Team Miyata tire clearance?
Quoted: 539 Post(s)
Liked 466 Times
I have an opportunity to purchase a Team Miyata. I own an 83 model 610 that I have converted to 700c with 38mm tires. Out of the 8 bikes I regularly ride it gets the most use. I do own an 18 lb Reynolds 853 Lemond for my racy bike but it is limited to 23mm tires.. How large a tire will a Team Miyata clear? Are there any insurmountable issues in converting to 700c? I would love to own a Team Miyata but don't want a heavier and older racing bike that won't take at least 32mm tires. Thanks for any advice. I did search but came up without much info.
Quoted: 3811 Post(s)
Liked 6,717 Times
FWIW, I converted my Lemond Buenos Aires to 650b x 38mm wheels. Light, racy, and plush tires (win, win, win).
Quoted: 539 Post(s)
Liked 466 Times
I tried 25mm tires on my Lemond. Very tight in the carbon fork. They were doable but not enough benefit to make it worth buying a set IMHO, so I just kept it racy with 23's. I'm not sure how much a 650b conversion would gain me. I like it racy . Point is I have bikes for the full spectrum. I don't really need another narrow tire racer though.
Quoted: 5888 Post(s)
Liked 3,472 Times
snip . . . How large a tire will a Team Miyata clear? Are there any insurmountable issues in converting to 700c? I would love to own a Team Miyata but don't want a heavier and older racing bike that won't take at least 32mm tires. Thanks for any advice. I did search but came up without much info.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 3,472 Times
Best way to find out is to measure. Assuming it has tires on it, you (or the dealer) could pump up the tires and try bigger and bigger allen wrenches between the crown of the tire and the brake calipers/bridges. And between the sides of the rear tire and the chainstays. That gives a rough idea how much bigger you could go.
Likes For bikemig:
WHAT YEAR Team Miyata? Specs change from year-to-year!
FWIW, the Miyata 710 changed dramatically from 85 to 86. My '86 710 will < barely > take a 700x28mm tire, whereas the '85 has a different fork. that will allow taller/wider tires.
Pic of my '86 710 with brand new 28mm tires. BARELY 1mm clearance between tire and fork crown.
Car free since 2018
Bikes: Mostly japanese ones
Quoted: 259 Post(s)
Liked 269 Times
Quoted: 3241 Post(s)
Liked 2,512 Times
I have a 90 TM. 25 is the limit for that one.
Quoted: 2339 Post(s)
Liked 2,832 Times
What year team miyata?
I have an 84 and an 85
the 84 easily takes panaracer gravel kings in 28
the 84 easily takes conti gp5000 in 28 and vittoria corsa control tubular in 30mm
not sure what your mean by convert to 700c? the earliest reference to team miyata i can find is 81 and it had 700c rims
Quoted: 539 Post(s)
Liked 466 Times
Liked 2,832 Times
Vittoria Rubino Pro Tech III 28mm.
Once I actually got stopped by grass clippings that were blown into the road - yes, they stuck to the tire and jammed under the fork bridge, bringing me to a stop... Anyway, now I'm using the same tire but in 25mm up front. I had bought sets of both sizes. Now it wears the 25s up front and the 28s on the rear. Wheels have been changed since the pic. Now 36h Mavic Open Pro laced to Dura Ace hubs, and 15/16ga butted stainless spokes.
