Drop Bars?
Drop Bars?
I am new to the whole drop bars idea. Every time I try to go into the drops it seems like I am bending over to far. Should I raise the bar up or is it something that I will get used to?
I haven't rode a bike in almost ten years and even then it was a wal mart special mountain bike.
Bikes: Workcycles FR8, 2016 Jamis Coda Comp, 2008 Surly Long Haul Trucker
Liked 6 Times
I have rarely used the drops on my bike. I'm mostly on the hoods or tops. Recently i've been contemplating switching over to trekking bars instead.
xtrajack
Bikes: Kona fire mountain/xtracycle,Univega landrover fs,Nishiki custom sport Ross professional super gran tour Schwinn Mesa (future Xtracycle donor bike)
Back in the late 70's early 80's, I rode with drops. I quit riding for about 25 years, started riding again, found out drops weren't much fun for me. I discovered trekking bars, my body is much happier with them. YMMV.
Green Tea Lemonade
I had drops on my bike, with a flipped stem. I found I never rode in the drops, always on the hoods. Then, I put the stem back up, and I now mostly ride in the drops, unless I'm feeling tired or something.
I think I may try raising the bar and see if that helps. If not well I may have to find a plan b.
Plan B-take it to the local bike shop for a professional fit-there may be some other things going on with the fit, like seat position. Up/down/front/back. I love the drops, much more aerodynamic. But I see a lot of guys converting to straight bars, so either way is valid.
Quoted: 18883 Post(s)
Liked 10,646 Times
Something like this will run you about $25, and let you move your bars up and down at will. It might be that your bike is too aggressive for you (low bars = aerodynamic profile) and you need them higher, or it might be that you'll get used to it with time. If it's the later, you can put them as high as you like now, and lower them slowly.
