Toe Clip Straps-Do you twist?
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
I have new straps coming for a couple of my vintage mountain bikes.
For those that still use toe clips, Do you give the strap a twist in the pedal or do you thread it straight through?
I was always taught to put a twist in it when I rode a road type bike and it carried over to my MTB cages and straps.
What say you?
What say you?
Quoted: 405 Post(s)
Liked 430 Times
Yes.
The twist helps prevent the strap from sliding through the pedal when you pull it tight.
Nylon straps should be twisted twice... They're slippery.
--Shannon
--Shannon
Likes For ShannonM:
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...depends on the pedal and the straps. They should stay where you put them, the buckles shouldn't move.
If I can do that without a twist, I do so. With some pedal/strap combinations, the twist is redundant. With some, a half twist is enough.
With pedal/ strap combinations that are difficult to insert in the first place, they usually stay where they are without it.
There are a lot of limp assed toe straps, made and sold now, that don't work well regardless of what you do. Pet peeve.
Likes For 3alarmer:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
The twist is just old school tradition that hasn't died, and rightfully so, it does help keep the leather strap from sliding through the pedals, but also reduced rub/teeth wear on the strap from the buckle making it last a bit longer. So what they would do is put a single twist in the strap, after riding a while the teeth on the buckle would begin to wear the strap, so before they got bad, they would put another twist into the strap effectively shortening the strap which means the teeth on the buckle would bite into an area of the strap that is fresh, so they would keep doing that as time went by, and that is why you don't want to cut the strap to shorten it.
Some later pedals like Suntour Cyclone and Superbe have set screws to hold the strap in position. Those pedals would not fit regular leather straps, so nylon straps were necessary, there were some thinner leather straps but they were cheaper and wouldn't last as long.
Likes For rekmeyata:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
Of course! Every un-twisted traditional toe-strap I see is a mistake to me.
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Quoted: 4806 Post(s)
Liked 3,932 Times
Quoted: 3513 Post(s)
Liked 2,927 Times
My straps are held in place securely by the cleat plate. No need to twist. Which uses up valuable length better suited to strapping in my size 12s. Additionally, twisting would obscure the "Bianchi Dino" labeling.
But even worse than twisting is placing the end of the strap through the "buckle," as seen above. Don't forget toe strap buttons! The Velo ORANGE Blog: Toe Strap Buttons are Cufflinks for Your Bike (velo-orange.blogspot.com)
Likes For KerryIrons:
Liked 3,932 Times
In my younger and more aggressive fix gear riding days, I used to have a more pressing concern than strap twist. Making the buckle (especially the left buckle) friendly to the hand that reached a little too far for the strap. I ripped my finger open a few times on the lower tab where the strap is (never) pushed through. I used to cut that tab off with wire cutters, then file smooth so there was nothing to catch skin. I also Speedy Stitched 1/8" cord in a loop to the strap ends. This served like those buttons to keep the end of a shortish strap slipping through and provided a very finger friendly handle to grab. (Fix gear - basically a machine that will grab and crush or shred anything caught in it.)
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
I actually had to check my bike (picked up during Covid lock-down).....the only one that has toe clips/straps.
I started riding with straps in the mid-70's and twisted them back then and I had put a twist on this one too.
I guess Old habits are hard to break .....
Likes For Speedway2:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
N.B., that's a Binda laminated strap on the Superbe Pro pedal, so pretty thick.
Liked 2,927 Times
Cyclone has the set screw to prevent the strap from move; Superbe Pro doesn't. I can see where it would be helpful if you run a nylon strap on the Superbe Pro pedal, but I've managed to get leather straps installed on them. It took some serious tugging with pliers on the straps, but it's snug enough that they stay put even without the twist (which wouldn't work anyway, with the limited room from the X-shaped body extrusion.
Old fart
Liked 3,401 Times
Liked 2,927 Times
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Haven't used toe clips since mid-90's but still have some straps that come in handy for a variety of uses, some of which are bicycle-related.
Quoted: 1820 Post(s)
Liked 1,696 Times
I still have my last set of pedals with straps. The straps are not leather, but a composite plastic and the buckles are similar to ones used on many shoes for clipless pedals. They were great. You could ratchet the buckle to tighten the strap and there was a button to push to release tension. You could not twist those straps at all
Likes For alcjphil:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,644 Times
Next we will learn if people are using twisted safety straps with their cable bindings and wood skis.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 405 Post(s)
Liked 430 Times
Road racing and fast recreational riding aren't those situations, true, but there's more to cycling than just those things.
So the question is valid, and useful, and the correct answer to it is: twist the straps.
--Shannon
Likes For ShannonM:
Liked 2,927 Times
Grupetto Bob
Liked 5,644 Times
Unlike cable bindings and wooden skis, there actually do exist cycling situations in which toe clips and straps are the best choice.
--Shannon
--Shannon
Bikes: 87 Bianchi X4, 95 Bianchi Ti Mega Tube, 06 Alan Carbon Cross X33, Gold plated Columbus AIR Guerciotti, 74 Galmozzi Super Competizione, 52 Bianchi Paris Roubaix.
Quoted: 259 Post(s)
Liked 540 Times
Yes.
