Saddle Bolt Question
Bikes: Trek Domane SL 5
Quoted: 218 Post(s)
Liked 102 Times
Hey All,
What does the "7 RND" label on my saddle bolts mean? Also, from looking at this, do you know which bolt(s) I'd need to adjust to adjust the saddle tilt? I'm looking at the ones on the sides vs. the one silver bolt underneath and in the back.
Thanks!
Thanks!
Should Be More Popular
Quoted: 22651 Post(s)
Liked 8,967 Times
Advocatus Diaboli
Quoted: 4758 Post(s)
Liked 1,537 Times
FWIW, though not a great angle/photo, the tilt bolt under the saddle appears might be a T25 torx
Just a guess, looking at the clamp style, the 7RND is probably saying that the clamp is only compatible with 7mm Round rails.
Likes For Sy Reene:
Quoted: 218 Post(s)
Liked 102 Times
Does the tilt angle slip over time? About 6 months ago, I was at the bike fitter and told him I felt like I was slipping off the front and he said that the nose was tilted down 1.5 mm and that it may have been bumped.
Recently my wrist started hurting and I noticed that I felt the same feeling of slipping off the front. Instead of going back to the fitter, I decided to start tinkering with it. One 360 deg turn nose up and it feels better.
Is it normal to slip over time?
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Not 100% familiar with your seat, but you might try tightening the side bolts also after you get it where you like it. That might stop the movement over time. It shows the torque measurement on the side. Other than that, I don't see a locking nut or device to stop movement over time. Good luck,
Likes For Bigbus:
Quoted: 4717 Post(s)
Liked 1,882 Times
not 100% familiar with your seat, but you might try tightening the side bolts also after you get it where you like it. That might stop the movement over time. it shows the torque measurement on the side. Other than that, i don't see a locking nut or device to stop movement over time. Good luck,
Likes For noodle soup:
