Vintage Gravel Grinders
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
The ability to accommodate a wider tire, combined with the comfort of a steel frame with at least medium-length chainstays, is the main practical reason I lean toward classic touring and sports-touring road bikes of the 1970s, as well as older racing bikes. My other motivation is aesthetics -- they simply look right to me. I have put tires as large as 27 x 1-3/8" knobbies on one of my ca.1960 Capo frames, and it was almost as competent as my mountain bike on dirt roads, and much more fun on paved roads. Great all-rounder! Tire clearance is another reason I liked my 1980 Peugeot PKN-10 -- my son is currently running 700Cx35 tires on it, whereas my otherwise comparable Bianchi of the same general vintage can take a 700Cx28 only if the tire is smaller than its callout dimension, as is the case with Continentals, but not Specializeds.
Likes For John E:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
How the heck did you get 38c tires mounted on the univega? Just asking because not a lot of road bikes can handle a 38c which is one reason why 650b has become popular.
I started a thread on this a while back:
https://www.bikeforums.net/classic-v...tage-bike.html
Otto
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,800 Times
Most of my bikes go on gravel. All you really need is to stay away from skinny tires. The narrowest I run is 32mm, all the way up to 54. This means the bike has to be able to fit wider tires. Adequate brakes are another thing to plan on. Other than that, most any vintage frame will do, with gearing appropriate for where you ride (same as it ever was).
Late February in Arizona climbing up the gravel road of Montezuma Pass near the Mexican border - '76 Motobecane Le Champion:
2019 Cino - '73 Raleigh Grand Sport with 700c x 33.333
2019 Magical Mystery Tour - 1973 Raleigh Competition with 650b x 42 tires (pic stolen from @Spaghetti Legs)
Likes For gugie:
Quoted: 823 Post(s)
Liked 1,395 Times
This Mercian Vincitore road fixed-gear has probably gotten more of my gravel miles than all my other bikes combined. Here it's wearing 28 mm Paselas, but the bulk of those dirt road miles were on Continental Sport 1000s, which actually measure closer to 26 mm. I would ride to the start of a long stretch of dirt and stop long enough to flip the rear wheel around from my 70-in pavement gear to a 63-in or so gravel gear. It worked pretty well, even with the fenders.
Last year some event organizer type hosted an expensive little shindig ride, complete with entry fees and a barbecue plate at the end, over the fire and forest service roads my ride buddy and I have been exploring for years. I got curious about the route and contacted him. Seems to me he got a little touchy when I told him I'd already ridden all those roads on a fixed-gear with 28 mm tires.
Likes For rustystrings61:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
A few have mentioned the Varsity as a gravel bike, the steering is actually rather off-roadish but check the chainstay length, as anything much over 45cm starts to really tax the climbing traction, forcing the rider to hang back and possibly causing back muscles to fatigue. So maybe not a good frame for steeper terrain (not to mention the weight of the thing).
That was actually the problem(s) I had with my 1984 Stumpjumper Sport, after moving to SoCal with it's loose, dry slipperiness. I started using a 1991 Specialized Crossroads model, which actually worked better(!), wore that bike out in two years.
Sport touring bikes will usually be at or under 45cm chainstay length, which is why I prefer them to tourers.
small ring
Quoted: 438 Post(s)
Liked 925 Times
Definitely a tight fit. I keep the pressure low and the Challenge Gravel Grinders measure out to 37mm. Lots of room at the brakes (Tektro 559), but probably not even 2mm at the chainstays.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
my name is Jim
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
Likes For Chr0m0ly:
Bikes: Motobecane Le Champion, Raleigh International, Bertin, Raleigh DL-1 1980, Colnago Super,Follis, Bianchi Competizione, Brompton M6L, Black Mountain Monstercros
Quoted: 125 Post(s)
Liked 839 Times
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Pelizzoli 650B, 38's:
Davidson DIsco Signature, 32's:
Likes For rccardr:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
My first gravel grinder. 80's Raleigh beach cruiser.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Likes For stevel610:
Quoted: 601 Post(s)
Liked 781 Times
Recent gravel grind at ABQ
Quoted: 5888 Post(s)
Liked 3,471 Times
Quoted: 7348 Post(s)
Liked 2,471 Times
Love this thread.
Someone in the Mid Hudson (NY) Bike Club asked about our routes. I showed a route I had recently ridden which included a rough hiking trail, mentioning I had taken my road racing bike with 28mm tires. Someone piped in and said I shouldn't be encouraging people to do that route on road bikes. And he was right. If you're not experienced, the result would be bad.
Quoted: 81 Post(s)
Liked 221 Times
I guess my Covid project fits pretty well in this thread. I just finished putting this together a couple of weeks ago. It's a 1982 Trek 710 to which I added cantilever posts, a few other braze-on bits, and dimpled the chainstays to make some room for real tires. The end result works well with 650b x 42 Rene Herse Pumpkin Ridge knobbies. The tires are great on gravel roads, jeep trails and single track, but they're also amazingly fast on the 25 miles of pavement I need to ride before I get to the good stuff.
Likes For lonesomesteve:
Liked 3,471 Times
Quoted: 3811 Post(s)
Liked 6,707 Times
Before gravel bikes became a thing, they reminded me a lot of the the early days of MTBs. Old bikes were repurposed to handle gravel and it was a way of avoiding cars.
Vintage MTBs obviously make good gravel grinders. There are also some bikes that pushed the design envelope: the Bridgestone XO series (many of these had road geometry with 26 inch wheels), the Bianchi project bikes that were early forerunners of the 29ers, and the GT Tachyon bikes.
Here is a good piece on the Bianchi Project and GT tachyon bikes
https://www.bikehugger.com/posts/the...at-wasnt-700d/
I have a 1992 Bridgestone XO 2. The bike is a great gravel and all around bike with plush 26 inch tires and road geometry:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Two inch tires means never having to say you’re sorry...
‘88 RockHopper back to SS and drop bars after a brief dalliance with upright bars. I am sticking with the new Nitto stem adapter. It looks a bit chunky but is very well made and versatile.
Otto
Otto
Likes For ofajen:
This is almost exactly what I want to put together for myself as a second ride. Nicely done, must be comfy as heck.
Liked 3,471 Times
I feel lucky to have this bike. In the 90s, if you were thinking of making a road bike that could take fat tires, a 26 inch wheel made a lot of sense. 650b and 29ers were not yet a thing but 26 inch wheels had a big market presence with the mountain bike.
So thank you for pointing that out.
Bikes: ‘09 Ibis Silk SL, ‘08 Cannondale Synapse, ‘97 Cannondale R300, '96 CKC, '91 Batt., '86 Simoncini Cromor, '85 Allez, '78 PX10, '76 Gran Jubile, '73 Arctic, '73 Interclub, '72 TdF, '71 PX10, '70 Mondia SS, ‘90 Basso Paris Roubai
Liked 6 Times
A ‘72 or ‘73 Gitane Interclub with 650b wheels.
Bikes: '72 Fuji Newest, '79 Fuji Royale Gravel Grinder; '84 Schwinn High Sierra BMX Cruiser; '97 Huffy Tremor BMX
Quoted: 33 Post(s)
Liked 134 Times
Awesome bikes, everyone!! My '79 Fuji Royale grinder is one of my favorites. Newest update not pictured is a set of Shimano 600 clip-ins to match the rest of the group
Quoted: 4512 Post(s)
Liked 6,385 Times
I'm not a gravel rider by any stretch but have some insight that surprised me at the time.
Eroica Calif. 2017 this flew down a long gravel hill as fast as I could pedal, the faster I went the more stable it was, not loose and not hardpack, with 28's.
I was amazed and surprised that I stayed with it as while I am a downhill guy with nothing for uphill, I was grinning from ear to ear, maxed out with nary a twitch.
None of this is new, Merz, Wolf, Brandt, Ritchey and many others were doing it waaaay before it was ever a thing.
Merz had a very good handle on this, Wolf had him build many for this as they shared the same vision.
Quoted: 964 Post(s)
Liked 1,451 Times
All the components on my Trek cost more than the frame...
