New chain size question
I have a quick question. Just bought a new chain and I am a bit perplexed. Hopefully you guys can help me out.
Just bought a new chain from my LBS. I have swapped chains a few times before on other bikes with no issues, just never have done it on this bike. This is a fairly new bike and this is it's first new chain. The bike has a 10 speed rear hub, so I bought a 10 speed chain (SRAM PC1071 to be exact). However, as I compared it to the bike's old chain, the new chain is shorter! It is too short by two full links. Is this common? I can't imagine that it is, and it was my understanding that new chains are almost always too long so that links can be removed to achieve the correct size. Can anyone shed some light on this situation? Or is it simply a fluke and I go return the new chain.
Thanks!
Thanks!
Quoted: 18376 Post(s)
Liked 4,512 Times
Many new chains normally specify the number of links which can vary. Chains can be short for a few reasons like larger than average cogs or chainrings. Or, perhaps long chainstays. Tandems, cargo bikes, and etc often splice chains.
Make sure you're accounting for chain stretch when measuring your old chain, it can be as much as one link or so. Plus, also add in a quick link if you're using one.
If you're still short, call your LBS and ask if they have a longer one.
Licensed Bike Geek
Generally new in the box chains will come in 104, 110 or 116 links long. If you're able to return the chain to where you purchased it, ask for 116 links. That length will cover 99.99% of the bikes out there. Then cut to size.
Okay, good info, thanks guys. I did not account for chain stretch, guess I didn't think it would be that significant. Will check again.
The new chain I purchased has 114 links. I'll check for stretch and update.
Checked for stretch, it was insignificant. Upon further inspection, the new chain is short by one full link. I do have a spare power-link, but I don't see that adding length unless I am mistaken.
I was able to find out the chain that came stock on this bike and it, indeed, is a 116 link chain. KMC X10 if you're interested. Looks like I'm headed back to the shop tomorrow.
Really Old Senior Member
How do you know the chain on the bike isn't longer than needed?
All you need is to loop the chain over the largest ring and largest cog.
DON'T go through the RDER.
All you need is for the ends to meet +1" <2".
Is this a road bike or mountain bike?
This is a touring bike, current model Novara Randonee - https://www.rei.com/product/875004/n...onee-bike-2016
You want at least 1" extra.
You don't want 2" or more extra
Quoted: 140 Post(s)
Liked 162 Times
Derailer Adjustment
Sheldon explains chain sizing in this article, with this method giving the shortest possible chain length that will safely shift to the largest chainring/largest cog combination.
Quoted: 2026 Post(s)
Liked 1,096 Times
The sizing technique consists of simultaneously looping the chain over the largest chainring and the largest rear cog without running it through the rear derailleur. Overlap the ends and add 2 half-links (i.e. 1" of additional chain) cut the chain at that point or add an additional half link as needed to have the ends match properly. This is commonly known as big-big+1".
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
I just go by the position of the pulleys. If the chain is on the smallest cog (in back) and the largest chainring, and the pulleys are somewhat perpendicular to the floor, you should be fine.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Liked 1,096 Times
If you are within the chain wrap capacity of your rear derailleur you are probably ok. However, I always want to be CERTAIN the bike will shift into big-big and the big-big+1 technique does assure it will.
Thanks for that info on the big+big+1 method. It confirmed that this chain is indeed too short. Looks like I need the 116 link.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
It's critical the chain is long enough for big-big. Big-small does not check that your chain is long enough, which could result in frame & wheel damage.
Super Moderator
Liked 927 Times
I'm the odball, and I check by running the chain through the derailleur, and big-big. Then I am 100% sure it's long enough.
