Dial it up to 882 watts...WTF?
Bikes: Baum Romano, Brompton S2, Homemade Bamboo!
Quoted: 474 Post(s)
Liked 204 Times
I was just checking out the Garmin 500 data from this morning's ride in Ascent and was surprised to see that it calculated my max power at 882 watts.
This is not a powertap etc, it is a calculated power based on all the known variables that the Garmin collects and that I have entered (weight etc).
Since this is a truly epic amount of power, I just had to know where I did this. Was it that attack on the short hill, or was it the acceleration to catch the little guy who put on a push?
After a quick search of the data I found a short acceleration up a 20 deg hill. Hmmmm. There are some 10, 11 and 12 deg climbs here, but I'm pretty sure I haven't gone up anything this big. Let's double check on the map...nope, nothing close there.
So - I am reminded of the board game 'Monopoly' where you can get a Chance or Community Chest card stating "bank error in your favour" etc. Today I had a data error in my favour!
I think the unit got a bit 'lost' when it was turned back on after a drinks break and didn't calibrate fully before we rolled. When it did gather its thoughts there must have been a wild alteration in the elevation - and the consequent calculation of power was just a little off!
Maybe I need to save up for a 'real' power meter...
Well, no, estimated power won't be remotely accurate, but that doesn't mean that a peak of 882 watts is all that crazy. A peak might be for only one second, and lots of riders are able to hit that kind of wattage. I don't know my peak power, but I do know from a few experiences with CompuTrainers and a friend's borrow PowerTap that it's higher than 882 watts - and I'm 56 kg. If you're bigger, an 882 W peak is even more plausible. From the same CompuTrainer experiences, I know that hitting 450 watts is relatively trivial even for a little guy like me. With a real thrashing, higher wattages are possible, and I once did a five-second test at 897.
This is all totally different from sustained power. As mentioned, that 897 is a five-second average. I have no idea how long I could hold 450 for, but not long! It's the same idea with something like 882. If your Garmin is telling you that you were putting out that power for a sustained period of time, that's messed up. If it's saying that you peaked at 882 on your ride, that's pretty plausible, even though chances are that it's a highly inaccurate estimate.
If you want to get a power meter, cool. I was seriously thinking about getting one for next season, but I decided that I really didn't need to go there. I would have been way more insufferable with the numbers than I even am in this post.
Bicycle Repair Man !!!
882 peak watts for a brief interval is not unusual... ran some old fashioned calculations a while back and calculated that at my weight I was able to generate 1000 watts for a few seconds and this was when I was topped out in a sprint or hammering up some short 12% grades we have here and a 20% grade is going to bump up the numbers if you were laying down some crank bending power.
As another smaller rider my wattage numbers are lower and bigger guys can really generate some intense, albeit brief bursts of power... am thinking that track sprinters get numbers in the 1800 watt range.
Quoted: 474 Post(s)
Liked 204 Times
I'm about 207lb and I know I can push about 650-700 watts out of a Concept 2 rowing machine for a couple of minutes!
I didn't immediately think it was an error, but I did want to see where I had done this epic feat.
The reason I'm sure the data is wrong is that the location on the map is pretty much flat and I wasn't working hard there. If it had been at one of the two locations that I suspected it was then I would have just accepted the truth that I am a cycling monster (over very short distances).
Quoted: 2952 Post(s)
Liked 3,106 Times
Where are you seeing this? I have a Garmin 500 but have never seen it display an estimation like that.
I weigh 180 lbs and can push roughly 7,000 watts. I know this because I work in an industrial facility and once had to attach my bike to the 10hp rotary-screw air compressor when the electric motor blew out (real 10hp, not the Sears inflated kind). I was on the bike for roughly 13 hours. It was a good workout but nothing to write home about.
882 watts is easily doable.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Quoted: 20810 Post(s)
Liked 9,456 Times
Quoted: 474 Post(s)
Liked 204 Times
I did say I could do this for about 2 minutes! There is no way I could keep it up for a full 2k piece. For the record my current 2k erg time is 7.15 (my best, back in the day of racing club open straight pairs is about 6.40).
Quoted: 474 Post(s)
Liked 204 Times
I'm sure (based on the location) that it is a glitch, but it's nice to know that 800w is not 'out of this world'.
Headset-press carrier
Bikes: Kona with Campy 8, Lynskey Ti with Rival, Bianchi pista, Raleigh Team Frame with SRAM Red, Specialized Stump Jumper, Surley Big Dummy
Isn't that waterrockets' kilo wattage?
more long distance pieces required that's a pretty big split drop from even a 1 min power test to 5, since you're essentially effective power is cut by a factor of 3! i think our coach had a benchmark of 5 splits per testing distance... so +5 from 500 to 1000, +5 from 1000 to 2500, +5 from 2500 to 5000 and so on.
Quarq shill
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
I'm your size and hit 800w on at least 90% of my rides. It's not that impressive, sorry.
Quoted: 474 Post(s)
Liked 204 Times
I always take heart that I can shift a 1x better over a 1000m race than guys who are 30-40 seconds quicker on the ergo. That always shuts them up!
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
My Saturday ride I had 1130w for a max, and 908w for peak 30 seconds, and that was without any real sprint.
So 882w peak power for someone over 200lbs is not a big deal.
You could get lost and die.
You could hit a tree and die.
pan y agua
Liked 727 Times
As an aside, the 908 watts was up a 4% grade at 24.2mph. Ran the numbers through Kruezotter, and the calculater said that 908 watts should be 23.9 mph, which was amazingly close.
Quarq shill
Damn, I've never had luck coming up with numbers on there.
Agreed, 800 W max is not hard to do. The question is how long can you keep it up? I'm guessing Garmin won't tell you that. Enjoy,.
Bikes: BMC Team Machine SLT01
That said, I've hit 1100 watts on the c2 for a single stroke - equivalent to a 1:08 split.
