The DHell-1: When Thumpism goes dumpster diving at the co-op.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,398 Times
Those of you who follow the bottomless pit of beautiful British bikes in the C&V 3-speed fetis- uh, appreciation thread might remember thumpism's valiant rescue of a 21" 1981 DL-1 from his closing local co-op back in February, complete with one fork blade rotted completely off.
He stripped it down and kept the parts he needed, and graciously sent what remained to yours truly, mad scientist Dr. Frahmenstein.
"Hello, I'm a Raleigh DL-1. What's left of it."
First...blast the DHell-1 out of it with fire. After all, why fix it the easy way when you can fix it the interesting way?
This didn't exactly work, as the nails were still holding fast to the tubing despite grinding the tubing up to the crown reinforcement. I drilled them out since; we plan to try again.
But in the meantime, I got the next brilliant (yea, right) idea: Stick a huge Sturmey-Archer RXL-RD3 in the rear dropouts. Also known as "how to stick 135mm worth of hub in 110mm worth of rear triangle."
"I've seen this show before."
Before I pulled on it hard, I heard a bit of a creak. I discovered the chainstay bridge had already split sometime in the past. I'll either have Mike braze it, or I'll go into "get it done" mode by cleaning up the affected area, giving it two MIG tack welds, and calling it a day. The opposite side is clearly not that well brazed to begin with on top, so a bit of sloppiness here isn't going to make much difference. Nor will a rattle-can touchup matter either, whether MIG or brazed.
I went ahead with the cold setting, which really doesn't affect the chainstays at the bridge too much. 135mm achieved. Centered and with frame ends square:
I was also lucky enough to have this Alexrims DR13 front wheel on hand. Someone drilled it for Schrader, so it's fitting for a DL-1, even though it's no longer ideal for a road bike. I'd really like to find a matching or similar box-section 36h hoop to lace the Sturmey hub into - that's one of the main things missing from the build.
The tire came off an Electra Loft i7 I parted out quite a while back.
Meanwhile, I ordered some modern, black, pseudo-Lauterwasser bars off Amazon. This should prove to become an pretty funky build if I can get a pair of replacement blades shoved onto that fork. Pashley Guv'nor on the cheap.
-Kurt
-Kurt
Likes For cudak888:
DHell you say?! You are more ambitious than I. Definetly a challenge.
I.C.
I.C.
Likes For Insidious C.:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1233 Post(s)
Liked 3,575 Times
I'm all for you doing things the hard way, if possible. I'll bring the popcorn!
There were 135 Confentes, but only one...Huffente!
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Congrats! Looks much better at your place than it did at mine. I continue to revel in its absence.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3896 Post(s)
Liked 6,498 Times
Likes For SurferRosa:
Quoted: 3815 Post(s)
Liked 3,348 Times
interesting to see a tubular crown fork apart
had not before seen this and always wondered what might be going on in there...
have ofttimes wondered as to who made the ones employed by Fiorelli...perhaps a proprietary design done for them by Agrati or other Italian lug maker...?
Liked 4,398 Times
Plus, this build requires some sort of decent brake up front, so modifications are a necessity.
And go find me a rim
Go away, or I shall taunt you a second time.
I'll get some better pictures once the blades are off. Providing they come off.
-Kurt
Likes For cudak888:
The Huffmeister
Liked 3,575 Times
I don't know if these insinuating, fightin' words are directed at me, but they most definitely should be
Likes For AdventureManCO:
Liked 4,398 Times
Speaking of which, the DL-1 is technically stampedtastic. The rear frame ends are smushed steel and so are the fork dropouts on the '40s and '50s examples.
-Kurt
Liked 4,398 Times
Well, I might just need clubman's fork for this.
We torched the living daylights out of that blade to no avail. I thought it budged once, but that was wishful thinking. I have NO idea how this thing is wedged in there, seeing that the pins were drilled out.
Meanwhile, just to add to the excitement, this happened - thankfully when the torch was off, or else Mike and I would probably be Extra Crispy right now.
You might notice that the lines to the torch are new - those were added that morning - but the acetylene-to-flux tank line wasn't new and had deteriorated from UV. We were moving the bottles and flux reservoir after failing with the fork as part of a cleanup, and this tore right off. The line still had pressure too, sending a fair amount of acetylene out. I usually run into Mike's shop, this is the first time I've run out of it.
The second tear I was able to do with my hands. Morals of this story: 1. Just because a line appears OK doesn't mean it is. 2. Keep them away from UV. 3. Purge your lines before moving anything. 4. It's silly to have a flux tank and not have it on the same cart as the bottles.
-Kurt
-Kurt
The Huffmeister
Liked 3,575 Times
The second tear I was able to do with my hands. Morals of this story: 1. Just because a line appears OK doesn't mean it is. 2. Keep them away from UV. 3. Purge your tanks before moving anything. 4. It's silly to have a flux tank and not have it on the same cart as the bottles.
-Kurt
-Kurt
Liked 4,398 Times
I, myself, am grateful that I have lived to see your Huffy another day. Something like that, anyway.
-Kurt
Likes For cudak888:
The Huffmeister
Liked 3,575 Times
As am I. It's always good to have people geniunely concerned about you
Liked 4,398 Times
Good 'ol Mad Honk - with a little donation by Harry Havnoonian - came to the rescue with a Long Shen-based fork crown for this build.
Now, initially, I thought this wasn't going to clear the tires I had in mind, but - thankfully - I was wrong. I dug up a pair of extra-length Cromor blades in the pile of tubing that I got from Mike, which I hope I'll be able to bend correctly.
The steerer got brazed to the crown today. Nothing pretty here, just functional. Results picture soon.
Harry also gave us a pair of socketed dropouts; turns out these do not work with the extra-length Cromor blades. I traded them to Mike for a pair of conventional tab dropouts.
-Kurt
-Kurt
Likes For cudak888:
Likes For Reynolds:
Liked 4,398 Times
Quoted: 3464 Post(s)
Liked 2,831 Times
I like that bike very much. Fiorelli did give the upper tier frames extra effort, the seat lug ears are filled with a tube, brazed to fill voids and cut back like the top tier Italian builders did.
Likes For repechage:
Quoted: 1627 Post(s)
Liked 630 Times
You people are sick.
Liked 3,348 Times
Likes For juvela:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4685 Post(s)
Liked 5,823 Times
Are those lawyer lips I see on that dropout? File them off! Not period correct, lawyers didn't take over bicycle design until much later...
Likes For gugie:
Liked 4,398 Times
If it wasn't for the existing front hub, this thing would be getting discs. Look away when the canti studs go on
-Kurt
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1093 Post(s)
Liked 1,840 Times
Is that a "LC-17" crown? If so, nice score. They are getting harder and harder to find.
"Leave the gun. Take the Colnagos."
Liked 4,398 Times
Crawlin' up, flyin' down
Quoted: 1033 Post(s)
Liked 2,542 Times
Likes For bikingshearer:
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
Keep us posted with the progress.
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
