Storing wet bikes. Right side up. Or upside down.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I ride my bikes in the rain. They get wet. I put them back in the garage and let them drip dry. No sissy blow drying.
A given bike can either drip dry while standing upright on its wheels, leaned up against something, or while hanging upside down by its wheels from two hooks in the ceiling.
Is there a reason to prefer upright or upside down?
Quoted: 1438 Post(s)
Liked 1,092 Times
Well, if you have fenders the water will pool in them, and the underside of the seat, if the bike is hung upside-down. Headset, too, probably.
My intuition says it will dry faster and more thoroughly standing upright, provided you have (or make) a hole in the bottom of the BB shell to allow it to drain. Paint the raw edges of the hole to avoid rust, if a steel frame.
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
Either upright or hanging from the front wheel. Most bikes have vent holes in the rear at the back of the seat stays or a vent hole in the bottom of the BB.
Bikes: Ratty ol' fixed gear and a 2013 Kona Dew Deluxe (SS conversion)
Quoted: 12 Post(s)
Liked 22 Times
A quick wipe of the drivetrain and a little lube is a good idea too; otherwise stand it up and walk away.
Quoted: 14 Post(s)
Liked 13 Times
Lube-wise, I believe it better to lube while dry, before riding in the wet. The lube helps exclude moisture from pivots. After riding in the wet, or washing the bike I let it dry thoroughly before applying lube so the lube can cleanly wick in without water/moisture being involved or getting trapped.
Right side up vs upsidedown? 6 of 1, half dozen of the other. I think it makes little difference.
Sr Member on Sr bikes
When I end up riding in wet conditions...I first rinse it down with a bucket or two of hot water. That gets some of the oil/grease off that it picks up from the road. Then I hose it off thoroughly with fresh water making sure to hit the undersides and small crevices of everything. This gets off any sand, and road salt which would hasten corrosion. Then, I let it dry in a different position every time so that any internal corrosion doesn't get real bad in one spot. Of course this method requires attention to lube before the next ride.
Dan
Dan
Quoted: 1572 Post(s)
Liked 644 Times
To me that's the key: Hole in the bottom bracket - right side up. No hole in the bottom bracket - upside down and you'd do well to also pull the seatpost.
the Club cut out of Steel Colnago (etc) Frame's BB's Drain nicely better To Park In a warm Room so the water evaporates....
Heated Garage a Winner.. (or Hair dryer , Hell.. get out the Formica Couter top Bubbling Heat Gun !)
Heat Leaks into my Mud/entry room, under the door at My house from the front room.
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 713 Times
Ridden hard and put away wet? Leave 'em upright.
Jeff Wills
Jeff Wills
