Questions about Panasonic Touring Deluxe as light touring bike / some dirt roads?
Quoted: 9 Post(s)
I have an opportunity to buy a Panasonic Touring Deluxe but, since I'll have to drive a few hours to look at it, I was wondering if anyone could advise:
Its an '85, all original 19" frame.
I'm wondering if this would be a suitable bike for someone 5'2" tall (my 50cm '76 Motobecane Mirage is too big for me; the 50cm top tube is too long)
And about how heavy would it be? I"m interested in some light touring with probably not much more than 15 lbs of gear for paved and some dirt trails like the C&O Canal.
Could I fit tires of at least 32mm on it?
Thanks!!
Thanks!!
Quoted: 1627 Post(s)
Liked 630 Times
If it’s that far away, better ask the seller to measure the top tube for you, 19” isn’t much smaller than 50cm.
I would expect it to weigh about 25 lbs without racks.
Quoted: 3359 Post(s)
Liked 3,638 Times
Thanks!!
Thanks!!
I found this archive of the 1985 catalog:
1985 Panasonic Catalog
Unfortunately, it appears that the 19" Touring Deluxe has a 53cm top tube.
Stock tires are 27 x 1 1/4, which comes out to about 31mm.
Weight would likely be in the 25-27lb range. I know that's a pretty big gap, but I remember my 1986 Schwinn Passage was about 27lbs and it was a 58cm frame. You could expect the smaller frame size to weigh slightly less.
Quoted: 238 Post(s)
The Panasonic Bike Museum website shows the 19" model's top tube to be 530mm, although the seat and head tubes are not parallel which would affect your reach somewhat. Still, I think this would outside of your range if you prefer to be around 50cm.
Frankly, the only vintage touring model (or at least as we've come to generally define them) that comes close to that spec is the 47cm Specialized Expedition which had a TT around 51cm. The smallest Miyata and Fuji Touring models had TTs around 53cm as well. The Trek 520, which at the time was more of a sports bicycle, was briefly available in 18" with a TT of 49.5cm. The smallest Trek 720 was a 19" with TT around 53cm. Vintage Trek site.
The reach issue can be somewhat alleviated by raising the handlebars up with a longer quill stem.
Are you sure its a reach issue? Do you feel too stretched out or is there cramping in the legs?
Edit: whoops, Abshipp beat me to the Panasonic site.
Quoted: 238 Post(s)
I should also add a touring bike does not necessarily have to have drop bars on it. You could switch the bars out for some Northroads or other handlebars to reduce the reach and for more comfort.
Likes For zze86:
Quoted: 9 Post(s)
Thank you, this is extremely helpful! I'm still learning a lot about vintage bikes and bike fit and everything really.
The problem I have with the 50cm (50cm top tube) Motobecane Mirage is that while I can just BARELY stand over the top tube, I had to put a 80mm stem on it because with the longer stem I felt too stretched out and had too much weight on my hands and wrists for comfort. I think the short stem has made the bike a bit twitchy and I'm hoping to find something that will fit me better, especially for longer rides. I also love drop bars for longer rides although if touring bars would help with reach I could try those.
I'll probably start a new topic about this, but what are my options? Sounds like I either need to give up on a C&V tourer and save up for a 650b Surly or something, or find one of those 47cm Specialized Expeditions or small Treks and hope a short stem will be ok? (Custom frames are probably out of my price range, unfortunately!)
Quoted: 809 Post(s)
Liked 1,023 Times
Would you consider a mixte?
Bad example
Quoted: 825 Post(s)
Liked 212 Times
Alas, I suspect that most older steel bikes with 700c wheels are going to be too long, even if they are short enough in the seat post. There is only so much the manufacturers were able to do to cram wheels, cranks, pedals and so on into a small bike.
What I would suggest is to look for an early steel hybrid or mountain bike with 26” wheels. Those *were* made shorter in both the seat and reach, and with good touring wheels can be an extremely satisfying touring bike. The added bonus is that you can find quite good examples with 21 speeds or up, cantilever brakes, and plenty of braze-ons for racks, fenders, etc, all for a relatively inexpensive price.
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I routinely use a 60mm technomic stem and feel no twitchyness on my bikes. I think you get used to the way they handle pretty quickly.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Another thing to consider would be a 650b conversion. If you were thinking about 700c x 38's, 650b x 38's would give you more standover room.
Velo Mule - I’m actually going to go look at a Mixte, I just think they are usually heavy, low-end bikes?
Aubergine- are there any kinds of mtn bike that would be best suited for touring? I currently have a mid 90’s rigid frame Fuji Thrill that I love riding around town but it is so heavy and slow!
