Adding a 1 1/8 Suspension Fork to an Old Frame with a 1" headtube.
Bikes: 1958 Schwinn Corvette, 1930's Triumph
Just wondering if anyone has attempted to add a suspension fork to a vintage Schwinn or Schwinn like frame.
I know it can be done, but it is a little tricky getting the right parts for the headset.
Schwinns have a little bit bigger 1" headset, which is really more than an 1". I have a bike I got off of Ebay that is using a 1 1/8th Suspension Fork and it works. I have seen others do the same thing.
The only place thus far that I have found that uses a headset that will work is called the Retro Ryder Headset from genuinebicycleproducts.com. It allows you do run a 1 1/8th suspension fork on an older vintage frame.
I email the guy I bought my bike from and he says that he filed down the headset on my bike so it would work.
Rather than buying the Retro Ryder Headset, It would be cool to do it myself. If anyone has any tips though, I would love to hear. I am planning on building my wife's bike (Old 68 Schwinn Holywood). Just need to figure out the fork part.
80's bikes FTW
Im looking to do the same thing to my Univega Alpina 5.5. Its got a 1" steerer and I want to put a 1 1/8" fork in there. I thought about opening up the stock headset to accept the fork but want to not damage the headset in the process. My headset is an 1" AHEADset which is not threaded so it makes it potentially a little easier.
Quoted: 28 Post(s)
Liked 60 Times
Two DIY options - Chuck your 1-1/8" headset in a lathe and turn it down enough to press-fit in the headtube like the retroryder, or ream the headtube out to 34mm ID to permanently convert the frame to 1-1/8", consider brazing some external re-inforcement rings around the thinned headtube if the walls would get too thin from reaming to 34mm.
Likes For GrayJay:
80's bikes FTW
I like the lathe idea a lot more. I think I may do this.
Quoted: 3243 Post(s)
Liked 2,091 Times
Quoted: 18382 Post(s)
Liked 4,515 Times
I'd just hop onto EBay and find the fork you like.
https://www.ebay.com/sch/i.html?_dca...Plus%7C700C%7C!
For vintage builds, you may also be able to find vintage "Springer Forks".
Quoted: 4513 Post(s)
Liked 6,391 Times
Danger, Will Robinson!
Likes For Reynolds 531:
Quoted: 235 Post(s)
Liked 351 Times
I'm just wondering... not being negative or anything, but why do you want to put such a fork on your old Schwinn or Schwinn-type. Are you going to use it off-road,? I can't see a suspension fork doing much for comfort (if that's the reason) if ridden on the road.
Again, I'm not trying to be negative; I'm interested. Long ago I considered a suspension fork swap on a bike and wound up changing to a different fork, but a different rigid fork.
Quoted: 1563 Post(s)
Liked 1,737 Times
Been done a million times.
https://www.youtube.com/watch?v=YDOyPb2WIdc
If you want to start from scratch, the Ritchey headset are easiest to machine.
Liked 6,391 Times
Doh!
Bikes: '88 Colnago Carbon Volo, '89 Colnago SLX Spiral Conic, '91 Colnago Master Olympic, '94 Colnago BiTitan, '99 Colnago Titanio, '89 Cinelli Su Misura MTB, '90 Cinelli Su Misura MTB
Quoted: 9 Post(s)
Why tho?
There are plenty of great, even legendary, forks with 1" steerers. Find something made for your bike; don't Frankenstein it up.
There are very few 1” forks available and maybe none suspension that use disk brakes.
I ended up getting external cups made from stainless steel that I’ll press/glue and use integrated headset bearings. I can’t post a pic but they’re the same as standard headset cups youd press in except pressing on the outside.
Bikes: a few that I can't recall
Quoted: 347 Post(s)
Liked 302 Times
For other bikes, I threw in the bit about Ritchey headsets seeming to be the easiest to machine for other bikes. I agree with you they definitely won't work for everything.
