Another Touring Project - 84 Trek 520
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 267 Times
Apparently I'm going through a "Cantilevers and a good deal? I'll buy it!" phase. Found this Trek 520 locally, right up the street even, and couldn't resist. It's been hanging in a garage for years and appears to be completely stock, minus the saddle and well, the pedals are missing. It's pretty dusty and mucked up with bone dry grease, but I'm confident it'll clean up nicely. No surface rust and the paint looks flawless. Judging by the original brake pads and chainrings, it didn't see very many miles at all. Anyhow, I'll be doing a full teardown / rebuild and swapping a few parts.
I wasn't familiar with Helicomatic Hubs, but after some quick searching, I'm glad I have extra wheelsets to choose a good replacement. I'm not opposed to 27", but may lean towards a 700c conversion since I also have extra tires in that size. We'll see how it works out with the brake adjustment.
I know the 520 is situated below the 620, and 720 models, but gotta stay it seems like pretty sweet ride. At a glance, on par with my 84 Miyata 610. Hoping to start the deep cleaning this weekend and get it back on the road soon.
Likes For squarenoise:
Quoted: 394 Post(s)
Liked 346 Times
Looks to be in great shape. I'm not a fan of the helicomatics but, on the other hand, these look to have little use on them & those rims are decent. If you had a decent thread on freewheel hub, with similar flange dimensions, you could swap it with the helico, hopefully using the same spokes, and those wheels would probably last a good while. The front hub probably wont give you any trouble, it's just the rear helicomatic that's problematic. Or just clean out the old grease, regrease them, and get some miles out of them before worrying about it. If it were me, I'd want a nicer set of wheels eventually, but I'd be tempted to get some miles out of those first, unless somebody else wanted them. Man, it looks like it was never ridden! Great score!
Likes For Hobbiano:
Quoted: 99 Post(s)
Liked 267 Times
So far it's cleaning up real nice. Bottom Bracket had petrified grease, but luckily no pitting on the races. Cleaned out the very light rust inside the seat tube and fork and treated with T-9. Making quicker progress than expected!
Likes For shoota:
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Beautiful condition for that 520! Classic Trek subdued taupe/pewter metallic. Looks great. You'll find another vote for 700C whenever you decide to do it. I'm in a "Touring bike and a good deal? I'll take it!" phase, almost like cantis, except 1982 was the one year a 720 didn't come with with cantis, or 27" wheels (700C was spec'd, but the owner put 27s on, lol). Looks like you have the 24" size. 45.5cm chain stays, too. Very nice!
Likes For RiddleOfSteel:
Quoted: 99 Post(s)
Liked 267 Times
Let me know if you ever need help with a Tucson pick up. I could always store it in my garage until there's a convenient time for you to come down.
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 699 Times
I recently swapped a used heliocomatic hub back into an 83 Peugeot to replace a damaged one. Matchy matchy syndrome combined with the “try it out first in stock condition” complex. I did like the 13-30 range on the freewheel and it shifted nicely too. I won’t be going across state or country and have many bikes, so I will ride it until it gives up. It seems you have quite a few choices and perhaps don’t suffer from that “stock” affliction. Nice bike in nice condition. It would be impossible to pass up.
Quoted: 99 Post(s)
Liked 267 Times
I'll store the Heliocomatic wheels in my garage. Let me know if you ever need another replacement.
Quoted: 99 Post(s)
Liked 267 Times
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Congratulations!!!
You *might* need different brakes- I've read of some people having luck with DC 960s- but there's several sets of cantilevers that have enough adjustment to fit to 700C.
I used to not be able to understand why people would specifically get an old bike and throw stuff on there all willy-nilly. A little later I started getting more interested in components- and I stopped looking at bikes as "bikes," but rather a system of combined frame and components to create a bike. I think it kind of started with Suntour Command Shifters- because I wanted to use those shifters- I did whatever mental gymnastics that made it OK to upgrade a 1985 bike as if someone upgraded the bike in 1993 or so. Sometime later I finally figured out that "vintage" frames don't need to have "vintage" components. I am still encumbered by "classic" looking components- I do have trouble with black, plastic-y, swoopy droopy components on a "vintage" frame.
As far as the whole "matchy-matchy" thing- Stuff has to match- and by "match" I mean it has to go together at least to my own particular... idiom. Much like Trek built the tourers with the "eclectic mix" of components- like combining Simpex with Huret with Suntour. As long as things match in a cohesive functional and aesthetically pleasing manner- I don't like things being thrown together.
Speaking of "matching," I've always thought that Sakae CR crankset should have been marketed as a Cyclone crankset because it looks like a propeller or something.
Commence to jigglin’ huh?!?!
Liked 2,024 Times
I just came across your epic Trek 620 project, then realized... Oh! This is the guy with ALL the EPIC projects, haha. Big fan of your bikes and process.
Liked 2,024 Times
Those brakes should work just fine for 700C work. If you wanted to, finding a set of Shimano MC70 or MT62 cantis also works and happens to be period correct (if that's a thing for you). They look good and work well, too. They were original to my '85 620 when I ran cantis (MC70s), and handled the 27" to 700C conversion just fine.
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
Just picked up a new to me 84 520. Yours seems to have the headset listed in the catalog. How does it feel? I ask because the specks have the word "delrin" (1984 Trek Bicycle Brochure Part 3 - Touring Bikes). Owning a PX10 old delrin is a concern.
