headset needed
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
headset needed
can you guys help me find a cheap headset (aliexpress is the best option) regarding a new headset to replace an old treaded fork with one treadless and a bit larger?
Quoted: 5793 Post(s)
Liked 2,593 Times
First and most important --- you cannot go from a threaded to a threadless headset on the same fork, so change your plans unless you've changed your fork.
Next, consider the critical dimensional specs.
1.125" (1-1/8") forks and headsets all conform to a single standard, however there are so-called tapered and standard types.
1" forks are trickier. There are 2 common standards ISO with 26.4 crown an 30.2 headtube, and JIS which are 27.0/30.0 respectively.
So, figure out what you need then happy shopping.
BTW- if you did buy a new threadless fork, you'll also need a new stem.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 805 Post(s)
Liked 2,987 Times
Quoted: 333 Post(s)
Liked 168 Times
I don't do brand recommendations but here are thin gs to consider.
Liked 2,593 Times
Note, if its 1", there's a possibility that you bought a JIS vs ISO fork, kr the other way around. It will still work, but since the fork and frame don't match, you might need to buy 2 headsets.
FB
Chain-L site
FB
Chain-L site
Quoted: 805 Post(s)
Liked 2,987 Times
your correct/
in that case I would choose the FSA with cartridge bearings.
https://www.amazon.it/Orbit-MX-8Inch...993240&sr=8-17
Clark W. Griswold
Quoted: 4365 Post(s)
Liked 4,006 Times
Cane Creek 40 from Cane Creek or an authorized dealer. Would not want junk from Alibaba and his 40 thieves and have always found Cane Creek to be some of the best headsets and will last and last and last and continue lasting. Plus Cane Creek has good support behind their products and the bearings are sealed cartridge bearings which are easy to replace and a better choice for a headset.
Measure the fork at the crown seat (base of the steerer). Measure the head tube ID at top or bottom.
Liked 2,593 Times
Yes, they can be forced in but it can be risky practice. The added stress can eventually split the tube, especially with aluminum and some higher steel alloys.
FB
Chain-L site
FB
Chain-L site
Just curious if you've ever seen this happen. I can imagine it happening, hence my caveat, but I've heard about it being done enough times to not worry too much about it.
Liked 2,593 Times
Yes, a few times. Mostly with aluminum and once with steel. We need to keep in mind that these standards aren't created at random. They're carefully created and reflect the mechanical properties of materials, to a balance between the "constricting" force and the elastic limits involved.
FB
Chain-L site
FB
Chain-L site
