Lotus Sprint
Fuji Fan
Lotus Sprint
I picked up this one off CL a few days ago to goof around on, but cannot find much information online. Even the Vintage Lotus Bicycles website does not have anything other than one photo. Does anyone here know anything? (Tmar, are you out there?)
(I apologize for the crappy photos.)
What is the tubing? I assume Tange, but I'm not sure. If it is, which kind?
Was this sold as a frameset only?
Any help would be appreciated.
Lotus Monomaniac
Quoted: 5 Post(s)
That's an interesting bike and I also hope someone can give us more information about it. I suspect the model was available from 1984-ish.
The tubing is Chrome Moly 4130 plain guage. I've only ever seen the frame in this color.
Do you have the serial number?
Quoted: 4722 Post(s)
Liked 3,039 Times
I definitely haven't seen one on those until now. Gut feel is circa 1983. I'd be checking the seat post diameter and pulling the fork to check for a date code and tubing manufacturer's stamp. Serial number may help.
Bikes: 1973 Mercian Pro, 1972-73 Peugeot Track, 1983 Lotus Competition, Early 1970s Bottecchia Pro/Giro, 2000 Bob Jackson Special Tourist, 2011 Rivendell A. Homer Hilsen; 1996 Franklin custom
I don't recall ever seeing one of those locally, and I saw lots of the messengers bikes where I work in the '80s. I'm impressed Lotus offered a street rideable single speed way back in the '80s, before most hipsters were even born. Marketed to bike messengers?
Fuji Fan
Thanks Snydermann!
Dang! I was hoping to pull it apart next weekend, but I might have to dig my tools out early.
I tried reading it before, but it is not very legible. I'll give it another try as soon as I can.
Edit: Appears to be 4121397, but is hard to read and I am not sure if there is something before the "4" or if it is a blemish in the paint.
Lotus Monomaniac
Quoted: 5 Post(s)
Most of the Pacific Cycles bikes I've seen have the serial number stamped on the seat tube. Pacific Cycles Taiwan started making bikes for Lotus around 1982-ish and their bikes show up in the 1983 spec sheet as the Elite, Elan, Prestige and Special.
Details in this Lotus Elite photo look similar to the Lotus Sprint.
Lotus Monomaniac
Quoted: 5 Post(s)
This photo of the Pacific Cycles Lotus Elite front fork also looks similar to the Sprint, minus the engraving. Some models with this fork crown were also chromed.
Note the Asian characters cast into the lug.
Quoted: 8 Post(s)
1984 Sprint
I ride my '84 Lotus Sprint hard every day, down on the drops. It's a lovely green-gray metalflake, 110 mm overlocknut rear, the flip-flop sporting 14 fixed, 16 free. 23-622 racing slicks. Campy Record quills and clips mate with Duegi wood-soled shoes of the same age, all still like new. One brake. Serial # 4121181 makes it practically a crèche-mate of the OP's. The number is preceded by a hint of a trace of an impression which we'll assume wants to be a P but it's not really legible. Definitely 4130 straight-gauge tubing. Nice tight bike.
Bikes: 1st Track bike: 1978 Speedwell titanium 1st Road bike: 2001 Independent Fabrication Crown Jewel
Quoted: 97 Post(s)
Liked 116 Times
I had a Lotus Sprint in the oxide green color (appears gray). It was a decent bike for tooling around town but I just couldn't get past the dull ride feel and sluggish response. My Trek 630 has nimbler handling and a plusher, way more responsive ride. The Lotus Sprint wasn't a bad ride - it just wasn't a joy for me. Straight gauge tubing really can't compare to double-butted when it comes to ride quality of steel frames. Sprints a heavy bike and would make a decent single speed commuter.
Liked 3,039 Times
The lack of a P-prefix on both samples would suggest that its absence is most likely not a manufacturing omission and that the bicycles were not manufactured by Pacific. Given the format, my leading candidate for manufacturer would be KHS of Taiwan.
Quoted: 8 Post(s)
Serial #
Incidentally: the Lotus weighs 1.4 kg < my custom bike fabricated of 531 and SL. That isn't to say the frame weighs less, though it may because of its geometry and lugwork; a track bike simply carries less material than a geared bike. I added a front brake and sturdier sneakers for road but otherwise ride it bare. The result is lively enough. I wouldn't compete on it, but for informal ITT and training it's just about perfect.
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 241 Post(s)
Liked 187 Times
Hello @kozmikarl,
Welcome to the forum.
Here is a link to another Lotus Sprint, from member @mkeller234, with a serial number that is not stamped deeply into the tube.
https://www.bikeforums.net/classic-v...n-its-way.html
KHS serial numbers starting in 1988 had a "U" as a prefix letter. From the serial numbers recorded for Lotus it appears that KHS was not contracted by Lotus until 1989.
The Lotus Sprint model is from before 1989.
Edit: KHS did not put serial numbers on the seat tube.
