Minor Headtube Dent - Ease My Mind (Fingers Crossed)
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 267 Times
Just got a frameset in the mail and not totally certain if it happened during shipping (packed well and no signs of damage to box) or if the seller omitted this detail (still waiting to hear back). Definitely looks like a "ooops, I dropped it" and not a "oh sh*t, I crashed" and the rest of the frame appears to be straight and free of damage.
Anyhow, still a bummer and I'm formulating the best possible fix (suggestions welcomed).
My gut says "it's not bad, just ease it back into place and forget about it" and my anxiety brain says "what if... what if... what if...". So yeah, what do you experts think?
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,384 Times
...have you tried fitting a headset cup in there yet ? Looks like it might be off enough to make that problematic, but it's hard to tell from a picture.
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
That looks out of round to my eye.
Quoted: 99 Post(s)
Liked 267 Times
It is a bit too much to force a cup in right off the bat. The seller just responded and apparently is a frame builder himself. He advised to have a shop bring it back to round using a headset press, so I'm going to look into that tomorrow. Also offered a partial refund for the headache so that's nice.
Likes For squarenoise:
Quoted: 99 Post(s)
Liked 267 Times
Henderson, NV
Quoted: 322 Post(s)
Liked 596 Times
Friendship is Magic
Bikes: old ones
Liked 10,384 Times
Steel lugs are pretty malleable, for the most part, especially if it's not a cast lug. But they can develop cracks when stressed.
If you plan on using an alloy headset, probably get someone with a press to fully seat steel cups, top and bottom, and see if they align well.
I think I would install a steel headset, install the fork, then see how smoothly the thing rotates. Then go from there.
An actual frame person would probably have a reamer, and maybe face it again, to make sure you have a level surface there.
Likes For 3alarmer:
Quoted: 3515 Post(s)
Liked 2,929 Times
Press a cup in and call it a day.
Likes For smd4:
Quoted: 242 Post(s)
Liked 456 Times
Deformed...if the headset bearing fits it is your decision whether to keep it or have the seller refund the money for selling a damaged frame and not disclosing said damage.
Wondering what you paid for a rusting frame with deformed head tube.
Likes For Kai Winters:
Liked 2,929 Times
Yeah, the rust would bother me way more than the head lug.
Likes For smd4:
Likes For jadmt:
Quoted: 4236 Post(s)
Liked 2,949 Times
Quoted: 2604 Post(s)
Liked 1,933 Times
Note O.P. mentioned it could have happened during shipment.
Likes For pdlamb:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
Quoted: 514 Post(s)
Liked 451 Times
The seating of the headset is more of a concern than the integrity of the tube.
Quoted: 99 Post(s)
Liked 267 Times
Thanks for all the input, everyone!
After a bit more searching and a boost of confidence to do it myself, I think I have it sorted out.
I ended up using a socket that was close to the head tube ID and gently tapped the dent out. Went slow and steady and was a pleasantly surprised how well it worked. Next, I dug up a JIS headset cup which has a 30.0mm cup diameter and got that seated no problem, figured this would help make sure it was a bit closer to round, before using the ISO 30.2mm headset cup.
Overall a painless fix and everything is looking/feeling good. No visible wobble when spinning the fork. The installed headset is a Tange Levin CDS, but I may end up swapping it out for something with more stack so I can lose the big spacer.
I'm planning to post a full build thread soon and will share updates as it comes together.
And again, thanks for the feedback. Definitely helps in the decision making.
The seller, genuinely surprised by the dent, was very apologetic and as I mentioned above offered me a partial refund for the inconvenience.
Regarding the rust, It's really not bad for nearly 40 year old touring bike. Inside the tubes look good so I have no problems with a bit of surface rust.
Onward!
Onward!
Liked 2,929 Times
Likes For smd4:
Likes For TiHabanero:
Quoted: 99 Post(s)
Liked 267 Times
Thank you! I tend to overthink things, especially if it's a problem I've never dealt with, so this forum is a huge help. I appreciate the advice and the "you can do it" sentiments which gives confidence to figure things out. I've learned so much here over the years and do my best to contribute with things I'm familiar with.
Quoted: 5793 Post(s)
Liked 2,593 Times
Apologize if this has been said.
No sweat. It may be difficult to start it, but most cups have enough taper to do so. Simply press it in and it will act as a mandrel pushing the dent back out. If you can't get the cup started or feel it's taking too much force to press it it, use a piece of pipe or other cylinder inserted a few inches and use it as a pry to push the dent out. It doesn't have to be perfect, the pressed cup will finish the job.
FB
Chain-L site
FB
Chain-L site
Location: Western Riverside county, Southern California
Bikes: 07 Raleigh supercourse, 04 Specialized epic MB, Surly 1x1, Recycled Recumbents Mach 2, 63 jc Higgins racer single speed, early 60’s Armstrong roadster, KHS tandem electric conversion, GT mb electric city bike conversion.
Quoted: 14 Post(s)
Liked 21 Times
Liked 2,593 Times
However, be aware that it's very unlikely that anything useful can be pushed through from the opposite side. The headtube ID is smaller than the reamed ends.
If the OP has something of the right diameter he can use a vise or improvise a press to force it in. But, there will still be springback, so the results will come up short.
Using a pry cammed into the tube allows working beyond the circle to compensate for springback.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 99 Post(s)
Liked 267 Times
I actually had it inside the top, right up against the dent. Held it in place using a socket extension and tapped on the extension to avoid accidentally hitting the frame. I positioned the frame so the headtube was face flat on a rug so it was a bit easier to handle. Hope that makes sense.
