New Project
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
New Project
1993 Specialized Stumpjumper
I decided to get a project bike and found this one online for cheap. The shifters don't work and it has a 24" wheel in the rear on what should have been a 26", the rear brake pads were taken off since they would pinch on the tire. Good thing some parts are fairly cheap.
My thoughts on this project are to convert it into a gravel bike for even cheaper, since I already have the drop bars, a set of 10 speed brifters, stem, quill adapter and derailluers.
Any thoughts on this project?
Likes For cyclist2000:
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Cool! Love the color. I wouldn't bother with changing to drop bars unless you are planning on longer distances. However, if that's what you want there is a long thread in C&V for inspiration. https://www.bikeforums.net/classic-v...nversions.html
Quoted: 305 Post(s)
Liked 2,038 Times
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
If you are using road shifters, you will need to use a road front derailer. The only issue is that if you are using the triple mountain bike crank, you’ll probably need to move the crank inboard because the chainline for the mountain bike crank is too wide for the road front derailer. You’ll likely need a shorter spindle on the bottom bracket. But you’ll have to watch how far inboard you go because the chainrings can hit the chain stay if you move too far inboard.
Stuart Black
Stuart Black
Quoted: 305 Post(s)
Liked 2,038 Times
Liked 4,219 Times
I’m not trying to persuade you against using the mountain crank. It has a better range than road triples. I’d try to make the mountain triple work before giving up on it. Just be aware of the issues and have a back up plan…which you do have.
Stuart Black
Stuart Black
Quoted: 305 Post(s)
Liked 2,038 Times
You got me thinking about this project and my other thought is that I have a set of shimano 10 speed bar end shifters in my junk box and some old aero brake levers. I think the set is 3x10 and the left side is friction. That would take care of the front derailleur issues (I hope). I also have a set of shimano aero brake levers that could go with the set.
Mega Clyde
I was looking at your brakes and it appears that you may have V brakes on the back and cantilevers on the front. It is hard to tell from the picture so please disregard if I am mistaken.
If you have both V brakes and cantis then you will need to make sure you have compatible brake levers for the two different brake types or switch out one or the other. V brakes usually need long pull levers while cantis use short pull levers.
I just did a drop bar to alt bar conversion and used Shimano Sora flat bar levers to support the cantis on my Surly LHT. I will be upgrading them to V brakes in the future and those levers support both long and short pull. I think they have a drop bar version as well with the same feature.
Good luck with the project and enjoy it.
Likes For bigwies:
Quoted: 305 Post(s)
Liked 2,038 Times
I am still trying to decide what to do with this project. I just found out that the brifters for option 1 of the gravel build is being used, the bar end shifters for option 2, may not be to snuff. So I am trying to decide between keeping it as a rigid mountain bike getting new brake levers and shifters (these are integrated brake and shifters) and the current shifters are not working, or the original idea to convert it to a gravel bike.
I also found out that I am getting a diamondback bike donated to me that may be better for a gravel bike, it has disc brakes and 1x11 brifter on it but without a drive train.
so much to decide in the next few months. Also with high price of new and used parts, it may be better to wait until the supply issues are resolved.
Quoted: 305 Post(s)
Liked 2,038 Times
Well this project took a 180. My brother-in-law were talking bikes and he was getting rid of a Diamondback Haanjo. He donated it to me. It was in pretty good shape sans drivetrain.
So I had two projects now, the Stumpjumper had crappy shifters (not working) and these were integrated with brake levers and the Diamondback. I decided to bring them back to life in somewhat original form. Since I was getting new shifters I decided to go with a 10 speed rear end and keep the triple up front. I got a few parts and put it together, but there was some skipping in the drivetrain and the brakes wouldn't stop me on the test ride. Turns out that the rear derailleur that I had in the spares box was for a 9 speed. Well, back to the workshop, I got a proper derailleur and new brake pads. Everything worked great on the next test ride.
Quoted: 14 Post(s)
Liked 157 Times
Looks like a nice little pastime. I think I might do something like this soon just to play around with bikes a bit more. I haven't checked the second hand market around here but with roofs to fix and solar panels to put up it will be a little while before I start thinking about it.
Quoted: 305 Post(s)
Liked 2,038 Times
It is a nice pastime. I get to play with my hobby. Do some problem solving. Read up on the newer gear. On this diamondback, this has been my first chance to play with disc brakes.
