22-T cog for Raleigh 3-speed
Bikes: 1988 Bianchi, 2006 Fuji Absolute 3.0, 1973 Raleigh Sport, 1972 Bottecchia Professional
Quoted: 18 Post(s)
Liked 30 Times
I am restoring a 1973 Raleigh ladies Sport bike for my wife, and want to install a new 22-tooth cog on the original Sturmey-Archer hub. I see that 356cycles carries a "Sturmey Archer 1/8" 22t coaster brake cog." However, my bike does NOT have a coaster brake. Does anyone know if this will fit? When asked 365cycles got right back to me with this answer: "As long as the splines on your hub are the same as the 3 splines on this cog, it should work with your hub. " How would I know?
Thanks for any advice you can offer this bike-restoring newbie!
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...those things are pretty universal, and a three splined cog fits on all sorts of coaster brake and IGH hubs. Look at your old cog, in place on your wife's rear hub. You should be able to make out that it has three little thingamabobs on it, and is held in place by a snap ring, which you can remove and reinstall with a couple of screwdrivers and some cursing, if you don't have a snap ring plier. They are reversible and offset a little bit, so you can pick the position that gives you the best chain line.
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
...those 3 little tab thingies are the "spline tabs"
Quoted: 3811 Post(s)
Liked 6,713 Times
The Shimano Nexus cogs work, too, plus they’re dished and come in lots of different sizes:
https://www.universalcycles.com/shop...ls.php?id=4171
Quoted: 18 Post(s)
Liked 30 Times
Thanks, 3alarmer. I'm going to try it out.
