View Poll Results: What is better for Crit racing
Mechanical disc is better
5
20.00%
Rim brake is better
20
80.00%
Voters: 25. You may not vote on this poll
Mechanical disc vs rim brake for crit racing?
Quoted: 7652 Post(s)
Liked 3,473 Times
I would wager (not really since this is a wild guess) that the tiny weight saving gained by underbuilt calipers is not the factor determining where you finish.
Try Some Shimano Ultegra calipers (or better, but I cannot say.)Ultegra rim brakes are the best rim brakes I have used and IMO better that the Spyre C brakes on my Fuji (never did a scientific test, but ... ) I am not sure how much more an Ultegra or Dura-Acer caliper weighs compared to a Campy Athena or whatever ... but I bet it is less than the weight of the disc setup.
Notice that as long as disc brakes have been around, they didn't become commonplace in pro racing until a few years ago. Pro racers don't like them, didn't want them, and they held out as long as they could. The only reason TDF bikes (for example) have disc brakes is because that's what the sponsors are selling to the consumer market.
Quoted: 1109 Post(s)
Liked 1,200 Times
I found a good price on some 105 calipers on Ebay and put them on her bike thinking that if she didn't like them as much as the Ultegra, I'd replace them and use the 105 myself. She told me, to her, they functioned the same, i.e. good and they seemed to be as stiff as the Ultegra. Anyway, the good calipers with good pads made a large difference to her, and she's not a rider who notices subtle things at all, not a bike nerd at all. I'd never used cheap calipers in the time since I became an "enthusiast" about 30 years ago: only Ultegra, Campy Record and Sram Red and Force. So I didn't realize how much difference it can make.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 973 Times
Shimano R8000 rim brakes... Installed a set of these on a road bike yesterday, and spent a couple of hours alternating between gasping and cursing on the climbs and then 100% attention span fast twisty descents. Just going up and down. Brakes were excellent. A couple of weeks ago I was on a bike with the entry-level Campagnolo Centaur 11-speed groupset. Wow - among the best braking I've ever experienced on a road bike. These are not expensive calipers, but when combined with the Centaur Powershift levers, produce braking as good as I'd ever need. Perhaps the stock Campy brake pads helped as well?
Somebody mentioned Dura-Ace 7403 dual-pivot calipers - also among the best road brakes I've used. These are heavy and over-designed, but excellent stoppers.
Nevertheless, all of these calipers feature better stopping power in the dry than the mechanical disks on my Giant 'cross bike.
Steel is real
Quoted: 670 Post(s)
Liked 973 Times
I have only ridden in London, one of the main places is Herne Hill Velodrome - the available surface area is pretty small, so it's usually very twisty, fitting as much track into a small area as possible. I have seen some videos though where the track looks pretty mellow - like Abingdon airfield, but the whole interest in crit to me is the technical aspect. I actually find when I am riding crit - it improves my MTB riding! .
But really - its no big deal. I just wondered whether I could get better fine speed modulation with less finger pressure, like I've become accustomed to on my MTB. And only by swapping out some parts in my spares bin. Sounds like the consensus in crit is that discs don't offer any real benefit, especially not mechanical ones.
I might still go ahead and try it out for a laugh later in the season! There's not too much I've seen online pitting mechanical disks against mechanical callipers. Would make an interesting write up.
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
I hope I see your future opinion about crit-ing with discs vs calipers. I'd like to know how it goes for you.
Likes For RB1-luvr:
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Looks as if your two pages have netted two opinions from actual racers so you may have maxed out.
Likes For shelbyfv:
Interesting - I will look into higher level campy callipers. The anthena are skeleton thin and flex visibly under full lever force. I actually deformed the front calliper once, doing an emergency stop when someone walked out in front of me. The whole thing folded down just enough that the pads were touching the fork blades.
