More seatpost height/setback than Campy NR
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Quoted: 45 Post(s)
Liked 101 Times
After a pile of test rides, I've decided that I need more height (25mm or so) and more setback than the original Campagnolo NR seatpost (27.2) that came with my '83 Basso Gap allows. Does anyone know of a Campy model that will fit the bill? If not, I guess I'll try some of the more modern posts and see what I can come up with. The Cinelli Via Folli looks interesting with 250mm length and what appears to be about 50mm of setback any experience with it? Any other thoughts that might work to maintain some of the vintage appeal?
Maybe a Velo Orange Long Setback when they come back in or if you can find one.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Quoted: 1858 Post(s)
Liked 664 Times
Quoted: 1608 Post(s)
Liked 2,216 Times
Looks like your saddle could go back more.
Nice looking bike! What year do you think it is?
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,098 Times
I. Necked today and the Record/Super Record posts have about the same set back as Campy Aero. Nitto 626 is nice looking and has a little more setback but as menti9ned earlier, looks like you have some room to slide your saddle a little.
Quoted: 1872 Post(s)
Liked 692 Times
I don't think moving his saddle back matters when he needs 25mm more height so that he's not past the minimum insertion line.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 45 Post(s)
Liked 101 Times
Thanks for the recommendations... Since I took this pic, I've upgraded to a Selle Anatomica, and set it as far back as they recommend, but still need some more. Plus the height. I guess I'll check out the Nitto posts and give up on trying to keep this as close as possible to original.
Better to ride it than admire it!
Quoted: 331 Post(s)
Liked 332 Times
Apples and Oranges
Height of the seat is determined by your inside leg measurement. Set back is determined by the length of your arms and torso.
Campagnolo does not make very long seatposts. The rationale being the frame should be right for you and the setback, stem length and seatpost are adjusted to fine tune a frame suitable for your body shape.
