn't tighten...threads stripped on the aluminum insert in my carbon frame. Found a longer bolt that is working for now. Apparently there were some good threads left deeper down the hole. Thinking I might want to try this product as I'm not sure there is enough material left for a helicoil. Thinking I may crack the mount if I insert a helicoil into it. Anyone use this before?
https://www.amazon.com/Loctite-23638.../dp/B01M1ECJ0E
Quoted: 839 Post(s)
Liked 1,064 Times
I assume you're talking about a disc caliper? I would say skip the Loctite product or any other epoxy type fixes as your brakes need a stronger fix. Helicoil it or just keep using the longer bolt if you feel it's strong enough and it can handle the specified torque when tightening.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
No pics. Imagine that.
Likes For SurferRosa:
Liked 1,182 Times
Disc brake.
What's this rim brake thing you talk about?
See there is a similar product called Time-Sert. Maybe the longer bolt works for now.
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
This is why IS mount standard is superior.
The heli-coil is probably the best repair. Make sure to use a torque wrench next time.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 169 Times
I doubt that there is enough metal to use a helicoil for repair. I would use the longer fastener and the form-a-thread, as long as it is a through hole with access to both sides. If it is a threadsert in a tube with no access the form-a-thread would not work properly.
Sir Mark, Knight of Sufferlandria
