SRAM Force AXS 2 x mullet chainrings?
Hi, on my 2021 BMC Roadmachine I am running SRAM Force AXS drivetrain with the 36t RD (RD-FRC-E-D1), a regular (not Wide) FD (FD-FRC-E-D1), standard crankset (FC-FRC-D1) with Wide spider and 43-30 chainrings, and a Flattop 12s chain. I live in Switzerland and do a lot of mountain riding around Europe. I like to climb long steep cols slowly, and descend fast. This requires very wide range gearing. The 30-36 is my perfect low gear but 43-10 has me doing a great hamster impersonation on descents. IMO SRAM snatched defeat from the jaws of victory with their move to a 13 tooth chainring spread; my existing setup with 'standard' 46-30 chainrings would meet my needs.
How can I do this?
I have done a fair bit of research and no one seems to make after-market chainrings to suit 2 x Force AXS.
Happy to run a different chain as well as chainrings, if that will play nicely with the RD / cassette.
Thanks
How can I do this?
Thanks
Quoted: 514 Post(s)
Liked 448 Times
So basically, you're looking for a 46t outer chainring with a 94 mm BCD? Praxis makes 48/32 road and gravel cranksets. https://praxiscycles.com/road-cranks-final/
Sorry, can't get any closer than that.
Likes For oldbobcat:
Thanks for the reply. I am aware of Praxis and use them on other bikes. According to most sources, the only chainrings compatible with SRAM Force AXS are ... SRAM Force AXS. And what I need is 46-30 ... Will keep looking ...
