Helix Update?
#2326
Quoted: 54 Post(s)
Liked 175 Times
That’s quite a novel approach to a collapsible bike fender. My only reservation would be the requirement of rear seat stays/bridge which the Musguard requires and which the Helix lacks. There are fenders that attach to the seat post but don't know if this would be a viable solution as they would also have to be removed.
#2327
Quoted: 54 Post(s)
Liked 175 Times
Similar in design to the Plume is the Chameleon. Only caveat is that it has to be removed but the mount could be left in place. It also rolls up easily. Jury is still out on whether either of these products will adequately provide sufficient coverage.
Chameleon fender |
Edit: Another glance at the website indicates that the Chameleon can remain on the mount and rolled up.
Chameleon fender |
#2328
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 394 Post(s)
Liked 778 Times
To the number of people complaining about the inability to fit mud guards, I'm rather surprised that such solutions aren't more talked about https://musguard.com/
it seems to me that a foldable mudguard is the ideal attachment, if not the ideal look or protection...
What do you think.
What do you think.
#2329
Widely Despised
The latest update is out.
It says that we'll have an update in a few days.
- Production numbers
- Lighter weight parts group
#2330
Quoted: 20 Post(s)
At this stage it's starting to look a bit ridiculous that they still insist on closed updates. Production has started, public offerings have started, it is doing them a disservice at this point not to open everything.
#2331
I want lightweight parts.
Stem integral carbon handlebar and full titanium bolt
In addition, upgrading to carbon cranks and carbon saddles reduces weight by more than 1 kg.
Upgrading lighter parts will raise the price
#2332
Quoted: 800 Post(s)
Liked 247 Times
The lightest carbon crank like the THM Clavicula SE will maybe save 200g.
The lightest saddle like AX Lightness weight at least 65g and will maybe save 200g too.
These two components cost about.. the kickstarter price of Helix !
#2333
The weight gains could come from something as simple as tires, rims & butted spokes, which doesn't have to add much to the price
#2335
If you order a 1000 or so tires and rims, manufacturers will build the model you want, rather than being limited to "stock" models. And seeing as 507 is a rare size, Helixs production numbers may be sufficient for their own spec now.
All totaled, a pound (450g) can be shed on the rotating weight alone. And we all know how important that weight is.
#2336
Quoted: 800 Post(s)
Liked 247 Times
60g per wheel saved with double butted spokes and because they are stronger, the number could be reduced (unlikely as the front hub is custom)
And anyway, the tire used isn't very heavy, a tire that would save a lot of weight would be a lightweight road tire usable only on good, clean road.
Same for the wheels if the number of spokes is significantly reduced.
Helix is an allround folder, not a competition/sport road bike, it need strong enough tires and wheels.
#2337
For tires manufacturers, 1000 pieces is a ridiculously low amount that doesn't cover the cost of developing a new tire, even a new size of an existing tire.
The Kenda tires are mid-range, low thread-count, with a puncture belt that really slows you down. It probably gobbles up 40 watts to make it roll. There are plenty of touring tires that use up well under 20 watts, and are at least 25% lighter and just as tough. Better materials and technology, just like the frame.
#2338
Quoted: 800 Post(s)
Liked 247 Times
Even a new size of an existing model needs to make tooling, then test and validation before being commercialized. This cost money and 1000 tires produces a ridiculous revenue (let say 30USD per piece, that's 30K end user price, much less for the manufacturer).
#2339
It seems you are arguing for arguments sake. I have nothing to add beyond the facts presented before (based on experience as a bike distributor). Let's wait and see what Helix announces. By the way, I helped Peter with the early spec of the bike.
#2341
Quoted: 800 Post(s)
Liked 247 Times
In order to do so, they must have enough margin on their products. Most companies have internal rules defining minimal margin's on their products.
They won't make products on which they do not have enough margin and with only 1000 pieces, the fixed costs to make a tire in a new size won't leave enough margin.
Remember also that what is needed is an high end lightweight tire, not Chinese low cost shhit.
#2344
Quoted: 800 Post(s)
Liked 247 Times
Sizes in inches are unclear, you should always use the ETRTO size, ETRTO 507 for Helix (there are many other 24"sizes, for instance ETRTO 520, ETRTO 540...).
The Tioga Powerblock should fit for the size.
But is a BMX tire, not made for road use, its durability and puncture protection in case of road use is questionable.
#2345
I believe the swingarm has been modified a while ago to accept slightly wider tires - Tioga Powerblocks 24x1.5 fit for sure. Tire height might be more of an issue now, on the front taller tires would hit the pivot holder.
#2346
Quoted: 54 Post(s)
Liked 175 Times
Alas, still no update. My hope for a May delivery date is slowly diminishing. I suspect nothing startling will be revealed in the next update. Let’s hope that I’m wrong.
Likes For Batstar:
#2347
Quoted: 44 Post(s)
Yeah, I'm feeling the same way about my June shipping date :/ Peter is not good with realistic time estimates, and by now he really should have learned to just double the amount of time he thinks something will take to get a somewhat realistic estimate. Recent updates have been announced a week or more in advanced before the update finally arrives. Although the frequency of updates is much better than when I first started following Helix, it's still not great considering how easy it should be to write a short update saying what's going on and where things are expected to be by the next update. It's certainly an easier task than designing a folding bike, setting up a factory and building a company
Likes For MrFlamey:
#2348
Latest update
There has been an update.
272 bikes shipped thus far. #300 expected in two weeks time. #400 during March. Another hand to be added to assembly. The infamous Corona virus made some obvious delay, but it seems to be solved.
If they can stabilize for now on 100 bikes a month (speculation), then I hope my first bike, scheduled on May, will ship before October. I take that as good news!
Likes For AvnerBen:
#2349
Quoted: 54 Post(s)
Liked 175 Times
The ultralight components sound intriguing. It would be great if they were made available in time for customers who would like the option of swapping out stock parts prior to taking delivery of their bikes. Not sure what Peter had in mind with respect to this offering.
Unfortunately, accessories will likely face more delays for now (no real surprise) but another CNC machine is apparently arriving soon to help speed up production. It also appears that a new customer liaison has been tasked to respond to our email inquiries.
Brief progress updates with numbers are supposedly to be posted every 2-3 weeks now which is encouraging to hear. It’s also probably safe to assume that new delivery dates for our bikes will soon be revised in the portal.
Likes For Batstar:
