cassette issue
cassette issue
I've just got a new rear wheel. I put on the lockring to the recommended torque, but the last few cogs (the ones that aren't attached together) are still able to move around slightly. I don't know why this might be. Is it possible there is a spacer or something missing? Its a Deore XT/M756 hub with an 8 speed Shimano cassette.
The amount of play in it is incredibly small - I only noticed by hearing the sound it makes once per revolution of the cassette while I was installing a new chain. It might also be possible that it is not torqued quite enough. There is very little depth for the lockring tool to engage the lockring, and I had issues with it slipping. I did (I think) eventually get it on though, and the wrench clicked. I just don't really see how I might have lost a part of the cassette?
I guess I'll just head to the LBS tomorrow.
Quoted: 5833 Post(s)
Liked 2,662 Times
Cassettes must overhang the freehub body slightly. Otherwise the lockring bottoms out on the body and can't properly compress and secure the cassette. It's analogous to threadless headsets which require the stem/spacer stack to be taller than the steerer to work. Add the thinnest spacer that's wider than the gap behind the cassette to establish the overhang and you'll be good to go.
BTW- you might not have lost a part, there's slight variation between brands in freehub body and cassette widths, so some combinations need spacers and others don't.
FB
Chain-L site
FB
Chain-L site
Some cassettes have a very thin spacer between the two smallest cogs, perhaps it is missing? Experience tells me that the cassette should have no play even if you only hand tighten the lockring, so adding torque is unlikely to help. The problem is, the smallest cog will tighten against the end of the freehub body and will not move any further no matter how tight you turn the ring. So don't over torque it.
