The People’s Liberation Drivetrains
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
Did anyone else read this article on Bikepacking dot com?
The People's Liberation Drivetrain - BIKEPACKING.com
I thought it was a good read, but my PLD is even more guerrilla. I have all the parts for a 1x9 set up that was going to go on my AWOL, but will now go on a future fully rigid 29er bikepacker/urban bike (or something else: whatever I get a frame for, basically).
I plan to run:
A Blackspire Snaggletooth 32t Narrow Wide Chainring on Deore Cranks;
A Sunrace CSM990 9-speed 11-40t cassette;
A Shimano Sora medium Cage derailleur with Wolftooth Roadlink; and
An Alivio trigger shifter.
I don't really need advice on my drivetrain, I as just wondering if anyone else had come up with a similarly cheap alternative 1x set up.
I plan to run:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
It would be nice if they just told us about the parts and how they work without all the drama and hyperbole.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
What the hell is the point? Is it REALLY... REALLY that hard to shift a front derailleur? This is on a bike packing website. You know, the people who load their bikes with 10s of pounds of equipment to go camp somewhere? A few ounces saved by eliminating a chainring is DEFINITELY going to help... /sarcasm
Quoted: 233 Post(s)
Liked 165 Times
I made a snarky reply, but I deleted it. I thought it was a somewhat interesting article, from a mechanical perspective, and I am personally interested in budget 1x drivetrains.
I get that 1x set ups are not everyone's cup of tea, but I was genuinely curious to get the opinion of other people about cheap and improvised 1x drivetrains.
Quoted: 239 Post(s)
Liked 7 Times
...except the one in the article isn't cheap, and with all those bleeding edge components, I wouldn't call it improvised either.
Very well, I'll tell you about my 1x:
For my fatbike, an SE Fat Ripper 26, originally a singlespeed, modified to be 7spd.
cheap origin-8 fat hub, using a 7spd cassette with spacer instead of a full 8spd cassette due to chainline considerations.
11-34 sunrace cassette
Surly Mr Whirly crankset with the widest spindle - as the frame was meant to be single speed and didn't have crank arm clearance for the narrow version.
chainring then had to be spaced back inwards with spacers.
26t surly steel ring
9spd shimano shadow derailer, chosen for its ability to handle the 34t cog
as well as it retaining the old 6/7/8/9spd pull ratio compatibility.
mounted to the track-ends frame using a wierd 'chain-tug-with-derailer-hanger' gizmo -basically a derailer hangar that mounts to your rear axle.
an ancient shimano xt m738 series 8spd shifter pod
because it's the nicest shifter that will work with 7/8spd drivetrains.
-vintage 8spd is better built than modern low-end 8spd
anyhow:
the 26t x 11-36 (yeah that's a tiny chainring!)
gives a low gear of 21.6" gear inches
which is just enough to get me up hills
and a high gear of 66.6" -I'm not that fast anyway, so this doesn't bug me.
The gearing range works for me, and being for offroad at low speeds the steps between cogs are just fine.
a sunrace cassette and 7spd chains makes for cheap replacement when things wear out. Which is good considering that tiny 26t cog means I go through a chain every 3-4 months.
In my opinion, 10,11,12 speed cassettes for going 1x drive are overrated for many situations. 7/8speeds is viable if you're careful with selection, and has the great advantage of super cheap chains ($5 for me, instead of ... $40+per)
Marketing is pushing for 1x10+ however, in that the rear derailers capable of handling the 40+tooth cogs are only available in 10spd and above, with a new dynasys pull-ratio that is not backwards compatible...
-my workaround, was a 'normal' sized cassette with a tiny chainring up front
sorry that wasn't well organized...
cheap, not too heavy, no bleeding-edge tech
anyhow:
I plan to run:
I can definitely see the appeal of 1x. I just need a stupid wide range for my riding. Bike 1-2 mi on flat pavement, extended climbs with 15% grade, followed by back down. The 15-18% slogs require a stupid low gear at my fitness level, and the flat pavement means that pedaling at 18-20mph is also good.
Quoted: 233 Post(s)
Liked 165 Times
I know, right? I actually mentioned that in a deleted reply. I liked the article, but I thought that his "budget" drivetrain was still pretty darn expensive; I bought three 11-40 9-speed cassettes for just a little over half what he paid for his SRAM 11-42 cassette. And no stress on organization, your set up sounds really interesting.
Quoted: 233 Post(s)
Liked 165 Times
It definitely is, but I am using what I have available and things within my n+1 project budget. I want to build a light urban bike for flat river paths with fat, slick tires that will probably never see a trail in its life.
Quoted: 239 Post(s)
Liked 7 Times
ah yes the clutch derailers.
Shimano marketing is clearly aware that the average rider's need for 10+ cogs is tenuous at best.
They encourage you to upgrade by withholding clutch technology from trickling-down to lower numbered drivetrain speeds.
my 7s bike has worked just fine without it, a slap guard on the chainstay to keep the paint from chipping, and a simple chainguide on the front ring as insurance against dropped chains.
Now, I actually do possess a clutch derailer on one of my other nicer bikes. It definitely prevents chain slap. Not a clear game changer for practical value though vs the older way of dealing with it...
Quoted: 233 Post(s)
Liked 165 Times
Quoted: 239 Post(s)
Liked 7 Times
not at the moment
here's a link to the Gizmo thing though
Problem Solvers
basically a chain tug, with a derailer hangar attached to it.
so you can take a singlespeed frame with track ends (rear facing slots) and mount a derailer on it
Problem Solvers
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
On my cargo/commuter bike i am running:
8 speed
This is the cheapest option while maintaining a reasonable number of options of cassette. Cheap chains, cheap cassettes.
Stock 22-32-42t chainrings
Gives me all the range to go up any hill with load, including towing a trailer. Most of the time i am in 32t but it helps to spread out the wear with the other two rings.
12-32t cassette
Lowest gear of 17.88 inches. 12t is chosen because of the closer ratio in the higher end 12-14-16- instead of the more common 11-13-15- which i find the 18-15 jump too big.
Altus M310 3x8 shifters
I have never found any grade of shifters to be deficient in precision so i settle for the lowest grade. And the gear indicator is below the bar, freeing up space for bells etc.
8 speed
12-32t cassette
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Yet, somehow, we dealt with rear derailers without clutches for most of 40 years now. One way to keep the chain from bouncing is to shift up to a larger ring on a downhill...Oh! But you can't do that on a 1x. Just another thing to add to the growing list of limitations
Stuart Black
Stuart Black
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Clutch RD's are a win, with or without an FD. I won't buy another MTB or another derailleur for a MTB without one. But that means 10-speed or higher. This isn't really a problem, 10-speed isn't that expensive.
The shifts on that 9x11-40 look pretty wide. There's now an 8-speed too Looking at the cogs I think it ought to go 16-19-23 and not 15-18-22
Genesis 49:16-17
Genesis 49:16-17
Liked 4,220 Times
At the beginning of time, the highest gear available for mountain bikes was a 44/14. This is an 83" gear and was frustratingly low. I found myself spinning out less than 30 mph and having to spend way too much time coasting.
The problem...on paper, at least...I have with 1x is the "either/or" nature of them. You can have a high gear or a low gear but not both. Why is that better? I can, and have, taken that triple and pushed it lower. Add a 36 tooth cassette cog or lower the inner ring on the crank to a 20 or both. That way I can climb anything and not have to coast for miles and miles on downhills. Plus I have lots of choices in between.
I (somewhat) get the simplicity thing but I feel that most people's problems with front derailers have more to do with the mechanic than with the mechanicals.
Stuart Black
Stuart Black
I'm with you. 1x systems may have a place in a closed circuit where the rider knows what to expect and doesn't need a lot of range. -snip
Benefits:
- Much wider gear range
- Cheaper
- Built in chain guide!
- Wear is spread to 2 or 3 chainrings so it wears more slowly
Cons:
- Slightly heavier
- Another shifter up on the bars getting in the way of the dropper post controls.
I'm not an idiot. I know how to get my left thumb to work with my right to get into the gear I want. And my brain is fast enough to do BOTH things very quickly. (And I don't even have to think about it! Imagine that!)
Seriously, what are the benefits of 1x? When's the last time someone ACTUALLY broke a front derailleur out on the trail? I've broken EVERYTHING on my bike, except the front derailleur. If someone says "simplicity" I'm just going to assume you're handicapped in some way because it really does not take a lot of brain power to shift two shifters like we've done for decades...
Quoted: 106 Post(s)
Liked 15 Times
I'm with you. 1x systems may have a place in a closed circuit where the rider knows what to expect and doesn't need a lot of range. But out in the real world, there are ups that need a very low gear and downs that are way too long to just coast down. I don't have a 1x system and I'm not going to go to one anytime soon because, on paper, they just look horrible. The gear train in the article offers this compared to a "normal" 9 speed triple. Similar low but there's no high end.
Quoted: 2484 Post(s)
Liked 2,956 Times
1X drivetrains with disk brakes, gigantic rear low-gear sprockets, and fat tires (and sometimes full suspension) = you really want a motorcycle.
Liked 4,220 Times
Evangelism works both ways.
Stuart Black
Stuart Black
Liked 4,220 Times
See: History. World. Religions.
See also: History. World. Religions. Politics.
Stuart Black
Stuart Black
I'm honestly surprised the 1x advocates haven't seen through the marketing. Minimal benefits, maximum price. That's the marketing strategy for bike "innovations" now-a-day. 1x included.
Tell me, what ARE the benefits of 1x? I know one that nobody has mentioned, but I'll let you guys figure it out.