The bike looks great.
Last new bike 1991
Last new bike 1991
Quoted: 99 Post(s)
Liked 267 Times
Quoted: 99 Post(s)
Liked 267 Times
Updates!
The Dia Compe 960s KIND OF work, but not close enough for my liking. They have the most minimal, if any, vertical adjustment making the brake pad angle down too much. The pads would need to be filed down to make more contact with the rim, soooo I have a set of Shimano BR-AT50s on the way that should do the trick.
Same here! Stems and handlebars are usually were I lean classic looking versus actual vintage. Mainly because of the lack of options for wider bars and taller stems.
I can't decide if I like this crankset or not. I think it's a bit visually problematic for me. Like, it's okay from a distance, but almost too wacky looking close up. I have a Sugino AT crankset that's been in the "maybe sell to fund other parts" pile, which I'm now leaning towards keeping to put on the Trek.
I'm a big fan of the "figuring things out" factor and put a lot of value in that. Some people might ridicule the time and financial investment, but hey it's my time and my money and it brings me joy and a sense of accomplishment. Wrenching and riding are my therapies.
I LOVE the MC70s and have them on a couple bikes, one being a 27 to 700 conversion and they did work perfectly for that. I also have the AT50s on another bike which seem to be functionally just as good as the MC70s. I just picked up another set at a decent price so I should be good to go.
Here it is with the 700c wheels and 33.3 Jack Brown tires. I was hoping to make this a fender bike and there’s room in the rear, but not enough clearance in the fork. Weirdly I’ve almost always experienced the opposite (tight rear stays, roomy fork) on every other bike I’ve built up. My current preference is larger tires over having fenders, so I’ll stick with it for now and maybe re-evaluate when it’s time for new tires as I’m sure 28s with fenders would work.
Onward!
Onward!
Liked 2,024 Times
Man, sorry that the tire/fender clearance is limited. :/ Reminds me of any vintage x10 Trek up until about 1982 where the front had clearance for a decent tire plus fenders (say, 33s and fenders), and the rear was only 25mm with fender. Made zero sense to me and was the main reason I sold those frames, not wanting to dip into the 650B world just yet at that time.
Quoted: 117 Post(s)
Liked 71 Times
I rode one of those for a few years as a commuter and loaded tourer. Despite having less tire clearance than we seem to want these days I found it excellent to ride loaded, like the 30 lbs I had on it for spending a month riding around the North Island of New Zealand way back when. Even with mere 32mm wide tires it coped with both gravel and a touring load extremely well. 700c wheels worked with Mafac tandem cantilevers. Mafacs command a lot of $ but they will help 700c wheels fit some frames that were made for 27".
Likes For Feldman:
Quoted: 99 Post(s)
Liked 267 Times
Whelp, I’ve officially rabbit-holed this project. I initially intended to use a lot of the stock parts, but then converting to 700c (because I had extra tires) meant switching brakes (to reach), which meant switching brake levers (to match). Then paranoia set in about the headset so that’s being replaced. I also have several nicer “backup” parts, so I have a feeling I’m gonna end up with a completely non original build. Just waiting on headset and brakes to show up, then the rest should fall into place.
Quoted: 838 Post(s)
Liked 1,082 Times
That fender clearance in the front seems bizarre on this bike. How much the various mid 80s touring models offered in this regard is always interesting to me. I seem to have lucked out with my 86 Voyageur in this regard as it fits 35s with fenders in front and back comfortably enough.
It looks like you may have just enough room up front. Have you tried putting a fender in there just to see?
Liked 2,024 Times
Ah yes, mission/scope creep via component dominoes. Or just an all non-original build from the get-go. It's why I try to just buy framesets, knowing my inclination to put 'my' parts on bikes and use next to no original parts, save for maybe a headset and the cantilever brakes. Fear not!
@polymorphself I think getting fenders in there is going to be reeeeeeeal tough. That is not much room at all. I bet I could get PDW fenders in there, but I'd have to modify them to accept being right up against the fork crown. Certainly a challenge to consider, IMO.
Quoted: 99 Post(s)
Liked 267 Times
I have a 87 Voyageur with 32s and plenty of fender room. Good to know that 35s would work too.
Edit: 5 cm, not 1/2. Brain fart while reading the ruler.
Quoted: 838 Post(s)
Liked 1,082 Times
Originally Posted by RiddleOfSteel;22250791
[MENTION=472972
[MENTION=472972
polymorphself[/MENTION] I think getting fenders in there is going to be reeeeeeeal tough. That is not much room at all. I bet I could get PDW fenders in there, but I'd have to modify them to accept being right up against the fork crown. Certainly a challenge to consider, IMO.
Like super bizarre! It's crazy tight, maybe 1/2 a cm at most between top of tire and fork crown. I did try to gently squeeze a fender in there and there's absolutely no room.
Likes For polymorphself:
Quoted: 99 Post(s)
Liked 267 Times
Replacement headset installed and everything is coming together. Just waiting on the brakeset, then hopefully test riding by next weekend.
Parts List so far...
Tange Levin CDS Headset
Nitto Technomic Stem
Fairweather All Road Bar (Similar to Nitto Noodle, but shallow drops)
Shimano RX100 Brake Levers
Rivendell Silver2 Barends
Shimano Deore DX Derailleurs
Sachs Aris 7 Speed Freewheel
Sugino AT Crankset
Specialized Touring Pedals
Sugino AT Crankset