I have not ridden on the new shape 12-speed era Campy brakes. Regardless: there are excellent road rim brakes out there, which is something that the trend-focused bike industry wants you to forget. Being a bike mechanic in a busy Co-op, I've dealt with the many folks that come in wanting 'disc brakes' are amazed with the transformation when we install new pads, housings and cables, and actually set things up correctly. Many new bikes purchased, even shop bikes, were never set up properly right from the start.
Direct mount rim brakes sort of got passed over with the introduction of disks. I have DM DA brakes and they are very good. Pad quality for your conditions are also very important for good braking and that applies to whatever you use.
Likes For popeye:
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
it pretty much did. When everyone was on rim brakes, even at the Pro tour level it was more common to do a wheel change for a flat than a bike swap.
You could get lost and die.
You could hit a tree and die.
Steel is real
Quoted: 670 Post(s)
Liked 973 Times
I was riding a bike with Chorus skeleton brakes last week; dual pivot on the front and single on the rear. The braking was good, with Campy's excellent pads, but not as good as the lower-level Centaur 11 calipers. So this may be the case where the lower-tier component performs better. Or maybe it was the matching of the Centaur metal levers with the Centaur brake calipers and the Centaur pad compound. In any case, excellent braking.
Likes For georges1:
Likes For ummed:
I just got direct mount eeBrakes, and they are amazingly good. Although to be fair I'm comparing to brakes that were fairly widely criticized...
Quoted: 2952 Post(s)
Liked 3,106 Times
That may be true, but the racing that’s the subject of this thread is local criteriums, not UCI grand tours. We still have wheel pits near start/finish, and you see riders needing to swap wheels if they flat. I’ve had to do it. Hopefully you’ll have an official who knows how to time your release back into the race. And then make sure you don’t forget to go retrieve your pit wheels before you drive home. (Which I’ve done.)
Likes For caloso:
Quoted: 4407 Post(s)
Liked 4,860 Times
Yeah. Bike swaps happened but it was usually if there was a larger problem. At some point it started to become fashionable to swap bikes out for different purposes... ride the aero bike on the flats and then swap to the climbing bike for the HC finish. But the current trend towards bike swaps for the majority of the time is because of discs for sure.
https://www.cyclingtips.com/2019/07/...-change-wheel/
"There’s more time to be gained or lost in the skill of the mechanic than in the type of axle and brake used by the rider."
Quoted: 10236 Post(s)
Liked 5,184 Times
Rim Brakes.
Having done technical support, ask yourself if you trust your disc wheels to be leaned against or onto by other wheels, with, horrors, quick release levers ready to stick themselves into or hang up on the edges of your discs. Pulling either wheel out could tweak a disc.
In the pre-lawyer tab days a front wheel change was a five to seven second deal. A rear was eight to ten seconds on average. Less for both if the rider pulled the wheel before we got there. Matter of fact, a ten second rear was pretty easily accomplished. Watch the classic bike movie Breaking Away where Rae Dawn Chong (Tommy’s daughter) changes a rear about that quickly. She was taught how by Bill Woodul who had done tech support for Campagnolo, before I was there, and Specialized.
As a former real old school crit racer, ditto on braking. You normally would feather the brake for corners if at all. If you have to really hit the brakes something bad has or will happen and modulation is irrelevant.
Improved modulation/feathering was the original query; can mech discs improve on this. Sure in an ideal world, modulation is of no interest, because you're so awesome that you never need to actively reduce speed. But really, if you're at my (lesser) level, and riding the courses I ride (tight, technical, hairpins) - modulation is super important. Its always a topic our coaches focus on at training.
I was amazed how much more fun I was having when I used my hydraulic disc CX bike at crit training, since I could so much better feather the brakes and make small speed adjustments, which helped me to work on improving my cornering technique. My current flexy Athena calipers are inferior to my Rival hydraulics concerning modulation. But I did get some good suggestions here about new pads and potentially better calipers.
I think to further my point regarding modulation, it might be worth seeing the this video from GCN and UK crit champ Alec Briggs:
At around the 6 minutes mark, they actually focus on the benefits of discs for modulation.
Likes For maxants33:
