Flared Bars-What am I doing wrong here?
I sweated through the handlebars that came on my Crux, so I decided to take the opportunity to get a set of new-fangled flared handlebars to put on there. In theory, I really like the idea of a flared bar--narrow and aero on the hoods and wide and stable on the drops where I usually descend. However, when I put them on, I noticed that my levers are way farther out than the drop handles, so my fingers have to do a backbend to get to the brakes--its incredibly uncomfortable and I can either cover the brakes or hold onto the bars...or be uncomfortable. Not sure it makes a difference, but the bars I got were PRO Discover 12° flare bars, and I've got pretty big hands.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
Watching. I've wondered about that myself. I like the idea of flared bars, but I also like the idea of always having a brifter within easy reach.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
You're not doing anything wrong, this is how they work. I've never had a problem reaching the levers but I can see how there would be an adjustment period
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
As a person with small hands, I appreciate when brake levers point outward a bit. Wonder if there's something you could do when mounting to counteract it.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I’m basing this entirely on the photo, so it may not be the case, but the levers look like they’re flared even more than the bars. Maybe align them in a more vertical orientation and see if this helps.
Likes For Rolla:
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
Odd.
My Salsa Cowchipper bars are 24deg of flare and 12deg of drop angle, but I can easily access the brake levers on the hoods or in the drops.
Maybe your SRAM levers are set at a point on the hook of drop bar that is angling them put more than necessaery?
Likes For mstateglfr:
Thread Killer
Quoted: 3143 Post(s)
Liked 1,707 Times
It kinda looks like the shifters are each on the wrong side of the bar…but that cannot be, can it?
Likes For chaadster:
Quoted: 4227 Post(s)
Liked 2,488 Times
Something doesn't look right, I think those levers need to be adjusted or maybe switch them around from left to right.
Quoted: 576 Post(s)
Liked 1,002 Times
My 16 deg flared bar doesn't look that far out, granted I have Shimano levers but that looks extreme.
Maybe it has to do with what is referred to "outsweep" in the below pic:
The Easton EC70AX has very little outsweep, whereas the Pro Discover Medium has a bit more.
Maybe I need a bar with a flare kinda like this? These are $$$ carbon bars though and I really don’t like spending >$100 on handlebars since they’re mostly disposable for me.
Likes For Phatman:
Lol. They’re not on the wrong sides. I know this is Bikeforums.net, but putting the levers on the wrong side is pretty hard to do when your bike is 1x.
Likes For Phatman:
Cyclist
The reach to the levers can be adjusted on Shimano levers, not sure if that is the case with SRAM levers. If you can adjust the reach that might help. You should also be able to rotate the levers inward a little.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
They're on the correct sides, for sure. The issue is that they're SRAM. They angle the lever outward just a skosh, look at a head on shot of a road bike with non-flared drops, and note that the tips of the levers sit slightly outside the lower bend. You could try to reposition the shifter, but I suspect that it will not greatly improve the ergonomics for you.
Likes For Badger6:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
That looks odd in that the levers flare a lot more than the drops do. My Cowbells are not like that with the 105 levers I use. The levers flare out about the same as the drops, maybe just a hair more, but not much.
Quoted: 1461 Post(s)
Liked 1,485 Times
My SRAM Force mechanical levers stick out to the side more than my Shimano GRX levers do.
That said, the photo in the OP looks pretty extreme. Here is what my GRX levers look like on the Enve G series handlebar:
Well I just did my third ride on these bars and they’ve got to go. I rotated them out and down a smidge and it made it a little more comfy on the drops, but now they’re uncomfortable on the hoods.
it looks like I need something like what he’s got vvv.
The Enve bars have the same type of flare/bend that the 3ts have, where it starts out more vertical where the hood clamp is, then goes out from there.
Too bad I can’t really do $300 bars, anyone know of an aluminum bars with that style bend?
Quoted: 1872 Post(s)
Liked 692 Times
I don't think this is true actually. The enve bars are shaped basically the same as your shimano bars. You just need to get a regular non-flared road bar, sram shifters just have too much flare built into their levers for you.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
I don't mean to be a dick, but did you see the pic that I posted from the Enve site?
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Liked 1,485 Times
For comparison, this is what my SRAM Force mechanical/rim brake levers look like on standard road bars with no flare. The SRAM levers definitely stick out to the side a lot more than the Shimano levers do. I've never tried these levers on flared bars, but I have a feeling they'd be poking way out:
I think I'm going to give up on this flare experiment and get the same bar I had before. It bums me out since I like the concept, but I can't be spending hundreds of dollars to try stuff out that will have funny lever ergonomics.
Sunshine
Liked 7,490 Times
Thread Killer
Liked 1,707 Times
OP, have you tried using the reach adjustment to bring the levers closer in to the bars?
There’s no reach adjustment on these levers, they’re Apex1. But even if there were, I don’t think it would help since it’s the lateral position, not the reach dimension that’s off.
