Hydraulic disc vs mechanical disc brakes?
There are also a ton of frames out there set up for mechanical and they will continue to need support. This is the same thing that has happened with cantilevers, V-brakes, long pull calipers etc.... All still available. I doubt there will be any difference with mechanical disc brakes either.
Didn't everyone have this discussion 20 years ago re mountain bikes? I still have my Titus Racer X with mech discs and they still work great. Hydros have always worked a little better, but with a tradeoff of complexity. Cable selection has always been critical for mech discs.
Mechanical discs were a hassle, issues with noise, rubbing, etc.
My experience with hydraulic disc brakes has been far bar better.
No idea if they've improved mechanicals since then but I'd personally be hesitant to buy anything other than hydraulic for disc brakes myself.
sounds like you mech disk is not properly setup, also most newer internal routing disk brake frame is designed for hydro, for my Niner, I have to route the rear brake cable outside the chainstay, the internal routing creates too much bending of the cable
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
It really doesn't take much to haul a bicycle to a controlled stop. I have built 2 disc brake bikes in the past year and I went with mechanical disc in both cases. TRP Spyres on one and Spykes on the other. The Spyres took a little breaking in and are still what I would describe a s soft, but perfectly adequate for my touring bike. I put the Spykes on an MTB. I have yet to really challenge them, but I can tell they will serve me well in the mountains.
Comparing the hydros on one MTB to the Spykes on another several things stand out. The hydros are easier to finesse with one or two fingers in technical stuff, and that is where I think hydros really stand out. They are also a bit easier to accidentally lock up in panic or emergency braking. I took a good spill last year on account of an accidental front end lock up. That never happened on the mech disc brakes I had on my previous MTB. My hydros also decided to act up last year in a way that I couldn't fix myself, so it had to go to the shop as I didn't have bleeding equipment. I can't see the same thing happening with mechs.
For the OPs intended use I don't see hydros offering any tangible performance advantage.
Comparing the hydros on one MTB to the Spykes on another several things stand out. The hydros are easier to finesse with one or two fingers in technical stuff, and that is where I think hydros really stand out. They are also a bit easier to accidentally lock up in panic or emergency braking. I took a good spill last year on account of an accident front end lock up. That never happened on the mech disc brakes I had on my previous MTB. My hydros also decided to act up last year in a way that I couldn't fix myself, so it had to go to the shop as I didn't have bleeding equipment. I can't see the same thing happening with mechs.
J.
Quoted: 20810 Post(s)
Liked 9,456 Times
Completely agree. I doubt there will be any noticeable advantage especially if the brakes are installed with high quality compassionless housings. Compassionless housing is fantastic on any mechanical braking system but especially beneficial on mechanical discs with the long housing run. That done, I think it's going to be difficult to tell the difference.
J.
J.
Likes For WhyFi:
Quoted: 389 Post(s)
Liked 255 Times
I was watching the Amgen Tour of California on the stage when Alex Hoehn got the mountain jersey, and when the camera zoomed in to his Cannondale, I noticed he was using mechanical discs. I thought that was pretty interesting.
Farmer tan
Given me a whole new way of looking at bike parts. Hmmm.
no kidding. I fixed it. But I'm sure compressionless housing is, in fact, compassionless.
And this is interesting for sure. Wonder which brakes?
Quoted: 4408 Post(s)
Liked 4,861 Times
The Differences Between Mechanical and Hydraulic Disc Brakes: Hydraulic Disc Brakes have Hydraulic systems work with fluids. This type transfers force from the lever to the caliper, giving you a greater braking or gripping power level. Hydraulic systems work with fluids and transfer force from the lever to the caliper, giving you a greater braking or gripping power level. They offer maximum braking power that you can easily control. Compared to hydraulic disc brakes, mechanical disc brakes are quite basic. They are also known for being lightweight, which vouches for comfort and stability on your trip. In terms of budget, I recommend this brake type as they are way cheaper than others.
Quoted: 645 Post(s)
Liked 797 Times
I am going to be purchasing a steel frame bike and leaning towards the All City Cosmic Stallion but not sure about post mount mechanical brakes.
I will use this mostly on road but will do some gravel.
I know flat mount hydraulic is the future but for the price, I like the frame ed coating and reputation of the All City.
Thanks
Thanks
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
I cant say I ever looked at my disc brakes, mechanical or hydraulic, and considered one to be more comfortable than the other due to weight. And neither ever came to mind as being more stable due to weight than the other.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Mechanical disc brakes are lightweight which is why they are comfortable and stable?
Liked 9,456 Times
Likes For WhyFi:
Sunshine
Liked 7,490 Times
Quoted: 3952 Post(s)
Liked 7,297 Times
Likes For tomato coupe:
KonaRider125
Bicycle Mechanics
14
02-18-16 03:43 AM
mikepwagner
Commuting
7
07-26-11 01:27 PM
