Seatpost Bolt / Clamp Housing Stripped!
I am disgustipated. Has anyone ever encountered this before? This bike I haven't had for a month, I tried tightening the seatpost with a torque wrench and the steel stripped into a fine taper. It's one of those notched bolts that locks into the mechanism. I'm not even sure what to call this piece, but it's on the frame, and now I can't get a proper torque to keep the seatpost from sliding down.
For future reference: What is the proper torque to set these to?
More importantly: How the frick can I fix this?
Quoted: 5789 Post(s)
Liked 2,581 Times
BITD this wasn't all that rare, nor was it common either.
Odds are that the bolt key was never properly seated, and once it started turning, it simply cut it's own path.
The first takeaway here, for the OP and anyone reading this, is that blindly turning nuts, even with the best tools, and even adhering to specified torques has the potential to screw (no pun) things up. As a mechanic you need to keep your eyes open and be attuned to what's happening. If the turning bolt was spotted early in the process, the damage would have been much more limited.
Fortunately, there's an easy way past this (in this instance). The OP can simply buy a cap screw, or hex head bolt, so he can hold one end while turning the nut. Or he can buy one of those double ended hex head binder bolts like these.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
No way! I've never seen this before! Never!!! !!!
Quoted: 4806 Post(s)
Liked 3,929 Times
I'd just go to Ace Hardware, buy the biggest SS hex head bolt that will fit through, a SS nut I liked, a few washers to sit on the outer flanges and use two wrenches. (Might want some wedgelike washers to distribute the load. I'd be looking through my odd parts for wedge shaped whatever I could cut and drill into washers.) I just did this on an old Miyata racing bike that spent real time left out in the rain. Threaded Campy-like seatpin stripped out early on.
Edit: and once again, FB beat me to it!
Likes For 79pmooney:
The thing that strikes me is I have that 33-year old gazelle with a similar mechanism and I've never had this trouble. The steel on that bike is far superior to this. The Gazelle has stainless steel underneath, where this steel doesn't look or feel anything like it. It feels way softer.
I found those binding bolts like you linked, after I posted this, and that does look like a viable solution. But, do you recommend I find a tapered washer as well, to fill in the gap? Or should I just leave it hollow?
I'm also wondering, should I try to find some beveled washers? If I put the binder bolt on there, the torque would apply unevenly due to the angle of the housing.
Liked 2,581 Times
Ideally the head will span across the top. Otherwise, I suggest a structural washer (a thicker machined disc vs. the typical flat washer), to take the load. Even if you could find or make a conical washer to fill the gap you wouldn't want too. The compression driving the cone inward will tend to spread the ear outward, possible cracking it.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 2,581 Times
SLIGHT!!!!! Have you learned nothing?
FB
Chain-L site
FB
Chain-L site
Quoted: 980 Post(s)
Liked 582 Times
Could some of the "spherical" washers used for brake shoes be adapted for this application? The bolt diameter might be too small though. Just a thought/
Here was my fix, at least for now. Marine-grade Stainless Steel M8 bolt, two extra washers, and the two washers and nut that came with the bike.
Ace doesn't have much of a selection of Stainless Steel Metric items. They had no beveled washers or structural steel washers. They did have a nice bushing that could have added some extra strength but it was zinc-coated, not stainless. It's holding the seat up at least, for now!
Liked 2,581 Times
Hopefully it;s just lighting and camera angle, but the left ear seems partly collapsed, and possibly touching it's opposite member.
If the ears touch anywhere, that will prevent proper clamping of the tube and you'll be over tightening to try to hold the post.
Take a look, and if it's not touching, all is good and you can file the above for future reference. Meanwhile, don't worry that it looks bad and that most of the pressure is at the base of the ear. That's actually in your favor since it minimizes stress on the ear itself.
FB
Chain-L site
FB
Chain-L site
