Brazed Schwinn Varsity???
Bikes: 1989 Bonded Aluminum Tommaso, 1991 Schwinn World Sport, 1989 Giant Iguana
I just purchased a Schwinn Varsity that appears to be brazed. I didn't think any of the Varsity line were brazed. I don't have access to the bike right now so I can't provide Serial Numbers or photos. Have any of the sage scholars ever heard of a brazed Varsity?
Thanks,
Chainsaw
Thanks,
Chainsaw
Quoted: 380 Post(s)
Liked 106 Times
Unless it is really old and a 3 speed it is an electro forged bike. Electro forging looks like brazing. There might be a couple of spots where brazing was used but it isn't a brazed frame. Roger
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
A serial number will track down what it really is. There were '70's Schwinns that were fillet-brazed chrome-moly (Super Sports, Sports Tourers, and Superiors), but they're very distinctive. Post photos ASAP.
Jeff Wills
Jeff Wills
Bikes: bikes I like
Quoted: 14 Post(s)
I'm starting to think that some of these comments here are pranks.
" I don't have access to the bike right now so I can't provide Serial Numbers or photos."
Right!
Right!
Quoted: 809 Post(s)
Liked 712 Times
Well, it could be in transit. Cut the guy a little slack.
Jeff Wills
Jeff Wills
If by "brazed" you mean lugged, note that the Varsity was reintroduced as a lugged frame import in 1986:
Decrepit Member
Since electroforging is an edge to edge weld, there is one joint on electroforged frames that is brazed; the top tube to seat tube join involves the mitered edge of the top tube end joined to the round seat tube. From Marc Muller's article Inside the Varsity, the top tube to seat tube brazed joint is explained this way:
One way to verify that the frame is welded and not brazed is to use a magnet on the "fillets"; on a brazed frame the fillet will not attract a magnet, but since the "fillet" on an electroforged frame is steel, it will attract a magnet.
Steel "fillets" on an electroforged frame:
Brass fillets on a fillet brazed frame:
Originally Posted by Inside the Varsity
Schwinn engineers went to great lengths to create joints suitable for E/F, but one--the top tube to seat tube joint-- always escaped their best efforts. Remember, E/F is an edge-to-edge process, and this joint had only one edge, on the end of the top tube. For years this joint was hand brazed and polished, but finally an economical solution was found. When the end of the tube was mitered ("notched" in Schwinn parlance) its edges were also flared to fit up to the seat tube. The frame was placed in a fixture with the head pointing upward. Surrounding the seat joint were induction coils that heated the seat joint rapidly, melting a preplaced silver brazing wire. Yes, your Varsity had a lugged, silver brazed joint!
Decrepit Member
Good point; I assumed he meant fillet brazed.
Actually, I'm on vacation and picked the bike up the day before leaving so I don't have the bike right now ... Yea, right! Makes it hard to get serial numbers or pictures. When get home, I'll do the magnet thing on the joints
Chainsaw
Chainsaw
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
I'm guessing that even the older version 1953 Varsity was not fillet brazed but was electro-forged. Maybe @Metacortex and/or @Scooper could confirm.
The 1955 catalog page has a better depiction.
Bob
Bob
Calamari Marionette Ph.D
I don't need magnets to check my bikes. I can SEE and FEEL the EF joins right through the paint. Not exactly art. But I still love 'em.
Question for those in the know.
How were the seat stays joined to the seat tube/top tube? That has to be brazed, right?
Decrepit Member
Bob, the 1954 dealer catalog Varsity page indicates it's got an electro-forged frame, and the 1952 catalog features the exclusivity of the Schwinn electro-forged frame, although it doesn't specifically mention the Varsity.
Here's the 1954 dealer catalog page:
Originally Posted by 1952 Schwinn consumer catalog
ELECTRO-FORGED FRAME
...There's super strength in Schwinn's exclusive frame construction...with specially designed head and hanger features that no other bike offers!
Decrepit Member
Since the seat stays are side-tacked at the seat cluster, I think you're probably right but don't know for sure.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Apparently this was done after the top tube was flared and brazed to the seat tube, since the brief, localized heat from the contact spot electric welds would not be expected to disturb the brazed joint.
But it's also possible that the brazed joint was done after the seatstays were welded to the seat tube, just that the seatstays would then sort of be in the way.
Schwinn installed a glass bead blasting machine in Plant #4, its frame fabrication facility, to clean the high frequency induction welded joint at the top bar and seatmast, and the weld splatter in the seatmast to hangar area on Schwinn built frames. When the bottom bar and seatmast are welded to the hanger a weld splatter is formed, and when the top bar and seatmast are induction welded a carbon residue is formed around the mating parts. The weld splatter and carbon residue must be removed before the frame is primed...
The article continues to indicate that the bead blasting machine went into service in Aug. '75 after 6 months of extensive research and development, and that previously this carbon residue and weld splatter removal was done entirely by hand.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Let's see some pix of your 15 speed Peugeot!!
Commence to jigglin’ huh?!?!
Bikes: bikes I like
Quoted: 14 Post(s)
Hey genius, I said it was long gone and I was asking what model it could have been
Here is the question and I gave all the info I have.
Peugeot 15 speed info wanted
I bought a Peugeot triple crank 15 speed road bike back in the mid 70's. I did a complete, new everything except the triple, refurbish on the bike complete with a strip and spray bomb repaint. I am trying to figure out what model the bike was. The bike is long gone. It had the 15 speed set up with full fenders and a tall frame, probably 25". The bike was old and crusty when I got it so if I had to guess it was a late 60's or very early 70's bike, maybe older. Anyone know what it could have been?
Bikes: bikes I like
Quoted: 14 Post(s)
That "chainsaw" dude replied but deleted his follow up post. I'll say what I replied to him.
It's lazy and inconsiderate to throw out a garbage question like that and expect a thoughtful response.
What are we supposed to do! Ponder every kind of Varsity ever made that he might be confusing his with? I know some did just that, but he should have at least waited until he could supply the most basic information. I'm respectful of peoples time, I would never pose a question like that.
Decrepit Member
C&V is a pretty mellow forum and most of the folks here try to be helpful and are very tolerant of newbie questions.
Relax.
Relax.
Liked 1,703 Times
So what are you doing posting a thread about a bike you don't have? Is this some sort of prank?
What are we supposed to do? Ponder every kind of Peugeot ever made that you might be confusing yours with? I know you did just that, but you should have at least waited until you could supply the most basic information. You're not being respectful of peoples time, evidenced because you posed a question like that.
You've been a member here for almost a year. At the time I replied, you had all of 14 posts. In almost a year. Not so much of a contributing member of the forum. You're being rude to someone who quite simply asked "Have any of the sage scholars ever heard of a brazed Varsity?" That question does not require a serial number or pictures.
You, on the other hand, posted a "Anyone know what it could have been?" thread about a bike you had 30+ years ago. That guy asked a question that's answerable. You asked a question... that's not so answerable. That question requires some sort of knowledge about what you had, possibly nothing that a serial number or pictures would answer.
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Hey guys!
Let's keep it civil here in C&V.
Bikes: bikes I like
Quoted: 14 Post(s)
They were elecrtoforged. An electrical current was sent through the frame structure from two opposite points of the tubing interfaces. An arch was formed between the two points creating a weld to join the tubing together.