52telecaster - interesting. Maybe my perception of twitchiness is part of just getting used to a road bike.
Gugie - I’m more concerned with the reach than the almost non-existent stand over clearance. (Although if I was a guy I might be more concerned lol)
Thanks!
Thanks!
Quoted: 238 Post(s)
With your Motobecane you could try adding a front rack or basket and load it up to see how it handles. Usually, adding some weight up front will slow the steering somewhat. As @gugie pointed out, a 650b conversion could help out with the standover over.
As for possibly looking for a new frame/bike, a mixte or step through would be a great option to help with the standover. These can be hard to find though and may not alleviate the reach issue without new bars as well. I personally, think they look classier with some Northroads or Albatross bars rather than drop bars but you do lose hand positions. Raleigh, Motobecane, Lotus, Puch, Panasonic and Centurion models are nice makes. Some of these makers made high end models using Reynolds 531 as well.
Another alternative could be the 80's ATBs and 90's hardtail MTBs. Some of these had really nice tubing and lug construction as well. The original Specialized Stumpjumper and early 90's Trek 900 series come immediately to mind. These should have lower standover heights since they use 26" wheels. Top tube may be longer than desireable but it will be hard to find a 50cm reach regardless.
Best of luck in the hunt!
Bad example
Quoted: 825 Post(s)
Liked 212 Times
Mixte Bikes are simply a different design with two slanting top tubes running to the rear dropouts. They can be and are made with the same steel and components that you’d find on any other bike. In other words, you can find some Mixtes that are very light and of high quality. The problem with Mixtes is that although they have a low stand-over height, obviously, they are not necessarily short in reach.
Liked 630 Times
Since fit is an issue, possibly try to test ride a
Geogina Terry bike. I don’t know if she made touring specific frames, but the main question in this case may be how wide of a tire it can take.
It's probably reasonable to say that most mixtes were middle range bikes. Low end bikes tended to have double downtube 'ladies' style frames. There were in fact high end mixtes, especially during the bike boom of the 70s. Better models would have double butted frames and fancy parts like Campagnolo, Stronglight, TA, etc. First good bike I ever rode was my neighbor's older sister's fancy French mixte. It was revelation. That thing just floated up hills. So yes, they do exist, but they might be hard to find nowadays. A late 70s Motobecan Grand Touring mixte might be good. They were kind of upper mid level and sold in fairly high numbers. Other than that, as with finding all vintage bikes, you just need to be lucky.
A modern neo retro bike that's set up for 650B wheels to begin with is a good option also. In many ways trying to build all frame sizes with the same size wheels like they did in vintage days was a mistake.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
On the smallest frames made for 700c or 27" wheels, the helmetge gets weird. To make a short seat tube they would often raise the bottom bracket, work the result that the top tube remains as high as you'd expect with a bigger bike.
In that case, you can consider converting a frame to use 26" wheels, which will lower the bb and top tube nicely. Brakes are an issue then (you might have to have @gugie install cantilever bosses).
Cyclist
I'd switch to Soma Highway One bars, or use a threadless adapter with some modern drop bars. Vintage drop bars have an incredibly long reach compared to modern compacts. It'll bring things A LOT closer
I don’t know about the touring model, my commuter is an 89 MC1500 with a drop bar conversion. It has aluminium 700c rims, and with rack, lights and tool kit weighs in at 29lbs unloaded. Comfortable, just the right amount of frame flex for me (I like just a little), if I had to stick to one bike of the 3 I own this one would be it. As a touring bike I might be able to deal with a bike’s extra weight assuming performance under load. But then my grail bike is a Panasonic DX4000 or better, so they have me sold on the fee of the frame.
Likes For erina2:
Pedal to the medal
Georgina Terry
I'd recommend finding a Terry bike in a smaller size. Terry made bikes for women, who on average are shorter than men, so their smaller models use a 24" front wheel. The consequences of this are proportional TT to ST and consistent HT angles throughout their sizes- often times smaller frames have shallower HT angles to avoid the front wheel hitting the DT. They do offer touring models complete with cantilevers and extra braze-on's, though the common Symmetry model has rack mounts and double bottle cages so suitable for touring. I think you can fit 32mm tyres on the Symmetry.
Good luck!
Good luck!
Quoted: 5888 Post(s)
Liked 3,471 Times
26 inch wheel bikes make a lot of sense in small frame sizes. I'd search for a top end vintage MTB to convert to gravel/light touring or a Bridgestone XO series bike many (but not all) of which were built around 26 inch wheels.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
Good luck!
Good luck!
Commence to jigglin’ huh?!?!
